Troubleshooting Error 43 on My Graphics Card
DiieGUz
7 (0.08/day)
I am currently facing an issue with error 43 on my graphics card, which prevents me from accessing almost any application. I have tried several methods, such as uninstalling and reinstalling the drivers, and deleting everything related to AMD, but none of these solutions have worked for me.
Recently, I discovered that the problem might stem from my computer's BIOS, which seems to be modified for mining purposes. Because of this, I decided to flash the drivers on my computer. However, when attempting to replace the driver, I encountered a P/N mismatch error. I verified on the website that the driver I am trying to use is indeed for my specific graphics card, and it matches the one listed on this link:
https://www.techpowerup.com/vgabios/216636/asrock-rx5500xt-8192-191031.
From what I have read in forums, it is necessary to change the BIOS number, but this requires the PolarisBiosEditor application, which, as I understand, is not compatible with my graphics card: ASRock RX 5500 XT 8 GB (Challenger D).
If needed, I can provide a screenshot of my GPU information via GPU-Z. Additionally, I found a BIOS file with the same version as my current one. While the flash process worked, after restarting, the error 43 persisted. I am unsure if this is because the flashed BIOS file was the same version as the original.
43,676 (6.78/day)
Get sticker pics from the card please
DiieGUz
7 (0.08/day)
Thank you very much for the information; I will keep it in mind. Here is the photo of the sticker:
I followed the steps as outlined in the guide and was able to complete everything perfectly. It allowed me to set the BIOS, I restarted, but when I tried to log in again, the error 43 persisted.
43,676 (6.78/day)
Get a gou-z screenshot as well, also get a picture of a ram chip please
43,676 (6.78/day)
43,676 (6.78/day)
147 (0.03/day)
Israel
System Name 2024 Build
Processor AMD Ryzen 5 7600X
Motherboard ASUS Prime B650-Plus
Cooling Artic Freezer 36 A-RGD
Memory Corsair Vengeance RGB 2x16GB DDR5 6000MHz CL36
Video Card(s) Sapphire Radeon RX 7600 Pulse OC
Storage Samsung 990 Pro 2TB + Samsung 980 500GB + Transcend 230S SSD 512GB
Display(s) MSI G255F FHD 180Hz - FreeSync
Case Antec Three Hundred TWO - Optirec DVDRW AD-7280S
Power Supply Corsair RM650 650W 80 PLUS Gold
Mouse Logitech G502 X
Keyboard Logitech Prodigy G213 RGB
Software Win 11 Pro
No, take your graphics card a part and find a ram chip on it
mybe if the card post he can use hwinfo64 just to check that kind of ram it is?
i mean samsunf/hynix/micron branding
DiieGUz
7 (0.08/day)
Sorry, the truth is that I’m not very technical, and I find English a bit difficult. Is there another method? Because to open my graphics card, I need a different type of screwdriver, which I don’t have.
I’ll send you a photo of a series of codes that, honestly, I’m not sure if they’ll be helpful.
DiieGUz
7 (0.08/day)
here is a photo of hwinfo64:
43,676 (6.78/day)
Not when a bios has been changed and is reporting 0, 0
Yeah you will need to open the card unfortunately
DiieGUz
7 (0.08/day)
Oh, okay, I'll try to open it as soon as I can. From what I see, will I need to do reballing?
514 (2.81/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
No, the cooler will come off non-destructively, or you've done it wrong.
Here is a video that shows a card like yours coming apart. It is a fairly easy one to do. Looks like a small Phillips head is all that is required.
