Aahahaha, pardon me for saying higher, I was actually thinking what better word should be used, but it was already 12 midnight and my father is like screaming at me to go to sleepIt looks like there's only two unverified GTX 960M 4GB BIOSes in the database. One supports UEFI, the other doesn't.
https://www.techpowerup.com/vgabios...sion=&interface=&memType=&memSize=4096&since=
Neither of which is the same version. And "higher" is not a thing in regards to BIOS versions. Newer maybe. But newer does not necessarily mean "better", or more compatible...or what-the-heck-ever you're thinking with that line of reasoning.
You might have more luck adding a UEFI GOP module to your current BIOS. Provided you know exactly what you're doing. Specifically with flashing a mobile GPU BIOS. Adding the UEFI GOP module should be a trivial affair.
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
Yeah, gonna involve myself into some research before doing this, don't worryDont screw up your stuff
