Thermaltake Launches TOUGHDESK 350 Smart Gaming Desk
47,298 (7.53/day)
Thermaltake, the leading PC DIY premium brand for Case, Power, Cooling, Gaming peripherals, and enthusiast Memory solutions, unveils the TOUGHDESK 350 Smart Gaming Desk, equipped with a series of smart features to provide users with a more customized, flexible, and secure experience. The TOUGHDESK 350 Smart Gaming Desk matches the RGB Desk Mobile App and the iTake Engine Software allowing users to adjust desk height and RGB lighting through their own digital devices. On top of that, anti-collision safety sensors and upgraded dual electric motors enhance the safety and stability of the smart desk's lifting process.
With an exclusive TT Smart Control Unit, the TOUGHDESK 350 can be easily controlled by your phone or PC via WiFi. After connecting to WiFi, through the RGB Desk Mobile App, besides customizing the RGB lighting effects on the peripherals, you can set the desk height from 70 cm to 110 cm (27.5" ~ 43.3") or quickly switch to 4 levels of preset heights (70 cm, 80 cm, 90 cm, 100 cm). Additionally, with the powerful MCU built into the control unit, the mobile app can track your usage habits to automatically adjust the desk height based on your schedule.
For more control platform options, users also can effortlessly personalize the RGB lighting and desk height through the iTake Engine Software on the PC, or modify desk height and save up to 4 height memory settings through the smart controller panel on the desktop. According to your preference, you can elastically choose the way you like to operate The TOUGHDESK 350 Smart Gaming Desk.
To pursue a safe and stable usage situation, the TOUGHDESK 350 Smart Gaming Desk is installed with anti-collision safety sensors to automatically detect when the desk encounters obstacles while elevating the gaming desk. Furthermore, the double electric motors allow the TOUGHDESK 350 to increase the strength, stability, and quietness of the lifting process. Moreover, the steel-built frame efficiently prevents vibration during height adjustments to support the desk's stability and comfort.
TOUGHDESK 350 is a smart gaming desk that combines functionality and flexibility. The extra-large desktop and a max load of up to 150 kg (330 lb) reduce the limit for users to choose their preferable peripherals. Last but not least, TOUGHDESK 350 also offers a solution for cable management, and users can organize the wires in the groove under the desk to maintain the workspace clutter-free.
With smart features, safety design, stability, and user-friendly support, the TOUGHDESK 350 Smart Gaming Desk is an ideal choice for both office use and gaming.
Features of the TOUGHDESK 350 Smart Gaming Desk:
TT Smart Control Unit allows users to directly and stably control the TOUGHDESK 350 Smart Gaming Desk on their phone or PC via WiFi. In addition, the powerful MCU inside the control unit can record your preferable desk height and usage habits.
Exclusive RGB Desk Mobile App
With RGB Desk Mobile APP, the desk height can be set between 70 cm and 110 cm (27.5" ~ 43.3") or quickly switch to 4 programmable desk heights (70 cm, 80 cm, 90 cm, 100 cm). Furthermore, the app can track your desk setting and usage habits to automatically modify desk height based on your weekly schedule. Besides, the RGB lighting on the desk can be customized by 4 different lighting effect settings and 5 individual levels of brightness and lighting speed.
iTAKE Engine Software
Through iTAKE Engine Software, the desk height can be adjusted from 70 cm to 110 cm (27.5" ~ 43.3"). On top of that, you can choose between 4 different lighting effect settings coupled with 5 individual levels of brightness and lighting speed.
Anti-collision Safety Sensor
For your safety, an anti-collision safety sensor is installed on the TOUGHDESK 350 to automatically detect obstacles while elevating your gaming desk. Keep use process away from injury or accident.
Full surface RGB mouse pad design
The TOUGHDESK 350 Smart Gaming Desk comes with a RGB Lighting Strip, and lighting effects can be customized and synced via the Thermaltake RGB desk mobile app or iTAKE engine software. The surface of the speed-type mouse pad is incredibly smooth, flat, and water-resistant, which provides gamers with a superior experience of precise movements and easy cleaning.
6-button Smart Controller Panel
The smart controller panel along with a digital display board shows accurate height adjustments. Users can adjust desk height through the ascend and descend buttons and can set up to 4 height memory settings.
Cable Management System
Cable Management System assists in easily and conveniently sorting out your cable for keeps your workspace clutter-free.
Dual Stable Motor
The upgraded dual electric motors offer the desk a stable process when adjusting the height. Enhance the safety and quietness of the TOUGHDESK 350 Smart Gaming Desk.
708 (0.55/day)
System Name Red Devil
Processor AMD 5950x - Vermeer - B0
Motherboard Gigabyte X570 AORUS MASTER
Cooling NZXT Kraken Z73 360mm; 14 x Corsair QL 120mm RGB Case Fans
Memory G.SKill Trident Z Neo 32GB Kit DDR4-3600 CL14 (F4-3600C14Q-32GTZNB)
Video Card(s) PowerColor's Red Devil Radeon RX 6900 XT (Navi 21 XTX)
Storage 1 x Western Digital SN850 1GB; 1 x WD Black SN850X 4TB; 1 x Samsung SSD 870EVO 2TB
Display(s) 1 x MSI MPG 321URX QD-OLED 4K; 2 x Asus VG27AQL1A
Case Corsair Obsidian 1000D
Audio Device(s) Raz3r Nommo V2 Pro ; Steel Series Arctis Nova Pro X Wireless (XBox Version)
Power Supply AX1500i Digital ATX - 1500w - 80 Plus Titanium
Mouse Razer Basilisk V3
Keyboard Razer Huntsman V2 - Optical Gaming Keyboard
For those interested:
Desktop size - 160cm x 80cm x 2.5cm / 63in x 31.5in x 1in
Material - MDF
Price - $1,099 (MSRP)
6,263 (1.53/day)
Over here, right where you least expect me to be !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
With a cheap-assed MDF top with nm-thin cheap-assed laminate edge covering....n.O.p.E., not doin that, no way, 'Jose !
And seeins how the previous model was $900, and this one at $1100, it's an auto no-buy except for the "moar $$ than brains" crowd :(
I'll just stick with my 72" L x 36" D x 2.5" thick SOLID Oak desk with powder-coated Stainless steel frame & legs & 6mm thick basketball court finish thank you, for which I only paid $350 :D
72 (0.08/day)
I was kind of interested until I saw that price. I can do much better for half the cost.
58 (0.06/day)
This screams the opposite of smart.
Just like with the gaming chairs, just get the office version - or perhaps DIY your own desk if you're willing.
1,197 (1.22/day)
Uplift actual wood desks and herman miller aeron chairs.
This gaming crap sucks.
2,227 (1.24/day)
System Name GrandadsBadAss
Display(s) Acer XG270HU
Audio Device(s) Logitech z623 <---THE SUCK
Keyboard Roccat Vulcan Aimo
Software Win 10/11pro
$1100 for an MDF desk. With collision avoidance system, cant forget that key feature of which at LEAST 2/3s of the price is based upon...at least. Because the MDF itself has gotta be worth a 10 spot.
Nope, not even after celebrating hitting the Lotto with a fifth of Jack.
42,612 (6.67/day)
How about they get back to making Good Cases and cpu cooling
