Thermaltake Releases the CTE E660 MX Mid Tower Chassis
GFreeman
1,561 (2.41/day)
Thermaltake, a leading PC DIY brand for premium hardware solutions, is proud to launch the CTE E660 MX Mid Tower Chassis, a dual chamber mid-tower supporting ASUS and MSI Hidden-Connector motherboards. Along with excellent motherboard compatibility, the CTE E660 MX also features an interchangeable dual front panel design, a three-way GPU installation option, and exceptional cooling support, enabling the creation of a dream PC with superior flexibility. Available in four colors, including Black, Snow, Racing Green, and Hydrangea Blue, this chassis offers a variety of options to suit your preferences.
Designed for next-generation motherboards, the CTE E660 MX is compatible with both standard motherboards and the latest hidden-connector motherboards (ROG MAXIMUS Z790 HERO BTF / ASUS TUF GAMING Z790-BTF WIFI / MSI Z790 PROJECT ZERO). Using a hidden-connector motherboard enables you to route messy cables to the rear, improving cable management and enhancing the aesthetics of your builds. To cater to diverse needs in PC customization, the CTE E660 MX combines sleek design with practicality. The left side of the chassis incorporates a 4 mm tempered glass panel, offering a clear view of the interior configuration. Additionally, the CTE E660 MX provides two interchangeable front panels: a tempered glass panel for expansive visibility and a perforated panel for enhanced airflow, allowing you to tailor setups for aesthetic appeal and optimal performance.
For maximum customization, the CTE E660 MX includes a three-way GPU installation option, enabling you to place components as you prefer:
Three-Way GPU Installation
  • 1. Floating GPU: Placing the GPU in the middle of the chassis by using the enclosed floating GPU bracket and pre-configured 400 mm long PCI-e 4.0 riser cable
  • 2. Up Right: Hanging the GPU vertically
  • 3. Right Forward: Placing it up-right with the graphics card facing forward to the side panel on the rotational PCI-e slots
The CTE E660 MX provides outstanding cooling support, it can accommodate up to a 420 mm AIO radiator at the front, rear and the M/B side, and up to fourteen 120 mm fans or twelve 140 mm fans can be installed in the chassis, ensuring exceptional cooling capability for top-tier components. This case also boasts optimal hardware compatibility. With support for an E-ATX (12"x10.5") motherboard, a power supply up to 220 mm in length, and storage options including up to two 2.5" SSDs or three 3.5" HDDs, the CTE E660 MX provides versatile and efficient configurations for demanding builds.
If you are seeking a chassis that has a maximum flexibility for installation, don't miss out on the CTE E660 MX. Its hidden-connector motherboard support, dual front panel design, and a three-way GPU installation option allow you to effortlessly customize a PC that meets both performance and aesthetic needs.
Features of the CTE E660 MX Mid Tower Chassis:
Compatible with Hidden-Connector Motherboards
Created for next-generation Hidden-Connector motherboards, the CTE E660 MX features a special design that enables support for both standard motherboards and hidden-connector motherboards from ASUS and MSI.
Compatible with hidden-connector motherboards:
  • ROG MAXIMUS Z790 HERO BTF
  • ASUS TUF GAMING Z790-BTF WIFI
  • MSI Z790 PROJECT ZERO
Dual Interchangeable Front Panels
With a 4 mm tempered glass panel pre-installed on the left side, users can easily show off their interior configuration; on top of that, the CTE E660 MX offers two interchangeable front panels: a tempered glass panel and a perforated panel. The former for a great look and the latter for better airflow. Users have the flexibility to display their PC build the way they want.
Display It Your Way: Three-way GPU Installation
There are three different ways to mount your GPU:
  • 1.Floating GPU: Placing the GPU in the middle of the chassis by using the enclosed floating GPU bracket and pre-configured 400 mm long PCI-e 4.0 riser cable
  • 2.Up Right: Hanging the GPU vertically
  • 3.Right Forward: Placing it up-right with the graphics card facing forward to the side panel on the rotational PCI-e slots
PCI-e 4.0 Riser Cable and Floating GPU Bracket Included
A pre-configured 400 mm PCI-e 4.0 riser cable makes it easy to achieve "floating GPU'' and "Up Right Forward" GPU placements. The riser cable complies with PCI-e 4.0 Standards, offering a 16GT/s transfer rate and supporting up to 64 GB/s (bi-directional) data transmission.
Maximum Radiator Support
The CTE E660 MX offers multiple mounting locations and plenty of room to create your own configurations. DIY radiators up to 420 mm in length can be installed on the front, rear, bottom and M/B side, and for AIO compatibility, up to 420 mm/360 mm radiators can be installed on the front, rear and M/B side, giving PC enthusiasts plenty of flexibility to create their ideal setup.
CTE Form Factor Designed by Thermaltake
The CTE Form Factor Designed by Thermaltake, stands for Centralized Thermal Efficiency, and is focused around providing high level thermal performance to critical components. The design utilizes a 90-degree rotation of the motherboard providing more efficient airflow pathways.
