Tried installing 576.02 - installer window disappears
5 (0.00/day)
I'm on W10 22H2, got latest NVCleanstall 1.18.0.0.
It's the first time I have such an issue. I even tried compiling the installer instead of installing directly. NV installer checks compatibility and disappears.
Any ideas on what should I do?
4 (0.00/day)
Mine says "required files missing" once nvidia's installer starts.
Apparently NVApp is the culprit, putting it in driver directory is all that's needed.
Tav0
1 (0.11/day)
I think you checked unattended install, because if you dont, the installer shows you a message like "files missing, cant continue" and doesnt let you advance.. must be an error with NVCleaninstall.. will have to wait.
8 (0.00/day)
I'm seeing the installer window on Windows 11 24H2, but it tells me it's missing required files. This is on the minimum preset and no additional options selected.
43 (0.01/day)
System Name CyberDyne Systems
Processor AMD 7800X3D
Motherboard Asus ROG STRIX B650E-E Wifi
Cooling Alphacool Eisbaer Aurora HPE 360 mm
Memory 32 GB G Skill Flare X5 F5-6000J3038F16GX2-FX5
Video Card(s) Nvidia 4090FE
Storage WD Black SN850X 1 TB, WD Black SN850X HS 2 TB, WD Black SN770 2 TB
Display(s) Alienware AW3821DW 3840x1600 144 Hz
Case ThermalTake Core P3 TG Pro
Audio Device(s) Onboard Realtek ALC4080 Corsair SP2500
Power Supply Asus Thor II 1000W
Mouse Logitech G502 X
Keyboard Corsair K65 LUX RGB
Software Win11 Pro
Can confirm this. Here also also failing.
1,029 (0.29/day)
Nova Scotia, Canada
Cooling Cooler Master Hyper 212 Plus
Memory 32GB 4x8 G.SKILL Trident Z 3200 CL14 1.35V
Video Card(s) PCWINMAX RTX 3060 6GB Laptop GPU (80W)
Storage 1TB Kingston NV2
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 11 Pro 64-Bit
It installed for me using "Use driver files on disk" after downloading the driver from Nvidia's site. Got a couple error windows at the end but it doesn't seem to matter.
mellow
1 (0.11/day)
Can confirm this works. Don't download driver from NVClean, download from Nvidia directly and it will work like normal
jaybeee
5 (0.04/day)
So... you installed the official driver? Or am I misunderstanding something?
Nvm, I found the answer in another thread.
Is NVApp a folder or a file? Where can I find it? And which is the driver directory? In Program Files?
37 (0.02/day)
- Try installing some drivers from one year ago and see if it working
- If the problem persists just downgrade the Operating System i.e. W7/8.1/W10
Aphix
8 (0.06/day)
FWIW the NVENC patch needs an update to work with this version (often the previous patch version works fine), but fortunately it looks like there's a pull request in the main repo waiting to get merged.
Link to issue in NVENC patch repo (+ PR linked near bottom): https://github.com/keylase/nvidia-patch/issues/925
Screenshot of issue:
In the meantime, just skip the NVENC patch, or wait for it to be merged before upgrading the driver.
edcbabe
1 (0.11/day)
Japan
System Name Intel 12th Gen - NVidia RTX4060
Processor 12th Gen Intel(R) Core(TM) i5-12500 3.00 GHz
Motherboard MSI PRO H610M-G DDR4
Cooling Thermalright Assassin 120 ARGB
Memory 32GB (16GBx2) DDR4 3200Mhz WINTEN
Video Card(s) MSI VENTUS RTX4060
Storage SSD 1TB m.2 NVME CFD
Display(s) I-O DATA GigaCrysta 144Hz 24 Inch LCD
Case DEEPCOOL MACUBE 110
Audio Device(s) RealTek Audio with Dolby Atmos for Headphone and DTS Headphone:X Audio Enhancements
Power Supply Cougar VTC 600W
Mouse Razer DeathAdder Essential
Keyboard Lenovo Legion K500 RGB
Software Windows 11 24H2
Benchmark Scores Final Fantasy XIV: Endwalker : 16063 1080p DX11 Resident Evil 6: 16006 160FPS 1080p DX9.0c
I summarized current workaround for Nvidia Graphics Driver 576.02
1. Download the latest NVidia Driver here: https://www.techpowerup.com/download/nvidia-geforce-graphics-drivers/
2. "Use driver files on disk" and select the NVidia Driver you just donwloaded.
