- Oct 17, 2014
- 16,671 (4.70/day)
- Kepler-186f
poll
System Name | Pioneer |
Processor | Ryzen R9 7950X |
Motherboard | GIGABYTE Aorus Elite X670 AX |
Cooling | Noctua NH-D15 + A whole lotta Sunon and Corsair Maglev blower fans... |
Memory | 64GB (4x 16GB) G.Skill Flare X5 @ DDR5-6000 CL30 |
Video Card(s) | XFX RX 7900 XTX Speedster Merc 310 |
Storage | Intel 905p Optane 960GB boot, +2x Crucial P5 Plus 2TB PCIe 4.0 NVMe SSDs |
Display(s) | 55" LG 55" B9 OLED 4K Display |
Case | Thermaltake Core X31 |
Audio Device(s) | TOSLINK->Schiit Modi MB->Asgard 2 DAC Amp->AKG Pro K712 Headphones or HDMI->B9 OLED |
Power Supply | FSP Hydro Ti Pro 850W |
Mouse | Logitech G305 Lightspeed Wireless |
Keyboard | WASD Code v3 with Cherry Green keyswitches + PBT DS keycaps |
Software | Gentoo Linux x64 / Windows 11 Enterprise IoT 2024 |
Not I, said the frog.
Copper heatsinks need not apply, though. NIckel-plated only.
System Name | MONEY PIT |
Processor | i7-3770K @ 4800 1.20v batch #3231B415 Delided |
Motherboard | ASrock Z77 OC Formula w onboard waterblocks |
Cooling | Apogee HD, MCP655,rad MCR320-XP,Micro Rev2 res |
Memory | G,skill Trident X F3-2400C10D-16GTX |
Video Card(s) | EVGA GTX 980 Ti Classified with EK nickel/acetal waterblock installed |
Storage | 2x120gig Wildfire raid0 2x120gig VERTEX3 raid0 |
Display(s) | 3/ Samsung2343bwx + 65in LG 4K |
Case | NZXT Phantom White w/red |
Audio Device(s) | ReCon3d fatal1ty pro, Logitech z906 THX |
Power Supply | corsair AX860i |
Mouse | Rat7 |
Software | 64bit ++++ win 10 |
System Name | Box of Distraction |
Processor | Ryzen 7 1800X |
Motherboard | Crosshair VI Hero |
Cooling | Custom watercooling |
Memory | G.Skill TridentZ 2x8GB @ 3466MHz CL14 1T |
Video Card(s) | EVGA 1080Ti FE. WC'd & TDP limit increased to 360W. |
Storage | Samsung 960 Evo 500GB & WD Black 2TB storage drive. |
Display(s) | Asus ROG Swift PG278QR 27" 1440P 165hz Gsync |
Case | Phanteks Enthoo Pro M |
Audio Device(s) | Phillips Fidelio X2 headphones / basic Bose speakers |
Power Supply | EVGA Supernova 750W G3 |
Mouse | Logitech G602 |
Keyboard | Cherry MX Board 6.0 (mx red switches) |
Software | Win 10 & Linux Mint |
Benchmark Scores | https://hwbot.org/user/infrared |
The wisdom of the frog as spoken.Not I, said the frog.
System Name | Brightworks Systems BWS-6 E-IV |
Processor | Intel Core i5-6600 @ 3.9GHz |
Motherboard | Gigabyte GA-Z170-HD3 Rev 1.0 |
Cooling | Quality case, 2 x Fractal Design 140mm fans, stock CPU HSF |
Memory | 32GB (4 x 8GB) DDR4 3000 Corsair Vengeance |
Video Card(s) | EVGA GEForce GTX 1050Ti 4Gb GDDR5 |
Storage | Samsung 850 Pro 256GB SSD, Samsung 860 Evo 500GB SSD |
Display(s) | Samsung S24E650BW LED x 2 |
Case | Fractal Design Define R4 |
Power Supply | EVGA Supernova 550W G2 Gold |
Mouse | Logitech M190 |
Keyboard | Microsoft Wireless Comfort 5050 |
Software | W10 Pro 64-bit |
Processor | 13700KF Undervolted @ 5.6/ 5.5, 4.8Ghz Ring 200W PL1 |
Motherboard | MSI 690-I PRO |
Cooling | Thermalright Peerless Assassin 120 w/ Arctic P12 Fans |
Memory | 48 GB DDR5 7600 MHZ CL36 |
Video Card(s) | RTX 4090 FE |
Storage | 2x 2TB WDC SN850, 1TB Samsung 960 prr |
Display(s) | Alienware 32" 4k 240hz OLED |
Case | SLIGER S620 |
Audio Device(s) | Yes |
Power Supply | Corsair SF750 |
Mouse | Xlite V2 |
Keyboard | RoyalAxe |
Software | Windows 11 |
Benchmark Scores | They're pretty good, nothing crazy. |
That's the bond I was talking about - and that's with any TIM - not just liquid metal.it depends on whether or not the seal breaks with liquid metal.
