Typical power consumption for a DVD rewriter?
260 (0.06/day)
The Netherlands
Processor Intel Core i5 3570k
Motherboard MSI Z77 MPower
Cooling Thermalright Archon
Memory Crucial Ballistix Elite 2x4GB 1600MHz (8-8-8-24)
Video Card(s) MSI Geforce GTX 1060 6GB Gaming X
Storage Plextor M5 Pro 512GB; WD Caviar Green 2TB
Display(s) 2x HP ZR24w
Case Phanteks Enthoo Pro M Special Edition Tempered Glass
Power Supply Seasonic Focus GX-650
Mouse Logitech G403 HERO
Keyboard SteelSeries 7G
Software Windows 10 Pro 64-bit EN
Hi everyone,
I wanted to redo my cabling and I had the idea of connecting several devices to a Molex-to-4x-SATA cable (the Bitfenix Alchemy one). But since Molex only supplies up to 35W I was wondering whether this would work.
The 4 devices I wanted to connect:
2x 2TB Caviar Greens = 2x 5.3W peak | 2x 1.75 A
1x Crucial m4 64GB = 2.6W peak (according to Tom's Hardware measurements)
1x LG GH24NS90 = 2.0 A / 2.5 A (according to the sticker on the device)
I read somewhere that the typical peak power consumption of a DVD rewriter is around 20W. Does anyone know a more specific value? Since the margin to 35W is rather small in total. Or shouldn't I be worried?
12,062 (2.65/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
Hi everyone,
1.21 gigawatts.
I kid, 20watts MAX when burning data permanently. Usually around 16-18
AsRock
TPU addict
19,011 (3.01/day)
UK\USA
1.21 gigawatts.
But wouldn't 2.5A be around 30w although this would be the device's max usage and i bet it's rare it hits that kind of usage.
12,062 (2.65/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
If it actually pulled at 2.5A then maybe it would hit 30w. But i sincerely doubt it would. DVD drives are surprisingly efficient.
1,129 (0.20/day)
SCOTLAND!
System Name Machine XX
Processor Ryzen 7600
Cooling 120mm heatsink
Memory 32GB DDR5 6000 CL30
Video Card(s) RX5700XT 8Gb
Storage 280GB Optane 900p
Display(s) 19" + 23" + 17"
Case ATX
Power Supply 800W
i have never been a fan of molex connectors they burn up too easily. a sata> 4x sata adapter would probably be a better idea
260 (0.06/day)
The Netherlands
Thanks for the advice guys, so I would be better of not hooking them up to the same molex. Sadly that means more cables =(
Do you got a link for me to such an adapter/splitter cable? I know Bitfenix has none of those.
3,666 (0.87/day)
GMT +2
System Name Red Radiance l under construction
Processor 5800x
Motherboard x470 taichi
Cooling stock wrath
Memory TridentZ Neo rgb 3600mhz (2x8 kit)
Video Card(s) Sapphire Vega 64 nitro+
Storage 970 evo nvme
Display(s) lc27g75tq
Case tt core x5 tge
Audio Device(s) sennheiser's pc323d usb soundcard
Power Supply corsair AX860i
Mouse roccat burst pro
Keyboard roccat ryos mk fx
Software windows 10
12v*2.5a=30w
1,129 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
i had a couple of these in my server
http://www.ebay.co.uk/itm/Startech-...uting_CablesConnectors_RL&hash=item232a03fa60
1,181 (0.18/day)
Processor 7900
Motherboard Rampage Apex
Cooling H115i
Memory 64GB TridentZ 3200 14-14-14-34-1T
Video Card(s) Fury X
Case Corsair 740
Audio Device(s) 8ch LPCM via HDMI to Yamaha Z7 Receiver
Power Supply Corsair AX860
Mouse G903
Keyboard G810
Software 8.1 x64
All four devices will work fine on that one power connection. Molex isnt rated as low as 35watts.
That wont provide enough power. A single SATA connector is rated for 4.5a per 12v, 5v, and 3.3v line. The 4 devices need 1.75a + 1.75a + 2.5a ≈ 6 amps on the 12v line.
1,129 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
2x 2TB Caviar Greens = 2x 5.3W peak 5.3/12=0.88A
1x Crucial m4 64GB = 2.6W peak (runs on 5v)
1x LG GH24NS90 = 12V 2.0 A / 5V 2.5 A
so really the power consumption on the 12v is only 2.88A max with what he is wanting to run.
i just prefer the sata connectors reliability the pins on molex connectors get damaged really easily so it makes a bad connection causing all sorts of problems.
