UL Releases PCI Express Feature Test For 3DMark Ahead of PCIe 4.0 Hardware
crazyeyesreaper
Not a Moderator
9,783 (1.75/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI RTX 3080 10GB Suprim X
Storage 3x SSDs 2x HDDs
Display(s) ASUS VG27AQL1A x2 2560x1440 8bit IPS
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
With PCI-Express 4.0 graphics cards and motherboards soon to arrive, UL has released their PCI Express feature test for 3DMark. This latest addition has been designed to verify the bandwidth available to the GPU over a computer's PCI Express interface. To accomplish this, the test will make bandwidth the limiting factor for performance and does so by uploading a large amount of vertex and texture data to the GPU for each frame. The end goal is to transfer enough data over the PCIe 4.0 interface to thoroughly saturate it. Once the test is complete, the end result will be a look at the average bandwidth achieved during the test.
While real-life gaming performance is unlikely to be limited by PCIe bandwidth, the test does provide a repeatable and reliable way to measure PCIe bandwidth across generations and thereby the performance of different hardware configurations. The PCI Express feature test is available now in 3DMark Advanced Edition and 3DMark Professional Edition and is compatible with any system that has a Direct X 12 compatible discrete graphics card. The test will not run on systems using integrated graphics, and on multi-GPU systems, only the primary GPU will be tested. External GPU enclosures are not supported either.
1,703 (0.27/day)
Oshkosh, WI
System Name ChoreBoy
Processor 8700k Delided
Motherboard Gigabyte Z390 Master
Cooling 420mm Custom Loop
Memory CMK16GX4M2B3000C15 2x8GB @ 3000Mhz
Video Card(s) EVGA 1080 SC
Storage 1TB SX8200, 250GB 850 EVO, 250GB Barracuda
Display(s) Pixio PX329 and Dell E228WFP
Case Fractal R6
Audio Device(s) On-Board
Power Supply 1000w Corsair
Benchmark Scores A million on everything....
What is it supposed to be? Couldn't they have made it look like grass or something?
11,814 (1.73/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
Fairly certain W1zz has proven that by the time bandwidth is an issue the card will be obsolete. Multiple times.
Perhaps it might reveal weakness in other components that could cause stuttering
132 (0.07/day)
It's scaled to do 1 FPS per 1GB/s of bandwidth.
It starts with fewer big polys and then goes up, on my gen 3 PCIe it looks quite nice at the end, on gen 4 it should be quite convincing field of grain :)
1,703 (0.27/day)
Oshkosh, WI
Case Fractal R6
A field of grain floating on a turbulent ocean?
2,147 (0.43/day)
We should have some more PCI-E related, benchmark tools. Because there's enough gains to be scored when oc'ing the PCI-E bus. GPU-Z for example reports the Bus width / link width but not the actual bandwidth. If we OC the bus to 110Mhz that should increase the bandwidth alot more then running on stock?
I know oc'ing the PCI-E bus helps the videocard but can cause issues for the NIC, S-ata controller and what more. But we've done it in the past to sqeeze a few more FPS out of a OC contest.
1,595 (0.81/day)
Motherboard MSI X670E Carbon
Cooling MO-RA 3 420
Memory 32GB 6000MHz
Storage 4x 2TB Nvme
Display(s) Samsung G8 OLED
Case Silverstone FT04
I/O , Storage , Connectivity , those are the PCI-E 4.0 capabilities we want to see.
Modern graphics cards are proven to be effective enough to run on 3.0x8 with single digit performance loss.
The only "4.0 beats 3.0" scenario is external display card, but it is a very niche market .
Please stop doing these stupid PCI-E 4.0 graphics benchmarks.
16,714 (2.33/day)
Please stop voicing your stupid opinions? It's a test for crying out loud, it's been designed to show that there's a difference for the sake of having a test to show there's a difference. People love showing off the fact that they have fast hardware. What's so wrong with that? Yes, it might be a mostly pointless test, but stupid..?
19,368 (3.65/day)
Pcie 4.0 vs 3.0 today... like hooking up a fire hose to your garden spicket.
