Thermaltake Unveils Its First Ever Bumblebee-Colored Product in The Tower 200 Mini Chassis Series
GFreeman
1,628 (2.41/day)
Thermaltake, the leading PC DIY premium brand for Case, Power, Cooling, Gaming peripherals, and enthusiast Memory solutions, is excited to announce the launch of The Tower 200 Bumblebee Mini Chassis, a new-color version of the beloved The Tower series. The Tower 200 is a Mini-ITX case with a vertical case design and exceptional thermal efficiency. Though this chassis comes in a compact size, it can support the length of a 4090 graphics card and a 280 mm radiator. With the addition of a new vibrant yellow hue, The Tower 200 series now comes in six colors: Black, Snow, Turquoise, Racing Green, Matcha Green, and Bumblebee, allowing you to easily choose an ideal The Tower 200 to fit your style.
The Tower 200 Bumblebee has the same vertical body design as its predecessors, providing users more space flexibility with its smaller footprint. Like the productive spirit of a bumblebee, The Tower 200 Bumblebee is a tiny but mighty case that offers superior hardware support and exceptional cooling performance. The Tower 200 can accommodate a graphics card with a length of up to 380 mm such as the latest 4090 GPU and a standard-size power supply of up to 220 mm enabling you to choose the high-performance components you want. Additionally, The Tower 200 can house a CPU cooler with a maximum height of 200 mm, support an AIO radiator up to 280 mm, and is preinstalled with two CT140 PC Cooling Fans, allowing The Tower 200 Bumblebee to maintain a low interior temperature at all times.
Whether you are in gaming, video editing, or just daily use, the bright exterior color of The Tower 200 Bumblebee can inspire your courage and confidence, enabling you to reach your desired goals with fully positive energy. To be more visually pleasing with The Tower 200 Bumblebee, the fantastic inner components can easily be displayed through the tempered glass front panel. You also can make The Tower 200 Bumblebee more interactive with the separately sold LCD Panel Kit. The 3.9" LCD display can show components' real-time information, time, and weather. Besides, you can personalize your LCD display by uploading any images or GIFs through the TT RGB Plus 2.0 software.
The Tower 200 Bumblebee is a tiny but mighty chassis, like a bumblebee. If you are a compact chassis lover who would like to achieve outstanding cooling performance, hardware support, and visual aesthetics at the same time, don't miss out on The Tower 200 Bumblebee Mini Chassis!
Features of The Tower 200 Bumblebee Mini Chassis:
Tiny but Mighty
As a new addition to The Tower series, The Tower 200 Bumblebee has the same contours as its predecessors, allowing for an unobstructed view of the system components. The Tower 200 can accommodate a 4090 GPU, a standard-size power supply up to 220 mm, and a 280 mm radiator for optimal performance. In addition to the two pre-installed fans, one 140 mm at the top and one 140 mm at the rear, you can also mount a 120/140 mm fan on top of the power cover. These features allow for easy integration of the latest PC hardware without compromising on the building experience, making The Tower 200 Bumblebee an excellent choice for those looking to expand their hardware capabilities.
4090 GPU Fits in Perfectly!
The Tower 200 Bumblebee is fully equipped to accommodate all of your essential components, including the latest high-performance graphics cards such as the 4090 GPU. Besides, it can support graphics cards up to 380 mm in length, providing you with the flexibility to choose the best graphics card for your needs. Rest assured that The Tower 200 Bumblebee has got you covered, no matter what GPU you decide to use.
Classic Vertical Body Design
The Tower 200 Bumblebee retains the iconic contours of its predecessors, with a vertical body design that allows the chassis to have a smaller footprint, providing flexibility and minimizing obstructions to your gaming and workspace.
Supports up to a 280 mm Radiator on the Right
Despite its small size, The Tower 200 Bumblebee delivers exceptional cooling performance without any compromise. It supports up to a 280 mm radiator on the right side, which effectively reduces the temperature inside the chassis and maintains optimal system performance.
Two CT140 PC Cooling Fans Pre-installed
The Tower 200 Bumblebee features two 140 mm PWM fans, one on the top and the other on the rear, to provide good cooling performance.
Unify Your Fans with Your Build!
Thermaltake launches brand-new CT series fans, allowing users to choose from black or white, RGB or non-RGB, to match whatever color scheme you have.
