ThrottleStop problem
3 (0.01/day)
System Name acer nitro 5
Processor i5 9300h
Motherboard acer
Cooling laptop fans + cooling pad
Memory 24gb 3200 mhz
Video Card(s) gtx 1660ti mobile
Storage 1tb hdd + 512 gb ssd
Display(s) 120 hz
Case nitro 5
Audio Device(s) realtek + steelseries nova 1
Power Supply 180w laptop adapter
Mouse steelseries rival 710
Keyboard steelseries apex 7
on ThrottleStop stop ı can go no limited core underwolt like -1000 and no errors on ts benc cpu-z benchmark but my temps never changed?????
unclewebb
8,154 (1.33/day)
The core and the cache voltages are synced internally within the CPU. The maximum difference is about 100 mV.
-150 mV cache and -250 mV core is OK
Any increases to only the core beyond that will be ignored by the CPU.
Using different voltages works well when using apps that use a lot of AVX instructions in the processor. Cinebench is the best program when testing different voltages. If you do not see any improvement in performance or temperatures when using different voltages then you might as well set the core and cache offset voltages equally.
Set IccMax for the core and the cache to the max, 255.75.
50.00 Amps is kind of cheap.
Try to improve your cooling so you can run your CPU at its full rated speed.
3 (0.01/day)
Processor i5 9300h
Motherboard acer
Display(s) 120 hz
Case nitro 5
how can ı improve cooling ı repasted ? and on -250mV when ı try higher clocks there is errrors on benchmark if ı lower the mV its gets hot
unclewebb
8,154 (1.33/day)
What paste did you use? How did you apply it?
Always use enough voltage so there are zero errors in the TS Bench test or any other test.
Some enthusiasts physically modify their laptop cases to improve cooling. Some find ways to increase the contact pressure between the heatsink and CPU. Some use liquid metal. There are lots of tricks possible. Search Google to learn more. I am always amazed at what ideas some users come up with.
3 (0.01/day)
Processor i5 9300h
Motherboard acer
Display(s) 120 hz
Case nitro 5
ı used coolermaster cryofuze 14 kmv version and that 2019 nitro 5 needs fan on cpu the 2 fans are too far from cpu cooling system focused on gpu ı think . ty unchle :love:
and if ı change thermal pads and pink paste on vrams did it can help to lower temp is it worth ?