1,595 (0.81/day)
Cooling MO-RA 3 420
Memory 32GB 6000MHz
Storage 4x 2TB Nvme
There is no point of creating a benchmark with fancy visuals to test bandwidth.
Something looked like a AIDA64 memory test would be fancy enough for a bandwidth test.
And I have to remind you, this test isn't a PCI-E test because it needs a GPU to operate.
For example you cannot test your fancy PCI-E 4.0 x4 m.2 slot with it.
You can call it a "GPU data rate test" but PCI-E ? Hell NO.
It is a pointless test at the beginning and calling it a PCI-E bandwidth test is utterly stupid.
455 (0.10/day)
System Name ---
Processor Ryzen 1600
Motherboard ASRock Taichi X370
Cooling Noctua D15
Memory G.Skill 3200 DDR4 2x8GB
Video Card(s) EVGA 1080 TI SC
Storage 500GB Samsung Evo 970 NVMe + 860 Evo 2TB SSD + 5x 2TB HDDs
Display(s) LG CX 65"
Case Phanteks P600S (white)
Power Supply Corsair RM850x (white)
Can you provide links to this please? I've been trying to find this out.
16,714 (2.33/day)
Of course there is, maybe not as an actual test, but you know as well as I do, that companies like to show things off in a visual way, as does overclockers and people that like benching. It might not server an actual purpose for the test itself, but it serves a purpose, even though you might not find it useful.
Most recent one here https://www.techpowerup.com/review/nvidia-geforce-rtx-2080-ti-pci-express-scaling/
11,878 (2.27/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Anyone tried this on an actual pciex slot yet at home, surely someone has a Intel server pciex4 test to show?.
INSTG8R
Vanguard Beta Tester
7,981 (1.11/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 2
Software Win 10 Pro x64
Well I gave it a go. It was weird and I didn’t let it finish. But it’s was like 5FPS and my card was just idle during the test 5.9GBs was the highest I saw before I quit.
16,714 (2.33/day)
You running your card in x8 mode?
INSTG8R
7,981 (1.11/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
11,878 (2.27/day)
Manchester uk
VR HMD Oculus rift
My PC sustained 7GB/s on pciex 3
692 (0.15/day)
Australia
System Name Eula
Processor AMD Ryzen 9 7900X PBO
Motherboard ASUS TUF Gaming X670E Plus Wifi
Cooling Corsair H150i Elite LCD XT White
Memory Trident Z5 Neo RGB DDR5-6000 64GB (4x16GB F5-6000J3038F16GX2-TZ5NR) EXPO II, OCCT Tested
Video Card(s) Gigabyte GeForce RTX 4080 GAMING OC
Storage Corsair MP600 XT NVMe 2TB, Samsung 980 Pro NVMe 2TB, Toshiba N300 10TB HDD, Seagate Ironwolf 4T HDD
Display(s) Acer Predator X32FP 32in 160Hz 4K FreeSync/GSync DP, LG 32UL950 32in 4K HDR FreeSync/G-Sync DP
Case Phanteks Eclipse P500A D-RGB White
Power Supply Corsair HX1000 Platinum 1000W
Mouse SteelSeries Prime Pro Gaming Mouse
Keyboard SteelSeries Apex 5
Software MS Windows 11 Pro
+12GB/s on X299
arm1
2 (0.00/day)
Ukraine
I7 8700 + rx 580 + Asrock z390 extreme4 - 13.98 GB/s
4,378 (0.68/day)
Hurst, Texas
System Name The86
Processor Ryzen 5 3600
Motherboard ASROCKS B450 Steel Legend
Cooling AMD Stealth
Memory 2x8gb DDR4 3200 Corsair
Storage WD Black 512gb, WD Blue 1TB
Display(s) AOC 24in
Case Raidmax Alpha Prime
Power Supply 700W Thermaltake Smart
Mouse Logitech Mx510
Keyboard Razer BlackWidow 2012
Software Windows 10 Professional
hmm im gonna toss my GTX 550 ti on an nforce 4 board to see how bad PCIe 1.0 does
