Thin or thick Aluminum fins are better?
237 (0.45/day)
Motherboard ASUS Prime X670E-Pro WIFI
Cooling Noctua NH-D15S
Memory Kingston FURY Beast 2x16GB 6000MHz CL36
Video Card(s) Gainward RTX 2070 Super
Storage Samsung 990 Pro 2TB, Samsung 990 Pro 4TB, Samsung 970 EVO Plus 2TB, Lexar NM790 4TB
Case Fractal Design Meshify 2
Power Supply Corsair HX1000i ATX 3.1
I'm wondering which one would be better, a Aluminum heat sink with 1mm base and 1mm fins, 3mm base and 1mm fins or 3mm base and 3mm fins?
18,584 (2.66/day)
System Name AlderLake
Thin fins, so there is more surface to cool.
3mm base and 1mm fins.
What are you trying to cool?
1,482 (0.95/day)
Tel Fyr
Active or passive cooling makes a difference as well. Wider gaps for passive.
237 (0.45/day)
I'm planning to do some diy motherboard(vrm, chipset) and gpu (vrm,vram) cooling. I have some s478 coolers that have thicker base or use something like this https://www.ampul.eu/en/coolers/4466-aluminum-heat-sink-60x31x12mm-with-hot-melt-adhesi
Maybe I could repurpose a MC1 Pro, would the heatpipe compensate for the lack of fins?
Mobo chipset doesnt get a lot of airflow, it sits at 68-70 celsius idle.
Lei
1,143 (0.87/day)
usually in my shirt
Processor 3900x - Bykski waterblock
Motherboard MSI b450m mortar max BIOS Date 27 Apr 2023
Cooling αcool 560 rad - 2xPhanteks F140XP
Memory Micron 32gb 3200mhz ddr4
Video Card(s) Colorful 3090 ADOC active backplate cooling
Storage WD SN850 2tb ,HP EX950 1tb, WD UltraStar Helioseal 18tb+18tb
Display(s) 24“ HUION pro 4k 10bit
Case aluminium extrusions copper panels, 60 deliveries for every piece down to screws
Audio Device(s) sony stereo mic, logitech c930, Gulikit pro 2 + xbox Series S controller, moded bt headphone 1200mAh
Power Supply Corsair RM1000x
Mouse pen display, no mouse no click
Keyboard Microsoft aio media embedded touchpad (moded lithium battery 1000mAh)
Software Win 11 23h2 build 22631
Benchmark Scores cine23 20000
2,898 (0.57/day)
If the cooler gets any air you want thinner fins (1 mm base, 3 mm fins), as the increased surface area is going to transfer heat to the surrounding environment.
If the cooler is entirely passive you want thicker and triangular fins (3 mm, 3 mm). The former to add thermal mass and the later to promote convection currents to improve performance. Don't expect miracles. Convection in such a situation is small...so you're looking at thermal mass to try and create the desired temperature equilibrium.
Your stated goal is to cool the chipset though...so this isn't going to perform any miracles without airflow. If you've already got that, then the answer is that there's not a lot to in here. You don't list a computer...so my guess is only that this is fine. Some chipsets do run hot...but that's way cooler than your average thermal max for a CPU.
9,916 (1.82/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
the thick base would eat the heat more and thinner fins would release the heat more
14,233 (6.41/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
This.
Thick fins have higher heat capacity, that is, they are slower to warm up or cool down. Thinner fins can create more surface area to conduct the heat, as they require less space. You can't say one is better than the other. It really depends on the application. My logic would say that short, bursty heat loads would work better with thicker fins, while prolonged heat is better conducted by more, but thinner fins and/or active cooling.
525 (0.13/day)
This.
^ In an average,3mmx3mm would have the most cooling potential because of the total surface area and mass.
18,584 (2.66/day)
Just don't use stainless/steel for heatsinks lol...
3,479 (1.11/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
It's a common assumption that copper is a better material for heatsink fins due to it's higher thermal conductivity but copper's effusivity is lower than that of Aluminum. Copper is better at carrying heat away but it's inferior at dissipating it, hence why aluminum is used for heatsink fins.
In regards to the OP's question, thin dense fins are better for active cooling while thick more sparsely populated fins are better for passive. A thicker base allows the sink to more easily absorb temperature spikes and is recommended for passive cooling.
freeagent
9,682 (4.14/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
My Le Grand Macho RT has thick fins for passive use, but it also responds well to a high speed fan. All of my TR coolers can be used semi passively with my current hardware.
237 (0.45/day)
One of them is a Gigabyte 970A-UD3 where the Northbridge runs at 68-70 celsius and gets even hotter when doing demanding stuff, its sandwiched between the tower cooler and gpu, I did try using a 40mm fan, but it's too noisy for my liking.
The other board is a Asrock H610M-HDV that I plan to put in a small 20*20*7cm box and would like to cool the vrm, thinking about putting a MC1 Pro on it so that the heatpipes are on the sides.
18,584 (2.66/day)
Lei
1,143 (0.87/day)
usually in my shirt
Thanks:love:
I always love to stay hungry, stay foolish. Link :D
May be if vrams are close to pcb giant heatsink, can connect them with thermal tapes.
9,669 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
For low power passive use case the thicker fins might be of better use.
5,298 (3.73/day)
Colorado, U.S.A.
Software Windows 11 Home
That link claims
"Copper is better at conducting heat than aluminum, but aluminum is able to radiate the heat into the air better than copper because of its lower density."
I beg to differ; how does low density help?
  • Like
Reactions: Lei
3,944 (0.60/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
Use stainless steel often for heat exchangers when corrosion and or long life is an issue. Copper good but erodes faster with 400L/min raw river water flowing through it.
As for the OP
If the motherboard will be vertical make sure the fins are perpendicular to the ground so rising air can move through easily. Personally I would use a pin fin heat sink for this application, but whatever floats your boat.
I used to have a block like this but about 3-4mm thick base and 50mm tall pins and it worked really good for that.
Lei
1,143 (0.87/day)
usually in my shirt
That link claims
This doesn't answer your query, but makes me suck my thumb while reading it:
Hmm, let's put a paper on our vram and bury that under soil. Excellent surface heat emissivity :peace:
Look, magnesium is less dense than both Cu and Al.
237 (0.45/day)
Some good effective heatsinks for that:
I used this one with a fan, my dad got this system and still using it.
Or a thermaltake one, also had this one the southbridge:
I would put a tower cooler on it, but there isn't any clearance
I would really like to put a tower cooler on it, but there's no room for it
