This is a thing. Liquid cooling, without any chance of mess..
27,441 (6.62/day)
Linus over at LTT demo'd a new take on vapor-chamber/heatpipe cooling;
Question is, what do you all think?
I think it might just be the future of high-end cooling. This video showed impressive potential of the tech.
2,141 (1.12/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
its pretty cool tech and impressive , but its a bit chunky and the way its positioned currently messes up the airflow inside the case.
hat
Enthusiast
21,745 (3.31/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
I'm... not so impressed given the size of that thing.
10,690 (1.72/day)
Austin Texas
System Name Planet Espresso
Processor 13700KF @ 5.5GHZ 1.285v - 235W cap
Motherboard MSI 690-I PRO
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Mouse Xlite V2
Keyboard 65% HE Keyboard
At the end of the day whether we are displacing the surface area with water or a more efficient transport, you will still need the surface area; even if it's a bit less / less bulky.
Very impressive for sure, but I think water's flexibility of where to put that surface area (such as an intake at the bottom of the case etc.) and the fact that this has to sit on the socket like that is going to be it's Achille's heel.
Who knows though, they might put some blingy RGB on there and it becomes the next great thing.
hat
Enthusiast
21,745 (3.31/day)
Ohio
Yeah, that's gonna be a lot of weight hanging on the board for sure.
silentbogo
5,538 (1.38/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 3800X
Memory 4x8GB Samsung DDR4 ECC UDIMM
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
A little correction: it's not liquid cooling, it's basically a looped heatpipe.
Was watching that last night. The idea is very interesting, results are even more interesting, but I'm not sure that kind of weight and size is healthy for the socket and PCB itself. Maybe in horizontal orientation, but I would'n risk using that thing vertically long-term.
What's cool, is that the price is actually not too bad for such exotic cooling solution. It's even cheaper than TEC coolers, and has nearly double heat dispersion capacity.
5,469 (1.05/day)
Not impressed at all.
Not by size, not by performance, not by both with ultra-high RPM delta fans screaming in the background.
I would like to see such concept operating with 1 fan on decent RPM with half the size and half the thickness compered to similarly sized existing air coolers.
Then we can talk.
4,841 (1.54/day)
Processor Core i7-13700
Cooling Cooler Master RGB something
Memory Corsair DDR5-6000 small OC to 6200
Storage 970 EVO NVMe M.2 500GB,,WD850N 2TB
Case Phantek Eclipse P400S
Audio Device(s) EVGA NU Audio
Power Supply EVGA 850 BQ
Software Windows 11 Professional v23H2
Impressive for being all aluminum prototype, and as Linus suggested a bit of copper could knock temperatures back another 5-10°C. The final product is set to be smaller without compromising the coolers performance. Linus also said this type of cooler could run passive on a lower watt CPU.
10,690 (1.72/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
Mouse Xlite V2
The weight might be an issue there...
22,317 (6.03/day)
Well... lots of IFS but about weight and bulkiness... let's not forget we also mount NH-D15S to the CPU and its easily as big, chunky and the only difference is the airflow obstruction. This you would solve easily by going for a bottom > top flow case setup though, seeing as the IceGiant also is bottom>top.
In todays age of very hot CPUs I think this could be a pretty decent product. Yes, it can do with some more sexy. But the concept is nice. I like it most because its not a complex and prone to maintenance solution like WC.
10,690 (1.72/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
Mouse Xlite V2
It honestly looks like an evolution of the heatpipe. I can't see why this couldnt be implemented into the noctua pipe/fin design.
Im sure we will be seeing this heatpipe tech but not this particular cooler.
^ there is the cooler master prototype.
2,248 (1.03/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. i7 7700k @5. 3. i7 7700hq
Motherboard 1.aorus x570 ultra 2. z270 Maximus IX Hero,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.hyperxfury 32gb @3000 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 500gb , 2 3tb HDs 2. 256gb ssd, 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. some cheapo case that should not be named.
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847 2. 1106 cb 3.cb 970
na not for me, I like loads of messy pipes around my rig and like living on the edge at my age I like the excitement. interested at seeing the finished product tho.
570 (0.26/day)
PL, Krk (JPN, Tokyo)
System Name Nilin
Processor Ryzen 9 5800x
Motherboard Asus Rog Crosshair VIII Hero Wifi
Cooling Lian Li Galahad AIO 360
Memory G. Skill TridentZ Neo 32gb 3600Mhz CL16-16-16-36
Video Card(s) Asus TUF RTX 3080
Storage Samsung Evo 960 250gb (System), Samsung Evo 860 500gb (Misc), ADATA SX8200PNP (Games)
Display(s) LG 27" UHD IPS, LG Ultragear 27" WQHD Nano IPS
Case InWin 303 (7x Fractal Prisma 120mm)
Power Supply Tt Toughpower Grand RGB 850W
Mouse Razer Viper Ultimate
Keyboard SteelSeries Apex 3
Benchmark Scores https://www.3dmark.com/fs/21022952 (old system)
its quite cool (no pun intended) looking forward to finished product :)
8,987 (3.31/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Did not Deepcool make a claim to no mess with their new Captain series AIOs that come with a bleed valve? I also could have sworn I saw something akin to this with my Sapphire 7950 Vapor-X and I am sure there was a Cooler Master Air cooler that had this concept as well. I might be mistaken though.
Deleted member 185158
Its as good as a low end AIO water cooler and he claims water cooling is dead with click bait video title.
Temps within 2c margin of error.
How does this kid in the video think liquid cooling is dead?
Click bait garbage cooler. Not even slightly impressive.
19,371 (3.57/day)
Shrimp, meet Linus... Linus... Shrimp.
LTT is garbage. Videos for the unadorned masses (fitting for here I suppose!). :)
EDIT: I find this to be more 'the future of high-end cooling' than what is in the OP - https://www.hardwareluxx.de/index.p...mmetrischen-aufbau-fuer-bessere-kuehlung.html
FreedomEclipse
~Technological Technocrat~
24,001 (3.74/day)
London,UK
System Name DarnGosh Edition
Processor AMD 7800X3D
Memory G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
People seem to glaze over the fact that this product is currently a prototype. It is subject to change as they refine and tweak the product.
Do you moaners go into early access alpha or beta games and bitch about how the game is buggy and broken as hell it is despite it not being a final release??
Its a proof of concept that it can work. The real work on refining the design starts now.
FreedomEclipse
24,001 (3.74/day)
London,UK
Lol like vapor cooler is new....
Oh anything with heat pipes = vapor cooler.
Prototype with numbers. That means its in working order and close to finished product.
And not complaining, just telling the truth.
FreedomEclipse
24,001 (3.74/day)
London,UK
So by your train of thought, companies arent allowed to test their prototypes?
as for your vapor cooler argument you have a point but its not as simple or straightforward as traditional/current coolers with heatpipes as these heatpipes complete a full loop.
1,264 (0.29/day)
Motherboard MXI APEX
Storage 660P 1TB, 860 QVO 2TB
Case Open Benchtable V2
Audio Device(s) SB X-Fi
Power Supply MSI A1000G
Mouse G502
Keyboard G815
Software Gentoo/Windows 10
There is a reason why serious water cooling enthusiasts exhaust heat from radiators outside the system case.
41,899 (6.61/day)
Better make support brackets for it.
Better on a desktop pc, not a tower