Move Critical Heat Sources (CPU And Graphic Cards) Closer Towards Cool Air
Since the CPU location has been moved much closer to the front panel and the graphics card moved closer towards the rear panel, independent cold air induction is given for thermal dissipation of the CPU and graphics card respectively. This overall approach has allowed CTE to provide better and more efficient intake airflow through the placement of main components and cooling, as well as optimization to heat extraction from the system.
All your dream cooling components can fit!
The CTE E660 MX is designed with enormous fan and cooler installation capacity: up to fourteen 120 mm fans or twelve 140 mm fans, and 360 mm/420 mm AIO coolers at the front, rear and the M/B side. Moreover, equipped fan brackets at the front and bottom, and the installation spots at the top, rear, and M/B side ensures easy installation of all your desired cooling components.
Excellent Hardware Support
The CTE E660 MX has excellent expandability, allowing you to build the most high-end system you can dream of. It can support up to an E-ATX (12"x10.5") motherboard, a CPU cooler with a maximum height of 166 mm, VGA clearance up to 443.8 mm in length without a radiator, a power supply with a length of up to 220 mm, and up to two 2.5" SSD or two 3.5" HDD.
How Much Storage Is Totally Up To You
In the right chamber of the CTE E660 MX, you can put on up to two 3.5" hard drives in the HDD Cage, and one 3.5" hard drive or two 2.5" drives on the Drive Plate.
Everything You Need Is Located In One Place
Two USB 3.0 ports, one USB 3.2 Gen 2 Type-C, and HD Audio ports are placed on the top panel to grant direct access when needed.
Perfect Dust Protection
There are fine removable filters at the top, front, bottom, rear and right side of the chassis to provide excellent protection against dust, and they are easily removable for cleaning.
189 (0.80/day)
System Name Main Workstation
Processor AMD Ryzen Threadripper 2970WX PBO 3,6-4,2Ghz
Motherboard Gigabyte x399 Aorus Pro (ReBAR patched)
Cooling Alphacool Eisbaer Aurora Pro 420
Memory 8x16GB (128) Kingston Fury RGB @3266Mts 16-18-18-36-74 2T
Video Card(s) RTX 3090 ROG Gaming OC @1500Mhz (1965Boost)
Storage Lexar NM790 2TB, Corsair Force MP510 960Gb, Samsung 860 SATA 2TB, 2TB WD Green 7200rpm
Case Phanteks Ethoo Pro 2 TG
Power Supply EVGA Super Nova 1000GT
Thats the worst green Ive ever seen. And besides a PEPE build, I see no use for it.
14,146 (3.82/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
These have been on Amazon for a short while already
6,225 (1.53/day)
Over here, right where you least expect me to be !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
Yea, but can we now just UN-see them, please, oh pretty please...just another rehash of a rehash of another rehash boring AF rectangular boxen :D
1,420 (0.36/day)
Processor 11900K
Motherboard ASRock Z590 OC Formula
Cooling Noctua NH-D15 using 2x140mm 3000RPM industrial Noctuas
Memory G. Skill Trident Z 2x16GB 3600MHz
Video Card(s) eVGA RTX 3090 FTW3
Storage 2TB Crucial P5 Plus
Display(s) 1st: LG GR83Q-B 1440p 27in 240Hz / 2nd: Lenovo y27g 1080p 27in 144Hz
Case Lian Li Lancool MESH II RGB (I removed the RGB)
Power Supply Seasonic Prime 850 TX
Mouse Glorious Model D
Keyboard Glorious MMK2 65% Lynx MX switches
Software Win10 Pro
How do you get to your IO panel? Is someone supposed to just let their GPU display cable just get bent up into the rear fans?
Reminds me of the old BMW racing green, I like the color, just not on my case but options are better than black or white.
28 (0.06/day)
System Name SigmaMATER
Processor Ryzen 7 5800x3d
Motherboard x570 Aorus Master
Cooling Arctic Freezer iii 420
Memory Corsair Dominator Platinum 32gb 3600mz c15
Video Card(s) Rx 7900 xtx
Storage Crucial P5 plus 2tb, Crucial MX500 2tb, Seagate 2tb SSHD, Western Digital 10tb Ultrastar 2x
Display(s) Predator x27 and some lenovo and some other one
Case Corsair 7000D
Power Supply Evga 1600 p2
Mouse Logitech G Pro Wireless
Keyboard Evga z20
Software Windows 11 Enterprise
Could use some more fans
2,120 (1.03/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
Software Windows 10 Pro X64
Benchmark Scores Who cares
Weird i/o layout, with all cable coming out of the two holes in the back. Could be awkward, no fast plugging in of a USB device
Edit, i see what you mean now, mmm. i guess you could have the GPU in one of the other two configs
$180 not too bad i guess
14,146 (3.82/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
This would be an excellent airflow case once the mesh front panel was swapped with the glass front panel.
HyperBuildLabs
1 (0.03/day)
The E600 was already existed, they just add the support for the new motherboards with hidden cables and they changed the colour of the aio cables to white at the white and the blue version, and then it became E660, but after all its the same same case you are right! Even at youtube no one made a review about the E660, thermaltake dont even send it to reviewers