1,181 (0.18/day)
Processor 7900
Cooling H115i
Case Corsair 740
Mouse G903
Keyboard G810
Software 8.1 x64
The Greens pull 1.75a @ 12v each
5.3w is the heat dissipation rating(the amount of heat it puts out)
and the burner pulls 2.5a @ 12v from the sticker:
Thats about 6 amps total which I think is too much for a single SATA power connector since they are rated for 4.5 amps. Do you agree Geofrancis?
OneMoar
There is Always Moar
8,793 (1.66/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
the ammount of load you can place on a given chain is determined by the gauge of wire and the power supply its self if it uses
18 Gauge wire then you can safely draw 10 AMPs of power of over it
if its 22 then you can safely draw 7AMPs
if its 24G wire you can safely draw 3.5amps ect ect ect
most PSU's use 18or 22 Gauge wire for the 12V and 24 for the +5V
barring any limitations with the psu its self it should be fine
*connectors* don't have limitations other then the limits or the wire that feeds into it when it comes to Molex. a molex plug is just some wires terminated with a MALE bullet connector in a plastic shell
Sata connectors are a bit different because of the difference in Wire Gauge Vrs the Connector-pins generally I would say that a Single sata "connector" could handle 7 amps without much fuss
1,181 (0.18/day)
Processor 7900
Cooling H115i
Case Corsair 740
Mouse G903
Keyboard G810
Software 8.1 x64
You're right. I forgot here at techpowerup we push our hardware to its limits! 7 amps over the connection rated for 4.5a would be fine as long as you place a small fan over the connector :rockout:
OneMoar
8,793 (1.66/day)
Rochester area
http://www.aerocooler.com/images/AF0064-a.jpg
the connector is Specified for 4.5 there should be no problem with drawing 7 Amps though it but that point is m00t as you will never find a device that can draw more then 5Amps though a single connector
260 (0.06/day)
The Netherlands
Haha, well I'm not fully convinced what is best now...
The goal is simply to use as little cables as possible powering those 4 devices.
I ordered the StarTech cable already, eventhough I thus might be wiring it up differently.
I found this interesting (though dated) link the other day: http://www.playtool.com/pages/psuconnectors/connectors.html#sata
I got an AX850 psu, but frankly the provided sata power cable is not long enough and for some reason the connectors are upside down (perhaps Corsair/Seasonic still thinks people mount their psu's at the top of the case).
My initial idea was to hook those 4 devices to the Bitfenix cable which I then connect to a Molex cable coming from my psu, since I got a molex power cable in use anyway (to power my Xonar DX and 3 large 230x200mm casefans).
I guess the easy solution now would be power the DVD rewriter with Corsair's sata power cable (which has 4 connectors) and hook the 3 SSD/HDD's to the StarTech extension/splitter cable. Which I then connect to one of the remaining free connectors of the Corsair cable.
Or does anyone have a better idea?
PS. Thanks for all the help/advice!
EDIT: I ordered a Plextor M5 Pro 512GB to replace my Crucial m4 64GB. It was on sale for € 348 and I finally got enough space to actually put all my programs and games on the SSD.
But to recap the device's power needs:
DVD Rewriter:
5 volt = 2.0 A
12 volt = 2.5 A
WD Caviar Green (per device):
5 volt = 0.7 A
12 volt = 0.55 A
Plextor M5 Pro:
unknown, but for the 256GB variant 5 volt = 1.5 A
1,129 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
power consumption shouldn't be an issue. the main reason to hate molex connectors is they have a habit of making an intermittent connection that will disconnect if you even breath near it. sata connectors are made with much tighter tolerances so it will only disconnect if you pull the cables apart.
260 (0.06/day)
The Netherlands
So I shouldn't have worried to begin with?
Eventhough Frank's calculation was incorrect concerning the 12 volt power needs, based on my last post I'm above 4.5 Amps on the 5 volt wire though...
1,129 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
the connectors wont melt will you push 10+ A though them it should be fine.
260 (0.06/day)
The Netherlands
I got the SSD and splitter cable today, the Plextor M5Pro 512GB actually pulls 2.0 A on the 5V.
What bothers me though, why are those connectors of the spillter cable also inversed, eventhough people haven't been using top mounted psu's for a while now? Is there an easy solution to overcome that problem without twisting the wires too much?
