Unbalanced temperature with CPU
swchoi89
56 (0.01/day)
Toronto, Canada
Processor i5-3570K
Motherboard Asus P8Z77-V LK
Cooling CoolerMaster 212+ Hyper
Memory Ripjaw G-Skill 2x 4GB 9-9-9-16
Video Card(s) EVGA GTX 670 FTW
Storage OCZ Vertex 3 240GB
Display(s) Samsung 27'' LED
Case NZXT Lexa S
Power Supply OCZ 850W Modular
Software Windows 7 64Bit Professional
Hey guys,
I use i5-3570K and overclocked it at 4.4Ghz.
When I see the temperature, whether it's idle or under load, one core is always higher than the other 3 cores by at least 7 degrees celcius. Should I be worried?
Thanks!
41,290 (6.57/day)
95Viper
Super Moderator
12,851 (2.21/day)
It could be a sensor that is off (not quite accurate).
Or, have you check the TIM on the CPU to see if it is evenly spread?
Have you checked the cooler mounting to see if it is level and secured properly?
Run Realtemp and post your temps from a screenshots. Both idle and max. and run the sensor test and post a screenshot of that, too.
Edit:
Oops: thank you mod!
Now, you are reading minds... hmmm.
BUCK NASTY
4P Enthusiust
4,976 (0.80/day)
Port St Lucie, FL. U.S.A.
System Name Main Rig
Processor AMD FX-4130 @ 4.8Ghz
Motherboard ASUS M5A99X Evo
Cooling Coolermaster Hyper 212+
Memory 8GB GSkill DDR3 1600
Video Card(s) ASUS GTX 970 Strix @ 1503Mhz Core
Storage Corsair Force 90gb SSD/ WD Caviar Blue 750gb
Display(s) ASUS 24" IPS
Case Coolermaster Centurion 590
Power Supply Antec TP750 80+
Software Windows 7 Ultimate 64
Don't worry about the difference in core temps. Just worry about distance to TJmax or Max Temps. Core 0 will always be higher than the other cores.
538 (0.08/day)
System Name Ed-PC
Processor Intel i5-12600k
Motherboard Asus TUF Z690 PLUS Wifi D4
Cooling Noctua NH-14S
Memory Crucial Ballistix DDR4 C16@3600 16GB
Video Card(s) Nvidia MSI 970
Storage Samsung 980, 860evo
Case Lian Li Lancool II mesh Perf
Power Supply Corsair RM750x
Software Win10 Pro 64bit
1,838 (0.35/day)
London
System Name Jaspe
Processor Ryzen 1500X
Motherboard Asus ROG Strix X370-F Gaming
Cooling Stock
Memory 16Gb Corsair 3000mhz
Video Card(s) EVGA GTS 450
Storage Crucial M500
Display(s) Philips 1080 24'
Case NZXT
Power Supply Enermax 425W
Hey guys,
Thanks!
It happens with Intel cpu's. Nothing to worry about.
swchoi89
56 (0.01/day)
Toronto, Canada
Processor i5-3570K
Case NZXT Lexa S
Thanks to everyone!
Temperature wise, I use CoreTemp and the RealTempGT; both seem to be aligned and consistent with each other.
When idle, I usually get:
22C
31C
23C
21C
When under Load
61C
69C
63C
62C.
Solaris17
Super Dainty Moderator
26,570 (3.81/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Display(s) Odyssey OLED G9 (G95SC)
Audio Device(s) Moondrop S8's on schitt Modi+ & Valhalla 2
Keyboard Monsgeek M3 Lavender, Akko Crystal Blues
VR HMD Quest 3
it has happened on all the CPUs iv had that were over 2 cores. the ones inbetween cores get hotter.
swchoi89
56 (0.01/day)
Toronto, Canada
Processor i5-3570K
Case NZXT Lexa S
So... how do I measure my CPU Temperature...? Average of the 4?
Solaris17
26,570 (3.81/day)
Alabama
VR HMD Quest 3
4,815 (0.76/day)
Wangas, New Zealand
System Name Darth Obsidious
Processor Intel i5 2500K
Motherboard ASUS P8Z68-V/Gen3
Cooling Cooler Master Hyper 212+ in Push Pull
Memory 2X4GB Corsair Vengeance DDR3 1600
Video Card(s) ASUS R9 270x TOP
Storage 128GB Samsung 830 SSD, 1TB WD Black, 2TB WD Green
Display(s) LG IPS234V-PN
Case Corsair Obsidian 650D
Audio Device(s) Infrasonic Quartet
Power Supply Corsair HX650w
Software Windows 7 64bit and Windows XP Home
Benchmark Scores 2cm mark on bench with a razor blade.
I believe this is normal from what I have seen on the web and from the readings of my 2500K.
43,596 (6.58/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
Thanks to everyone!
22C
31C
23C
21C
When under Load
61C
69C
63C
62C.
Mine's worse. Looks very normal to me.
95Viper
Super Moderator
12,851 (2.21/day)
swchoi89, like the others have stated, those temps look fine and that little bit of a variation in the sensors are normal, IMO.:)
Edit:
The easiest thing to do is, just, use the highest core temp as your guide.
swchoi89
56 (0.01/day)
Toronto, Canada
Processor i5-3570K
Case NZXT Lexa S
Such a fabulous reply and very quick! Thanks for your help guys.
swchoi89
56 (0.01/day)
Toronto, Canada
Processor i5-3570K
Case NZXT Lexa S
Edit:
nope like above just watch tj max.
Thanks guysss :)