If there are gaps that allow insulating air in, that's a problem and the old TIM definitely need to be thoroughly cleaned from the mating surfaces and a fresh new layer needs to be properly applied.for the LM to dry and become brittle.
Mouse | Xlite V2 |
But if TIM dries, that is not a problem - contrary to what many believe. It is important to note TIM comes in a liquid form only so it can be squeezed out of the tube and spread evenly across the die. If the TIM dries out, the solids that remain behind are still there doing their jobs - filling the microscopic pits and valleys in the mating surfaces. TIM does not need to be replaced because it dries out. It only needs to be replaced if the cured bond is broken.
that's correct except in the case of liquid metal, specifically, the bond is extremely fragile, and it oxidizes when exposed to air.
It is common with all TIMs to decrease in efficiency a few degrees over time but it should never be enough that it puts you dangerously close to thermal thresholds. That is, if you "need" those extra few degrees to keep from throttling back in speeds or reaching some other thermal protection threshold, you have other more important cooling issues to deal with, like a broken bond on your heatsink or inadequate case cooling. The point is, TIM never needs to be replaced because it is x number of years old AS LONG AS the bond between the CPU and heatsink is not broken.
Remember, there is NOT ONE, not a single solitary TIM maker, cooler maker, processor maker, motherboard maker, graphics card maker, or computer maker that says the TIM needs to be replaced on any regular or scheduled bases. Not one!
If it was needed, at least the TIM makers would recommend regular replacement as that would significantly increase their sales profits.
Which would only happen if the bond is broken.
What question? As I said, all TIMs degrade in efficiency over time. The question was NOT about dissimilar metals reacting with each other.Liquid metal is far from a typical TIM though. Chemically, the question is valid. It certainly reacts to a limited extent with copper, and if you put it on Aluminun heatsinks, god help you.
So what? They are still there doing their jobs - taking up the space so insulating air can't get in.It is here because it becomes loose metallic crystals.
It is not. Please read the title of the thread.It is. We're talking about liquid gallium based product mixtures.
Well of course loose shards of metal are not desirable. But those have absolutletly nothing to do with TIM (LM or not) that was properly applied in the first place and where the cured "bond" (or whatever you want to call it) is not broken. Beyond that, it just seems you want to drive this thread OT (which is about temps increasing over time) just for the sake of arguing. So I'm stepping out.They are loose shards of metal in a PC. I speak from experience that this is not desirable.
Are there non-gallium based LM TIM's? I wasn't aware there were any..Liquid metal TIMs are fairly new to market.
That's what I thought. No one would be crazy enough to use an amalgam of Mercury and I can't think of any other metals that would be both good conductors of heat and liquid at room temp, regardless of alloy/amalgam composition.There aren't. Some use Indium additives in different percentages, but they all are liquid Gallium at the core.
So what? It changes nothing. READ THE TITLE TO THE THREAD! Let me repeat it just for you, R-T-B,Liquid metal TIMs are fairly new to market.
It does not matter if liquid metal or not. I will say it again, all TIMs decrease in efficiency a few degrees over time. That does not mean it needs to be replaced.did your temps increase after 2 years?
Huh? Not hardly - fairly new would be last 2 - 3 maybe 4 years. LM TIMs have been around for at least 8 years that I know of. So fairly new to you maybe, but not me.are fairly new to market
So you are arguing for nothing.
It's not just rumor either, basic chemistry can explain it.