Visually Pleasing, Totally Interactive
Maximize your Tower 200's visual effects by upgrading it with our optimal LCD Panel Kit. The 3.9" LCD Display allows you to monitor real-time information and upload any images or GIFs to add extra flair using the TT RGB Plus 2.0 software. It also allows you to interact with the cooling components that feature the same LCD displays. The latest version includes weather mode and time mode for users to expand the usage of our LCD displays.
Secure Your Components
The Tower 200 Bumblebee features a GPU stabilizer to ensure the GPU doesn't wobble during use or transport.
Choose the Way You Install
On the right side, The Tower 200 Bumblebee has the capacity to support either two 120/140 mm fans or a 280 mm radiator. Installation is a breeze thanks to the removable fan bracket, which simplifies the process.
Air Intake and Exhaust
People may have concerns about the cooling performance of a Mini-ITX chassis. However, our The Tower 200 Bumblebee has well-designed cold air intakes and hot air exhausts to keep the internal temperature low at all times.
Massive Airflow & Incredible Performance
Thanks to two CT140 PC Cooling Fans pre-installed, we were able to ensure that The Tower 200 comes with massive airflow, which guarantees amazing cooling performance and a low interior temperature while using the most upscale components.
Perfect Dust Protection
The Tower 200 Bumblebee has well-designed removable fan filters on the rear, inner two sides, and inner bottom layer. The removable filters provide excellent dust protection to ensure a dust-free environment.
Hardware Support and Cooling Solution
The Tower 200 Bumblebee has good hardware support. It can support a CPU cooler with a maximum height of 200 mm, a GPU with a maximum length of 380 mm (without power cover), a power supply with a length of up to 220 mm, two 2.5" SSDs with the side bracket and two 2.5" SSDs or two 3.5" HDDs (without rear fan) behind the motherboard tray. Although The Tower 200 Bumblebee is a Mini-ITX chassis, it is still optimized for good cooling. On the top and rear of the case comes with two pre-installed CT140 fans, which can improve thermal efficiency. An additional 120 mm or 140 mm fan can be installed on top of the PSU cover, and up to a 280 mm all-in-one CPU cooler can be installed on the right side of the case.
Handy I/O Ports
One USB 3.2 (Gen 2) Type-C and two USB 3.0 ports are placed on the top panel to grant direct access when needed.
DMD: Dismantlable Modular Design
No more unreachable screw corners or gaps, installation can be a breeze with our Dismantlable Modular Design.
17,966 (2.44/day)
Since when is bumblebee a colour?
2,259 (1.14/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
tbh the front panel logo of the bumblebee looks more like a wasp
2,678 (0.57/day)
East Europe
System Name PLAHI
Processor I5-10400
Cooling 120 AIO IWONGOU
Video Card(s) PNY QUADRO RTX A2000
Storage Intel 670P 512GB
Case Silverstone Raven 03 (RV03)
Mouse Logitech Triathlon
Keyboard REDRAGON MITRA
Software Windows 11 Home x 64
17,966 (2.44/day)
Maybe, because a Bumblebee is yellow and black.
Some are, many are also orange and some are almost brownish, while others have some white as well. There's more than one type of bumblebee.
148 (0.06/day)
Agreed but, if we look at every maufacturer that names a colour.
VW has a colour they call white but it is clearly a light shade of grey and how about sunset orange, that could be probably be over 100 different shades of orange.
2,355 (0.46/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
Outback Bronze
Super Moderator
2,070 (0.42/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 48GB G.Skill 7200
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Samsung 34" G8
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Asus
Keyboard Corsair
Software Win 11
Wheres the Bumblebee decal?
It sure as hell doesn't look like Bumblebee
2,153 (1.04/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
Software Windows 10 Pro X64
Benchmark Scores Who cares
I do like the yellow though
2,678 (0.57/day)
East Europe
System Name PLAHI
Processor I5-10400
There you go :) Dunno how it is with royalties and creative freedom, may be they can't put a sticker on. I really can't tell.
Case_Closed
2 (0.00/day)
"Thermaltake, the leading PC DIY premium brand for Case ... solutions,"
Well I have a Tower 900. One of the windows slipped, fell 6 inches, hit the floor and literally exploded into thousands of very sharp glass fragments. Sliced my leg open on a small piece during clean up. Called support to see if they could sell me a new window since I was off warranty. The reply was that they have no parts department or parts to sell. Odd that the "leading ...brand" has zero customer service for one of what I assume is their premier case products. That stung! I will not be buying another Thermaltake product again.
6,881 (1.46/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
Looks like a yellow jacket.