3. Uncheck "Apply NVENC Video Encoding Session Limit Patch" and proceed as usual.
Finished installation without error. Enjoy your day!
4 (0.00/day)
NVApp is a folder you can find by downloading newest drivers directly from NVidia's website and extracting with e.g. WinRar.
DadSaysImCool
1 (0.00/day)
2 (0.00/day)
I tried the 'workaround' however I found it's not actually a workaround. Yes it'll install the driver for you, but it won't follow your preferences at all. I did a clean install, selected MSI mode, disabled HDCP, disabled Type-C port driver, but alas:
So just an FYI the workaround is akin to just installing the nvidia driver without NVCleanstall :/
jaybeee
5 (0.04/day)
A bit off-topic:
Is the "Apply NVENC Video Encoding Session Limit Patch" option in the installer recommended to enable? I know it currently is broken, but I haven't been using it anyway. Should I enable it when it becomes functional again?
Mindweaver
Moderato®™
8,438 (1.44/day)
Charleston, SC
System Name Tower of Power / Delliverance
Processor i7 14700K / i9-14900K
Motherboard ASUS ROG Strix Z790-A Gaming WiFi II / Z690
Cooling CM MasterLiquid ML360 Mirror ARGB Close-Loop AIO / Air
Memory CORSAIR - VENGEANCE RGB 32GB (2x16GB) DDR5 7200MHz / DDR5 2x 16gb
Video Card(s) ASUS TUF Gaming GeForce RTX 4070 Ti / GeForce RTX 4080
Storage 4x Samsung 980 Pro 1TB M.2, 2x Crucial 1TB SSD / NVM3 PC801 SK hynix 1TB
Display(s) Samsung 32" Odyssy G5 Gaming 144hz 1440p, 2x LG HDR 32" 60hz 4k / 2x LG HDR 32" 60hz 4k
Case Phantek "400A" / Dell XPS 8960
Audio Device(s) Realtek ALC4080 / Sound Blaster X1
Power Supply Corsair RM Series RM750 / 750w
Mouse Razer Deathadder V3 Hyperspeed Wireless / Glorious Gaming Model O 2 Wireless
Keyboard Glorious GMMK with box-white switches / Keychron K6 pro with blue swithes
VR HMD Quest 3 (512gb) + Rift S + HTC Vive + DK1
Software Windows 11 Pro x64 / Windows 11 Pro x64
Benchmark Scores Yes
272 (0.23/day)
Georgia, United States
System Name LMDESKTOPv2
Processor Intel i9 10850K
Motherboard ASRock Z590 PG Velocita
Cooling Arctic Liquid Freezer II 240 w/ Maintenance Kit
Memory Corsair Vengeance DDR4 3600 CL18 2x16
Video Card(s) RTX 3080 Ti FE
Storage Intel Optane 900p 280GB, 1TB WD Blue SSD, 2TB Team Vulkan SSD, 2TB Seagate HDD, 4TB Team MP34 SSD
Display(s) HP Omen 27q, HP 25er
Case Fractal Design Meshify C Steel Panel
Audio Device(s) Sennheiser GSX 1000, Schiit Magni Heresy, Sennheiser HD560S
Power Supply Corsair HX850 V2
Mouse Logitech MX518 Legendary Edition
Keyboard Logitech G413 Carbon
VR HMD Oculus Quest 2 (w/ BOBO VR battery strap)
Software Win 10 Professional
A bit off-topic:
Unless you need it for something, I would just leave it disabled. Same thing with most of the tweaks in the list.
Aphix
8 (0.06/day)
A bit off-topic:
As far as my understanding goes, it's basically a limit that you'll only hit if you do a lot of parallel video encoding (and some ML image-gen stuff), and the patch basically unlocks a software-enforced lock that nvidia puts in place to get consumers to buy their higher-end GPUs for professional video-editing/video-processing. It's kinda similar to how some DSLR cameras have an arbitrary video-recording limit of 30 minutes to incentivize buying higher-end video cameras, which can also be bypassed/disabled using custom firmware on the camera.
29 (0.01/day)
