Thermaltake Releases M900 XXL RGB Mouse Pad
1,519 (0.86/day)
Thermaltake, the leading PC DIY premium brand for Cooling, Gaming Gear, and Enthusiast Memory solutions, introduces the M900 XXL RGB Mouse Pad, a full desk surface mouse pad featuring 16.8milliontrue RGB color illumination along with seven dynamic lighting effects. This mouse pad has a surface size of 1600 mm in length and 800 mm in width, which provides limitless space and unrestricted movement for your keyboard and mouse to glide through during gameplay. The 4 mm thickness of this mouse pad also ensures maximum comfort and is capable of smoothing out uneven surfaces that users may encounter. The weave design provides a smooth but semi-coarse texture that delivers low friction, high consistent accuracy, and responsive tracking fit for both laser and optical mice. This long-lasting mouse pad is iTAKE engine software and TT RGB Plus compatible; users can customize, control, and sync lighting effects via the Thermaltake iTAKE engine software that connects all your Thermaltake Gaming Peripherals and TT RGB PLUS compatible products without a hassle.
Full-Size Surface
The M900 XXL RGB Mouse Pad's full surface size (1600 mm x 800 mm x 4 mm) provides limitless space and unrestricted movement for your keyboard and mouse for free-flowing gameplay.
Striking Visuals
Users may choose among seven different lighting effect settings coupled with brightness and lighting speed adjustments to display stunning 16.8 million RGB color illumination, providing the brightest visibility and eye-catching style for your gaming sessions.
Total Control With Superior Responsiveness & Accuracy
Optimized with a smooth semi-coarse textured weave design, the M900 XXL RGB delivers superior gaming performance for both laser and optical mouse types; and provides low friction, high consistent accuracy, and responsive tracking, whatever the game.
Maximized Comfort
Smooth surface design with 4 mm thickness ensures maximum comfort during extended periods of play and is compatible with the majority of surfaces, smoothing out those little inconvenient uneven surfaces that you may encounter.
Built to Last
High-quality, robust sewing edge design prevents peeling or warping of the mouse pad. Made with a non-slip rubber base, play with confidence, and never have to worry about mousepad lift-off or slipping!
iTAKE Engine Software
Customize, control, and sync lighting effects via the Thermaltake iTAKE engine software that connects all your Thermaltake Gaming Peripherals and TT RGB PLUS compatible products. SyncALL RGB colors seamlessly via the TT SYNC function, creating one complete ecosystem.
TT RGB PLUS Compatible
Sync all TT RGB PLUS compatible power, liquid cooling, case fans, and Thermaltake Gaming product lines for seamless color coordination of your ecosystem.
For more details on the M900 XXL RGB Mouse Pad, please visit.
5,676 (0.97/day)
System Name Cyberline
Mouse Elecom EX-G
Keyboard Rapoo V700
