Underclocking 4790K
tabascosauz
8,216 (2.34/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Calling all underclockers! It's time to step out from the shadows of your overclocking brethren :laugh:
I've been fooling around today with my 4790K and relatively new H97N-WIFI, especially enjoying the voltage control offered by this board that was sorely missed on my late H81I. I got around to lowering the clocks and volts a bit on my 4790K. This is in the light of recent developments that may push me to abandoning my SG08 (and re-assigning my D9L to another rig) for an SG05 and a L9i or L9x65.
So, pre-emptively for a decision I might be forced to make, I naturally wanted to make my 4790K run a bit cooler. After some messing around and a few failed boots due to some overly ambitious undervolting, I settled on 3.3GHz, 4c/8t, with vcore at 1.05v. The result was most cores under 60 degrees and one peaking at 63.
I'm no expert at undervolting and underclocking, thus I must ask the undervolters amongst you; so, do you think that I could go further with this (higher clock at 1.05v, lower volts at 3.3GHz)? I think I could make do with 3.3GHz on a daily basis; I don't play games that much anymore and the few games I play either don't care much about IPC (PD2 doesn't care much about CPUs at all) or utilise multiple cores pretty well (GTA V). I guess a better question is should I go further or is this enough to keep under 80 degrees in an SG05 with L9i?
I believe stock voltage, at 4.0GHz was around 1.19v vcore. I think that number may have gone over 1.2v at 4.4GHz turbo.
PS these numbers are in a closed SG08 with a NF-A14 over top, and a D9L with just the stock NF-A9 fan.
OneMoar
There is Always Moar
8,802 (1.62/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
60c isn't even warm for haswell
you can safely run it all the way up to 80c at overclocked speeds @ < 1.30v
your chip looks pretty decent mine needs 1.30v for 4.4
2,758 (0.44/day)
Currently i'm at 1.26v and 4.5GHz, highest temps I've reach is around ~75c. If I lower the voltage anymore (.01 increments) I can't get past Windows loading.
manofthem
WCG-TPU Team All-Star!
10,960 (2.13/day)
Florida
Processor 3900X @ 4.0
Cooling DeepCool Castle 360EX
Storage Sabrent Rocket Q 1TB
Display(s) LG 34UC88
Case Thermaltake P3
Mouse Logitech G900
Fwiw my 4790 non-k runs at 3.8 @1.08v. Any lower and it crashes. If you're only going for 3.3, no harm in dropping a little more to see if it can handle it ;).
johnspack
Here For Good!
6,049 (0.96/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 1x27" 1440 display 1x 24" 1080 display
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Archlinux, Manjaro, Win11 Ent 24h2
Benchmark Scores It's linux baby!
Jeez, those temps. If I ever saw 75c running anything on it, I'll pull the cord.... and I thought my first gen hex ran hot!
177 (0.05/day)
Croatia
Processor Intel Pentium III-S 1.4 Ghz
Motherboard Asus TUSL2-C
Cooling CoolerMaster Sckt.370
Memory Kingston 2x256Mb SDR 133 Mhz
Video Card(s) 3dfx Voodoo 5 5500 AGP 64Mb
Storage Crucial BX500 240GB
Display(s) Fujitsu B19-5 ECO
Case Antec PlusView 1000 AMG
Audio Device(s) Creative X-FI XtremeGamer
Power Supply XFX TS 550W Bronze
Mouse Glorious MODEL O-
Keyboard Corsair K70 RGB MK.2
Software Windows XP
Benchmark Scores 3DMARK00-4905, 3DMARK01SE-2168
I keep my 4790K at 4Ghz (Turbo Off) but i reduced the voltage with adaptive mode in Bios. So when the Cpu idles it stays at 0.760V~0.765V, in full load it goes no more than 1.047V. I tested for stability issues and had no problems.
After 15 minutes of stress testing in Intel XTU it doesn't go over 47°C. I have to test if i can go any lower but i don't have the time right now.
As for your question: You should be able to go 4Ghz with your current 1.052V and reduce the voltage even more for 3.3Ghz.
But remember every Cpu is different. The numbers i wrote for my voltage maybe won't work with your Cpu.
Keep us updated.
tabascosauz
8,216 (2.34/day)
Western Canada
System Name ab┃ob
Apparently, I was being very conservative with my figures. This is the second pass around on 4.0GHz @ 0.98V. This is actually getting me a little worried as I'm wondering if I'm doing it correctly, if my 4790K is stable for 15 minutes at 4 cores 4.0GHz at just 0.98V.
177 (0.05/day)
Croatia
Software Windows XP
How do you lower your voltage ? Are you using Intel XTU program or from BIOS ?