725 (0.55/day)
System Name Red Devil
Processor AMD 5950x - Vermeer - B0
Motherboard Gigabyte X570 AORUS MASTER
Cooling NZXT Kraken Z73 360mm; 14 x Corsair QL 120mm RGB Case Fans
Memory G.SKill Trident Z Neo 32GB Kit DDR4-3600 CL14 (F4-3600C14Q-32GTZNB)
Video Card(s) PowerColor's Red Devil Radeon RX 6900 XT (Navi 21 XTX)
Storage 1 x Western Digital SN850 1GB; 1 x WD Black SN850X 4TB; 1 x Samsung SSD 870EVO 2TB
Display(s) 1 x MSI MPG 321URX QD-OLED 4K; 2 x Asus VG27AQL1A
Case Corsair Obsidian 1000D
Audio Device(s) Raz3r Nommo V2 Pro ; Steel Series Arctis Nova Pro X Wireless (XBox Version)
Power Supply AX1500i Digital ATX - 1500w - 80 Plus Titanium
Mouse Razer Basilisk V3
Keyboard Razer Huntsman V2 - Optical Gaming Keyboard
Yeah, uh-huh, you know what it is
Black and yellow
Black and yellow
Black and yellow
Black and yellow
Black and yellow
Black and yellow
Black and yellow
Black and yellow - (Wiz Khalifa, Oct 2010)
418 (0.08/day)
System Name Very old, but all I've got ®
Processor So old, you don't wanna know... Really!
I consider this a very lazy marketing. Kinda stasis-marketing if you will. This is just a chassis with two solid colours. They at least had to mention that it is named after the transformer one. But even the movie/comics character, had a mix of alternating yellow/black in it's appearance.
I don't want to put words in someone's mouth. But perhaps, Swede meant that bumblebee is not a colour.
There's no pattern in the appearance. And as Totally mentioned, Bumblebee is actually two colours, the colour scheme of alternating stripes of black and whatever is the other one. There's an enormous variety of them, with different colours sets, and all of them are bumblebees. Actually there are even solid black ones as well.
Also. As the company claim they are about DIY market, they could at least make some custom type of chassis for modders and other very DIY people, which would have no colour at all, but the primer coating istead. And then sell the variety of custom/selected colour sprays along with the chassis itself, so people could dye it whatever way they want.
P.S.: Don't want to offend anyone, but it seems that "Holywood" folks are dumb and completely out of touch. And whatever company copies their design and ideas is spreading the misleading stereotypes and ignorance into masses.
6,305 (1.54/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
Although I agree with you about the lack of customer service & spare parts, and yea, I know this may sound a bit harsh, but they (nor any other mfgr) are NOT responsible for your carelessness in dropping the glass...which IIRC, normally does shatter when dropped onto a hard surface...
I've had a Tower 900 since just after they were released, and have yet to even come close to dropping any of the panels, even through multiple assembly/disassembly/cleaning/rebuild/upgrade cycles...thanks to the non-slip rubber gloves that I used :D
But anywayz, I really wish they had made this many colors when I bought it (only black & white back then), which would have saved me weeks of prepping, sanding, priming & painting time, not to mention the $150 worth of supplies & paint, hehehe... :)
As for the "bumblebee", 1 or 2 colors thing....m.E.h.
Case_Closed
2 (0.00/day)
Good for you. It was an accident. My fault completely. My beef is that accidents happen and customer support means supplying parts to a premier product when needed. Not even having a parts department defines the absence of customer support. I replaced the window with a tinted plexiglass that I cut and drilled. Slight optical difference but otherwise guaranteed not to shatter.
Outback Bronze
Super Moderator
2,070 (0.42/day)
Walkabout Creek
Cooling w.c.
Case Corsair 460X
Mouse Asus
Keyboard Corsair
Software Win 11
That wasn't a bad idea.
I've got a Tower 900 as well and to me the original glass panels are actually too dark, as its harder to see your build inside. I was contemplating replacing them with a clear glass anyways.
2,425 (1.16/day)
Olympia, WA
System Name Sleepy Painter
Processor AMD Ryzen 5 3600
Video Card(s) MSI RX580 8GB
Case NZXT Gamma Classic Black
Audio Device(s) Asus Xonar D1
Mouse Logitech MX518 Legend
Keyboard Red Dragon K552
Leave it to VW to be utterly ridiculous.
...and leave it to ThermalTake to skirt IP/copyright law.
I bet Hasbro is regretting naming one of the most-popular characters after a generic bee (ie, limited copyright protections)
