Thermaltake Unveils View 37 RGB Edition and View 37 Riing Edition
46,926 (7.61/day)
Thermaltake, a leading premium gaming tower manufacturer, announced the immediate availability of Thermaltake View 37 RGB Edition and View 37 Riing Edition Mid-Tower Chassis. Constructed with a gull-wing window panel for internal components show-off, the View 37 Series delivers a sleek look to complement its excellent cooling. View 37 RGB Edition is preinstalled with 3 built-in Riing Plus 140mm Hardware Control fans, a Riing Plus RGB controller and a PCI controller to deliver 256-color RGB illumination and unparalleled ventilation.
More custom RGB lighting possibilities are permitted thanks to its light synchronization with enthusiasts' favorite RGB motherboard brands: Asus AURA SYNC/ Gigabyte RGB Fusion/MSI Mystic Light Sync-enabled motherboards. As to View 37 Riing Edition, it features 2 built-in Riing 14 LED Blue fans to illuminate and dissipate heat more properly. The duet doesn't disappoint when it comes to cooling potential and flexibility, with its ability to accommodate up to 8 case fans, including up to two large 200 mm fans at the front.
Speaking of hardware support, View 37 Series has ample room for up to seven 3.5" or eleven 2.5" HDDs, plus "8+2" expansion slots. It supports CPU coolers up to 180mm in height, VGA lengths up to 410mm, PSU sizes up to 220mm in length, and the latest AIO/DIY liquid cooling solutions. It is designed to embrace the diversity of a gaming station with stylish statement and options and make PC enthusiasts' next rig like no other.
Exclusively "Tt LCS Certified"
Tt LCS Certified is a Thermaltake exclusive certification applied to products that pass the design and rigorous hardcore enthusiast standards that only the world's best LCS chassis are held to. The Tt LCS certification was created so that we at Thermaltake can clearly convey to power users and enthusiasts which chassis are built and tested to be best compatible under extreme liquid cooling configurations. This ensures you get the best performance, compatibility and features.
Features of Thermaltake View 37 RGB Edition and View 37 Riing Edition Mid-Tower Chassis:
Enlarged Transparent Gull-wing Window Panel Design
Constructed with premium transparent top panel wrapping around to the side, View 37 Series ensures durability of the window and delivers a gorgeous view of the superb configuration inside.
3 Built-in Patented Riing Plus 140mm Hardware Control Fans
View 37 RGB Edition Mid-Tower Chassis comes with three patented Riing Plus 140mm Hardware Control fans to offer high-static pressure, 256 colors LED ring, 12 addressable LEDs, compression blades and hydraulic bearing for a vivid illumination and ultimate thermal efficiency. To deliver a better RGB experience, the Riing Plus 140mm Hardware Control fan is a hardware/software controllable gear that the fan speed/light mode/color mode/light speed can be customized through the included Riing RGB Controller and PCI Controller or via Asus AURA SYNC/ Gigabyte RGB Fusion/MSI Mystic Light Sync. Making the fan light match your build's style has never been so easy.
Software Controllable Lighting in Sync with Asus/Gigabyte/MSI Motherboards (View 37 RGB Edition Only)
Thermaltake has teamed up with enthusiasts' favorite motherboard brands, Asus/Gigabyte/MSI, to give View 37 RGB Edition Mid-Tower Chassis even more illumination synchronization options. Just connect the Riing Plus 140mm Hardware Control fan to the built-in Riing Plus RGB controller and Asus AURA SYNC/ Gigabyte RGB Fusion/MSI Mystic Light Sync-enabled motherboards for the ultimate compatibility.
Built-in Riing Plus RGB controller (View 37 RGB Edition Only)
View 37 RGB Edition direct fan control:
The built-in Riing Plus RGB controller is a 3 port hub that offers direct fan speed/light mode/color mode/light speed control over the Riing Plus 140mm Hardware Control fans. There is also a built-in memory function to save the color applied and insure the same color selection every time you boot your PC.
View 37 RGB Edition fan control in conjunction with Asus/Gigabyte/MSI motherboard RGB software:
Connect Riing Plus 140mm Hardware Control fans with the Riing Plus RGB controller and Asus/Gigabyte/MSI motherboard RGB software to easily expand illumination synchronization options without the need to install any extra lighting controllers.
