Raevenlord
- Aug 12, 2016
- 3,755 (1.22/day)
- Portugal
System Name | The Ryzening |
Processor | AMD Ryzen 9 5900X |
Motherboard | MSI X570 MAG TOMAHAWK |
Cooling | Lian Li Galahad 360mm AIO |
Memory | 32 GB G.Skill Trident Z F4-3733 (4x 8 GB) |
Video Card(s) | Gigabyte RTX 3070 Ti |
Storage | Boot: Transcend MTE220S 2TB, Kintson A2000 1TB, Seagate Firewolf Pro 14 TB |
Display(s) | Acer Nitro VG270UP (1440p 144 Hz IPS) |
Case | Lian Li O11DX Dynamic White |
Audio Device(s) | iFi Audio Zen DAC |
Power Supply | Seasonic Focus+ 750 W |
Mouse | Cooler Master Masterkeys Lite L |
Keyboard | Cooler Master Masterkeys Lite L |
Software | Windows 10 x64 |
Thermaltake is adding the new Toughpower Grand RGB Platinum Series to its Power Supply line-up. Outside of the RGB LEDs, the fully modular members come in compact sizes to provide users with more room for cable routing, cooling and more.
The newest addition to the Toughpower Grand RGB family covers capacities ranging from 850W to 1200W, featuring a pre-installed, patented 256-color Riing 14 RGB fan with 5 lighting modes (RGB Cycle Mode, Solid Red, Solid Green, Solid Blue, and Solid White), a LED Off mode and a built-in memory function that remembers users last lighting mode selection even after a shutdown.
The application of PCB layout with PFC & LLC integrated circuit efficiently reduces ripple noise and gives better voltage rail control, and the ultra quiet Smart Zero Fan permits zero noise when the fan operates below 40% working load, plus, the 100% high quality 105°C Japanese made capacitors offers the highest stability and reliability. With an ample 10 year warranty, the Toughpower Grand RGB Platinum Series is the best choice for those who are seeking a flashy looking Power Supply with superior balance of performance and quality.
Features of the Toughpower Grand RGB Platinum Series (850W/1050W/1250W):
One Button to Your Desired Color
By pressing the RGB lighting button, the fan color can be switched among a 256 Color RGB Cycle with variants including Solid Red, Green, Blue, White, and a LED Off mode. The fan is also constructed with a built-in memory function, saving the color applied and insuring the same color selection every time you boot your PC.
Compact Design for Easy Integration
Toughpower Grand RGB 850W/1050W Platinum feature a compact depth of 160mm, and the 1200W one features an 180mm depth. With its short depth form factor, Toughpower Grand RGB Platinum Series gives high compatibility to allow users more room for cable routing, cooling and more.
New Platform for Better Ripple Noise and Voltage Rail Control
All new PCB layout with PFC & LLC Integrated circuit reduces ripple noise and gives better voltage rail control to elevate overall performance.
Power Supply Fan Face-Up Placement for Better Cooling
With the face-up placement of the fan, users can freely gaze upon their patented circular 256 multi-colored RGB fan and at the same time obtaining additional performance by using the fan as a additional exhaust mechanism, repelling unwanted heat from your chassis.
As the thermal image testing shown, the temperature of PSU and computer system will decrease around 3°C (5.4 °F) by placing PSU face-up.
Riing 14 RGB Fan with Concentrated Compression Fan Blade
Riing 14 RGB fan blade is designed for high static pressure requirements of demanding applications; the concentrated compression blade is engineered to focus the weaker, inner circle of air outward, allowing the outer section to pressurize the air. The fan blades are optimized to enhance static pressure for an impressive cooling performance. Hydraulic bearings for silent operation guarantee ultra-low noise, and the anti-vibration mounting system strengthens the product's stability during operation. Moreover, In-mold injection anti-vibration rubber pads provide hassle-free usage for 80% protection coverage, including all four corners.
Ultra Quiet Smart Zero Fan
Smart Zero Fan ensures zero noise when the fan operates below 40% working load to minimize audible noise. The fan will operate when the power supply working load over 40%. A switch is provided for those who prefer the fan to spin constantly.
< 30 mV Low Ripple Noise
All ripples are lower than 30mV for high stability on +12V, +5V, or +3.3V from 0% to 100% load to ensure a high quality power supply. Low ripple noise will keep your performance-critical components, such as high-end graphics cards, to operate reliably for longer.
Extremely Strict Voltage Regulation < ±2%
The voltage regulation of the PSU is set to no more than ±2% for major rails to meet the highest performance. The strict voltage regulation of the Toughpower Grand RGB Platinum is better than Intel's standard ±5% for major rails and ±10% for -12V.
100% High Quality Japanese 105°C/221°F Capacitors
100% high quality 105 °C (221 ° F) Japanese made capacitors which greatly improve the durability and offer the highest stability and reliability.
High Amperage Single +12V Rail & DC to DC Design
Toughpower Grand RGB 850 Platinum is equipped with a powerful single +12V rail, eliminating the limitations caused by voltage distributions, delivering the power your CPU and VGA demand in any situations. Besides, with DC to DC design, the unit optimizes maximum energy harvest for computer systems, providing the best compatibility, conversion efficiency and stable voltage output.
Fully Modular Low-Profile Flat Cable
Fully modular Toughpower Grand RGB 850W Platinum offers cable selection for users while powering the system at an advantageous voltage. Low-profile flat black cable can make cable management easier, reduce clutter and increase airflow inside the chassis.
80 PLUS Platinum Certified and Intel C6/C7 States Ready
Deliver up to 92% efficiency under real world load conditions to promise lowest power losses. Additionally, Toughpower Grand RGB Platinum Series has been optimized to work with all generations of Intel's processors to achieve maximum energy saving.
RGB Lighting Provides Best Aesthetics for All Chassis
Toughpower Grand RGB Platinum Series is the best idea for users to go with when they are looking for a high performance RGB PSU which permits remarkable functionality and aesthetics in all cases, especially Open Frame or Tower cases.
