Trying to play MKV movie file on VLC player android HELP
17,503 (4.65/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710 (Red/Black)
so I can get a mkv movie to play for like 3 minutes, then it starts freezing up... I am running stock android 7.1.1 on my zte axon 7 phone... and vlc player and nothing else tinkered with...
why won't it work? is there another video player that will work? vlc player seems to be fine on desktop windows 10 for the same files so its odd...
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
ive always had a bunch of issues with .mkv, they are balls. can you convert it, or acquire it in a different format? that may be your best bet. if no to both options, maybe if you can change the method of rendering used by vlc? maybe it isnt utilizing your GPU, or CPU properly
also, maybe this?
113 (0.02/day)
System Name littlet
Processor Ryzen 5900X
Motherboard TUF GAMING B550M-PLUS (WI-FI) ZAKU II EDITION
Cooling EK AIO Basic 240
Memory G.Skill Trident Z RGB 4X16GB 3200MHz
Video Card(s) RTX™ A2000 12GB
Storage C: WD_BLACK SN850 1TB
Display(s) ViewSonic VX3276-2K-mhd
Case ASUS Prime AP201
Audio Device(s) Asus Xonar Essence STX II
Power Supply Corsair SF 600
Software Windows
try mx player by j2 interactive
you'll have to put up with ads but not during playback
newtekie1
Semi-Retired Folder
28,473 (4.06/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
You can also try Kodi, it plays almost anything.
Mkv is just the wrapper, the codec is what is usually the issue. X265 video almost exclusively comes in mkv, and a lot of stuff struggles with x265. But a lot of mkv files are also h264, which is a lot easier to play.
17,503 (4.65/day)
Thanks everyone. I will try Kodi and MX2
Happy new year as well ^^
712 (0.21/day)
Croatia
Processor Ryzen 5 3600 PRO
Motherboard AsRock B450 Pro4
Cooling Thermalright Peerless Assassin 120
Memory Silicon Power XPower Zenith 2x8GB @3200 MHz
Video Card(s) Gigabyte RTX 2070 Super Gaming OC 8GB
Storage Crucial P5 Plus 1TB / Crucial MX 500 1TB
Display(s) Dell P2419H
Case Fractal Design Pop Air /w 3x Thermalright TL-C12C
Audio Device(s) Creative Sound Blaster Z + Edifier R1000T4
Power Supply Super Flower Leadex III 650W
Mouse Microsoft Intelimouse Pro
Keyboard IBM KB-8926
Benchmark Scores Turns on on the first try! Usually.
In VLC, go to Settings-Advanced-Enable frame skip. I had issues with some files, and those that lagged were fixed, others stayed the same quality.