Built-in PCI Controller (View 37 RGB Edition Only)
Simply install the included PCI Controller on the outside of View 37 RGB Mid-Tower Chassis's back panel and enjoy taking full control of the fan lighting mode/speed without the need of removing the side panel. Up to 2 Riing Plus RGB controllers can be connected to the PCI Controller at the same time.
Advanced Ventilation
To dissipate heat properly, View 37 RGB is preinstalled with three Riing Plus 140mm Hardware Control fans (two front fans and one rear fan) while View 37 Riing Edition is preinstalled with dual Riing 14 LED Blue fans (one front fans and one rear fan). View 37 Series enables users to build a complete high-end system with ample room for up to 8 case fans, and full compatibility with 420mm, 360mm, 280mm, 240mm, 140mm and 120mm radiators.
Removable front fan filter, front panel filter and the power supply filter at the bottom provide excellent reduction against dirt and dust and gives better airflow.
Upgrade with Up to Two 200mm Front Fans
View 37 Series doesn't disappoint when it comes to cooling potential and flexibility. It supports up to two 200mm front fans to guarantee high airflow and embraces the diversity of a PC case with stylish statement and options.
Tool-Free Installation
The fully modular tool-free drive cages to provide the ease of installation/removal and maximize the interior space for highly customizable layouts. The modular drive bay concept of "3+4" offers a good ratio for accessories and storage devices.
Outstanding Expandability
Guarantees outstanding hardware expandability thanks to the support for standard E-ATX form factor motherboards, a CPU cooler with maximum height 180mm, a VGA of up to 410mm in length without front fan, and a power supply with length of up to 220mm while there is still plenty room for accommodating multiple 3.5"/2.5" storage devices.
Riser GPU Support Bracket
Specially designed for dual GPU placement options, View 37 Series has the support for vertical graphic card layout with dual PCI-E slots design. Integrated riser GPU support bracket not only prevents the graphic card from sagging, but also helps to reduce the weight on the motherboard PCI-E slots.
Vertical Radiator View (VRV)
Turn the tides on traditional radiator mounting and bring out the glorious view of custom loop or all-in-one radiator applications with vertical radiator viewing. Supporting proper placement for 120mm and 140mm radiator applications up to 420mm in length, gain more compatibility when pairing up both CPU and GPU cooling solutions. Take on even more with custom loop options for enthusiast grade cooling, fitment and flow.
AIO/DIY Liquid Cooling Capable
View 37 Series supports all types of advanced AIO liquid cooling solutions and has the capability to house up to one 420mm DIY liquid cooling radiator fitment, either at the front or on the right side.
For more information, visit the product pages of the View 37 RGB Edition and the View 37 Riing Edition.
7,762 (2.90/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Mouse Logitech G603
Wait, so according to the pictures this thing comes with four SSD trays? Fitting three drives each? Where do they all go? And who on earth has that many 2.5" drives in a single system?
4,297 (0.87/day)
Watch the review on hardwarecanucks, those 2.5"/3.5" trays fit behind the motherboard tray. Someone like Linus has more than 4 SSDs in RAID. Its just a provision made by TT and you can use those according to your personal setup.
7,762 (2.90/day)
Back in Norway
System Name Hotbox
Mouse Logitech G603
"Someone like Linus", as in Linus Sebastian of LTT? The richest/most sponsored person in tech? Yeah, I doubt there's enough people like that out there to warrant the inclusion of 12 SSD positions. Not that there's a lack of people with tons of cash to burn on PCs, but from my experience on various forums, the amount of people with >4 SSDs is tiny. Not to mention that there's a quite significant difference between ">4" and 12.
I prefer the opposite approach, frankly: make it possible to install more caddies if wanted, but don't bundle something that 99.9% of users will never ever have any use for. That just generates waste or makes the case more cluttered than what's necessary. Include one or two (still massively overkill for the vast majority of users), and sell more separately for $5 or something - packaging would be trivial, distribution networks are already there, warranty and service would be a non-issue for a part like this - and the amount of complaints would be trivial.
Ruru
S.T.A.R.S.
11,953 (2.80/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X
Cooling Arctic Freezer 50
Memory 48GB Kingston DDR4-3200C16
Storage ~3TB SSDs + 3TB external HDDs
Audio Device(s) Asus TUF H3 Wireless
VR HMD Oculus Rift CV1
Well, some people have still their cases full of HDDs.. I have four 2.5" SSDs and a NVMe drive as an OS drive.