Bo$$
Lab Extraordinaire
5,656 (0.98/day)
London, UK
System Name Desktop | Server
Processor Intel i7 2700k @ 4.6GHZ | AMD 5350 @ 2500MHZ
Motherboard Asus P7Z77-V Pro | Asus AM1I-A
Cooling Corsair H60v2 | Stock Air
Memory Crucial Ballistix 2x8GB CL8 1600MHZ | Corsair Vengence 2x4GB CL9 1600MHZ
Video Card(s) EVGA GTX 1060 6GB | PNY GTX 750Ti
Storage Samsung 840 EVO 250GB + 4TB WD Red | 2x Seagate Barracuda 2TB
Display(s) Samsung S27D390H + Asus VE276Q | Headless
Case Fractal Design R5 | CM Elite 110
Audio Device(s) Asus Xonar D1 w/Otone Stilo 5.1 and Creative Fatal1ty headset
Power Supply EVGA Supernova 850 G2| Corsair CX430M
Mouse Razer Imperator 2012
Keyboard Corsair K90
Software Windows 7 SP1 X64 | Ubuntu 16.04LTS
Yes i think you can go further!
However I'd probably change stuff in the BIOS rather than XTU. What program are you using for stress testing?
tabascosauz
8,216 (2.34/day)
Western Canada
System Name ab┃ob
I'm not using XTU to change settings because it doesn't stick; I change all my stuff in the BIOS. Stress test is done via XTU and OCCT; XTU is decent but OCCT stresses 100% of the time and that's a bit too much heat in a closed case like the SG08. There's nothing that can get by XTU but not OCCT; either it passes both or fails both.
Scratch that, 0.987 is not stable at 4. I don't think I really need to hit 4, so I'm going to stay under 1v at 3.5GHz. Sitting at 0.971v and it appears to be stable.
162 (0.03/day)
I got a 4690K which is the same chip as your 4790K except 2megs of cache gimped and HT disabled, and this is the voltage I see after I've dropped it at the same frequency by 100 millivolts:
8,253 (1.18/day)
System Name money pit..
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
my 4790 is okay at 4.6 with 1.28 volts.. at 4.5 its okay at 1.27.. to go higher than 4.6 requires a big jump in the vcore for stability maybe 1.35 or higher..
stock its at 1.17 boosting to 4.2 gig.. gaming temps are maybe 60 C-ish at stock and 72-ish at 4.6.. it still hits 100C and throttles down when i run a small block FPU only stress load on it..
i would guess with a stock intel cooler 100 C at stock speeds would be quite common when all eight cores are fully loaded.. the chips will stand this else intel would not sell them set at this.. low temps are nice but the chips are designed to hit 100 C.. when they do they throttle down to maintain 100 C..
intel could set them to throttle down at say 90 C.. the fact they pick 100 C means the chip is okay at that temp.. or lets say it wont damage it..
unless you have a laptop there aint much to be gained by running slow.. interesting to see though.. :)
trog
12,062 (2.58/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
That's pretty silly. You'd do more damage pulling the plug than running an Intel CPU at 75 degrees. Devil's Canyon and most modern Intel's have a safe operating temperature of over 100 degrees.
It's AMD CPUs that start getting dangerous around 68 degrees. Their temperature reporting is different to Intel's.
2,693 (0.42/day)
System Name panda
Processor 6700k
Motherboard sabertooth s
Cooling raystorm block<black ice stealth 240 rad<ek dcc 18w 140 xres
Memory 32gb ripjaw v
Video Card(s) 290x gamer<ntzx g10<antec 920
Storage 950 pro 250gb boot 850 evo pr0n
Display(s) QX2710LED@110hz lg 27ud68p
Case 540 Air
Audio Device(s) nope
Power Supply 750w superflower
Mouse g502
Keyboard shine 3 with grey, black and red caps
Software win 10
Benchmark Scores http://hwbot.org/user/marsey99/
my 4770k use to make me shit bricks when it hit 110c...
19,375 (3.51/day)
Underclocking... I...I...... *points large caliber handgun at head... pulls trigger*
Anyway, jokes aside, can you go lower? Who knows. Test it. Every CPU is different! So even someone with the same model board/bios, and CPU, results will be different.
*wipes up mess... reads first post again... points same gun at head, finishes job* :slap: :laugh:
6,871 (1.11/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Software Windows 11 Pro 64 bit
Benchmark Scores https://www.3dmark.com/spy/34962882
I'm ok with this-
6 cores/12 threads at 4 GHz using only 1.26 volts at full load (crunching)
