Hi everyone!
I've recently used Throttlestop and i've a small problem. I've had a Undervolt and put some limits to my cpu for fight my high temperatures and all was and it is great: also because i playing only at fortnite maybe but i have 70/74 degrees and it's perfect considering the 90/94 degrees at the start..... (Ah, sorry, MSI GF65 Thin 10ser 1253 IT, i5 10300H, Rtx 2060, 16 gb).
Yesterday i saw a very strange usage of tdp level. In fact as you can see in the image the tdp is limited at 25 W instead of 45 W (as it can be ad it has been until yesterday). Ad obviously the CPU dosen't reach the maximum frequency beacause the red advise "POWER" appears near "prochot 95 C".
I hadn't modify anything in the settings, how it is possible? (When i also open the window of tdp settings if i modify the tdp level with the value of 45 instantly changes in "1" and is it not editable. How can i fix it?
EDIT: This evening i've seen that the CPU dosen't reach the maximun frequency, and use 25W, also when TS is not activated and only when i started Fortnite (if, for example i play the CPU bench the CPU reach 45 W of tdp as it can be....) How is it possible? The problem persist only with fortnite! Epic games limited the CPU power.... i don't absolutely know why
Thank you very much in advance
