- Aug 16, 2005
- 27,598 (3.84/day)
- Alabama
System Name | RogueOne |
Processor | Xeon W9-3495x |
Motherboard | ASUS w790E Sage SE |
Cooling | SilverStone XE360-4677 |
Memory | 128gb Gskill Zeta R5 DDR5 RDIMMs |
Video Card(s) | MSI SUPRIM Liquid 5090 |
Storage | 1x 2TB WD SN850X | 2x 8TB GAMMIX S70 |
Display(s) | 49" Philips Evnia OLED (49M2C8900) |
Case | Thermaltake Core P3 Pro Snow |
Audio Device(s) | Moondrop S8's on chitt Gunnr |
Power Supply | Seasonic Prime TX-1600 |
Mouse | Razer Viper mini signature edition (mercury white) |
Keyboard | Wooting 80 HE White, Gateron Jades |
VR HMD | Quest 3 |
Software | Windows 11 Pro Workstation |
Benchmark Scores | I dont have time for that. |
On my server X10SLL-F I use a quadro 600 (notice lack or K and P designations) to offload video encoding jobs. I had a big issue getting the server to start (I run headless and connect via IPMI) After fooling around I removed everything, got the board to let me into BIOS and I realized this card is probably doesn't support UEFI. A quick check showed that to be the case. https://www.techpowerup.com/vgabios/94453/nvidia-quadro600-1024-100825
Now while I was in bios I changed PCI-E OPROMS to legacy from EFI and left storage OPROMS set to EFI so I could boot my OS. (This server only has ASPEED 2000 BMC for vid output). Now my OS boots and Server 2019 sees the GPU awesome! I noticed a curiosity though. GPU-Z is reading the card supports UEFI which isn't the case, atleast with the DB entry above. Even if it was a typo in the VGA DB however, this was proven by the fact the machine will NOT init with EFI is selected for the PCI-E OPROMS.
I do not use this card for display output. Nothing is connected. Tts GPU workload only. Just a FYI.
Additonally, this reading doesnt appear to come from the ASPEED controller. My other server X10SLM+ -F which essentially uses the same BIOS and definitely the same ASPEED controller model does not detect anything (or UEFI). (Probably since this is again not really a GPU and just a BMC output tied to a VGA port.)
That looks normal, GPU-Z on the other server also doesnt see the ASPEED controller, just the Q600 it just thinks its UEFI capable.
