I have this AORUS 15P XD laptop that pre-maturely throttles at around 80 degrees Celsiusor so and I can't change this throttlestop without getting a cracked BIOS version since a lot of voltage settings and such are completely locked.
C1E supposedly saves power by turning turbo boost off automatically when it is not being used, which is turn should reduce temperature.
I'm wondering if this might have any effect on pre-mature throttle and if I want to get the most performance I can before my CPU throttles, should I turn this C1E option on or off?
I'm thinking turning it off will help reduce temperatures and thus allow longer sustained performance, but turning it on may help to keep the core clock speeds higher before throttling?
