xDregon25x
- Mar 12, 2022
- 3 (0.00/day)
Hey together,
i have used Throttlestop for a long time now and what i found out is that my CPU (Intel I5 10600T) is never hitting 4Ghz, even with 1 Core.
It is stuck at 3,56Ghz max with all Cores and i feel the Lag when i do some heavy workloads.
The thing is that if i install Windows on another Partition it goes as high as 4Ghz again, i think that Throttlestop messed up some CPU configs as i hit 4Ghz before i installed it.
(Deleting the .ini File does not Solve the Problem)
Does anyone have some advices or do i need to reinstsall Windows to get this sorted out
Edit: Trying out different Power Saving Profiles does not fix this issue