7,762 (2.90/day)
Back in Norway
System Name Hotbox
Mouse Logitech G603
So, in other words, you'd populate 1 1/3 tray out of 4 in this case. If two were included, you'd still need to buy two more SSDs to run out of space. And sure, some people still have their cases full of HDDs - but those aren't 2.5" HDDs, and as such wouldn't fit these trays in the first place.
Ruru
S.T.A.R.S.
11,953 (2.80/day)
Jyväskylä, Finland
What I mean is that if those people would upgrade those HDDs to SSDs, this case would have space for those.
41,133 (6.56/day)
You may want to change the title to mid towrr case...
7,762 (2.90/day)
Back in Norway
System Name Hotbox
Mouse Logitech G603
Sure. Still, unless these people either don't have expanding storage needs (which would be strange - doesn't everyone?), or suddenly win the lottery, that seems like it'd be a multi-year process at best. People who fill their cases with HDDs do so for the storage space, and ... well, let's say you have three aging 2TB HDDs in a RAID 5 setup. You could replace those with two RAID 1 SATA SSDs and still gain performance, so let's say you do that. Or, to avoid the premium for >1TB SSDs, go for four 1TB SSDs in RAID 10. Picking the cheapest 1TB-class SATA SSDs off Newegg (currently the Team Group L5 Lite), that's still $880 worth of SSDs. For that money, you could instead upgrade your existing RAID 5 with 8TB drives and still have almost $300 left over. The more drives or higher capacity drives you have, the bigger the difference gets. Either way, while I get that some people would appreciate the opportunity to install 12 SSDs, I seriously doubt more than a handful of people in the world would want that and simultaneously be in the market for a case like this. Of course, there might be a subculture of millionaire data hoarders that I'm unaware of, but then I'd argue that those people can afford to splurge on a couple of extra brackets, and TT would avoid shipping hundreds or thousands of unnecessary brackets that end up in landfills. To me, that's a more reasonable approach.
5,606 (0.79/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Logitech G613
Man, Thermaltake has gone from 2000s ugly bling masters to designing tasteful and well-thought-out chassis in 2018. This one is quite a stunner, although I question the "gull wing" design that precludes mounting a top radiator or fans. Well, I'm sure reviews will tell us whether or not that's a downside.
Each tray can mount 2x 2.5" or 1x 3.5" drive: http://www.thermaltake.com/db/products/case/View37Riing/pic8.gif
7,762 (2.90/day)
Back in Norway
System Name Hotbox
Mouse Logitech G603
So those three-windowed brackets only fit two drives each? Ah, I see. I suppose I ought to have checked, I just assumed they followed the sorta-standard design convention of "1 opening per drive" that most brackets like that have. I suppose that makes the design a tad more sensible (especially as it makes the brackets a lot smaller!) - three HDDs and two SSDs (for example) sure makes more sense than 12 2.5" SSDs :p
4,297 (0.87/day)
Just because a manufacturer has made provisions doesnt mean you have to populate all the available feature. Do watch hardwarecanuks review it help you get a clear idea of HDD cages.
1,977 (0.33/day)
Processor RyZen R9 3950X
Video Card(s) RTX 3050
Storage Samsung 2TB SSD
Case Zulman MS800
Audio Device(s) On Board
Power Supply Seasonic 650W
Software Windows 11 64bit
Nice but the cutout at the top will compromise the rigidity of the case. So it should flex like a mother F@#ker. Also there is no ventilation at the top. Its all looks and no substance.
1,162 (0.21/day)
Chicago, Illinois
Is it a race car? Why does the chassis have to be rigid? Are you going to sit on it?
5,606 (0.79/day)
Ikenai borderline!
Remember that those brackets are able to mount 3.5" drives, and the only way to attach drives to them is via the drive bottom, and 3.5" drive bottom screw holes are kinda 1/3 down each end of the drive, so from that viewpoint it makes total sense.
Here's a kinda-sorta review of the RGB model:
Sadly the guy doesn't do any rigorous testing, but I do think that his claim that the front airflow will be restricted is likely. I do wonder how things would work if the fans are mounted on the right side panel (the radiator mounting) which is much less restrictive. Personally if I got this case, I wouldn't even bother with fans on the front, I'd just do a push/pull rad on the side.
Oh, and the "gull wing" acrylic is cheap and nasty, as expected. IMO they should've done 2 versions of this case, one with a standard metal panel with fan mounting options for the gull wing, and another more expensive one using tempered glass.
