- Oct 2, 2019
- 79 (0.04/day)
a friend gave me a 2070 today. turned out it had been dropped.
checking the photos from google the part that got broken off was not really a "essential" part of the pcb.
the card turns on. rtb turns on fans spin up then down during boot.
but no display. im using my 2070 super so i can check up on it.
shows up in gpu z but all the tick boxes besides opencdl are not checked.
i tried to download the vbios from it but it said "not supported"
frrom alot of trouble shooting it appears? that the card behaves the same if i plug in 2x6 pins as when i do 1x8 1x6. so maybe the sensing system? of the 8 pin is not working.
i checked but the sense pin of the 8 pin plug does connect to ground on the card.
if i check device manager sometimes no yellow question mark pops up. but it switched between either error 43 or error 31.
is there (maybe with a modded vbios) a way to disable the 8 pin check?
i know its "technically risky" but in scarce times as now its atleast better then nothing.
i tried booting ubuntu. and the card started displaying the boot screen but linux froze on something something journaled storage related (could tbh be my pc)
opun closer inspection with a group of people who work on pcb repair we found a single blown? up resistor on the 6 pin side of the card.
recommended me to desolder it since it had a direct short. the resistor according to them lead to a power cleaning circuit and it should not hurt the card if you have a good grade psu.
desoldering that lead to no change of behaviour.
i checked behaviour of leaving some of the pcie plugs unplugged and noticed the following
1x8 pin no 6 pin. rgb and fans turns on. no detection
no 8 pin with 6 pin leaves rgb on but no fans and no detection
2x6 pin instead of 1x8 1x6 lead to same behavior.
https://www.techpowerup.com/vgabios/204735/msi-rtx2070-8192-180925-1 this is the exact card in question.
anyone got any tips?
