clauloporter
- Dec 5, 2024
- 1 (0.05/day)
Hello
I recently acquired a 360mm LFlll aio, and changed the original fans for three 120mm Phanteks T30. The temperatures and sound improved, however, the phanteks are generating turbulence, at all rpm. It is not the pump, since I have played with settings in fan control, and determined that the sound is coming from the fans. My case is the lian li 216, and I have the configuration like this:
Does anybody else have this problem? What can i do to fix it? can i put the fans on top of the radiator or the.temps will go worse?
