Undervolting on a RTX 3080 Ti
1 (0.00/day)
Somewhere in Spain
System Name EVA-03
Processor 5600X
Motherboard X570 Aorus Elite
Cooling BeQuiet! Dark Rock 4
Memory 4x8GB G.Skill Trident Z 3200MHz CL16
Video Card(s) EVGA RTX 3080 Ti XC3
Storage Samsung 970 EVO 500GB/980 1TB Toshiba 2TB HDD
Case Cooler Master H500P Mesh
Power Supply Focus GX 850W
Mouse Logitech GPro X
Keyboard Ducky one 2 mini
Hey everyone, I want to get into undervolting my 3080 Ti, I've read some guides and have a general understanding on how the procedure is done but have never done it, what is some general advice and recommendations when doing it?
The card is an EVGA XC3 3080 Ti, general system specs are a ryzen 5 5600x, 32GB @ 3200mhz cl16, gigabyte aorus x570 elite mobo and a seasonic focus gx-850w psu
Thanks in advance.
1,854 (0.39/day)
Romania
Install MSI Afterburner and then test your card in whatever games you play. I never had a 3080 Ti but had a 3080, i went with +150 and undervolted it little by little 0.975V then 0.950V and so on until it crashed, then backed away a bit and it was done.
1,025 (0.70/day)
Processor E5-4627 v4
Motherboard VEINEDA X99
Memory 32 GB
Video Card(s) 2080 Ti
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
First find the maximum boost speed attained by looking at monitoring software. sometimes it could be a little higher depending on how the card feels. Make sure it's above that value in MSI afterburner where you bring up the voltage frequency curve and find the point where boost clock intersects with the optimal voltage and right click to flatten it from that point till the end. Then save, add to windows start up if it feels crash free.
Sak
7 (0.02/day)
System Name SFF (Small Form Factor)
Processor Ryzen 5800X3D
Motherboard ASRock B550 Phantom Gaming M-ITX
Cooling Noctua UH-U9S
Memory 32 GB (2x16) Corsair Dominator 3600MHz CL18
Video Card(s) 4070Ti Asus TUF
Storage 1TB + 2TB | Samsung EVO SSD
Display(s) 1440p/240Hz/OLED | 1440p/144Hz/IPS
Case NR200
Audio Device(s) Moondrop Aria, PreSonus Eris 3.5"
Power Supply Corsair 750W SFX
Mouse Finalmouse UltralightX, (formerly Starlight-12 Tenz)
Keyboard Wooting60HE + Tofu60 Aluminum OG
Software Windows 11, 3+ hrs of optimization
Follow this video if you need some help. I had a similar GPU (EVGA FTW3) and did a -150 undervolt I believe. Did not meaningfully affect performance, but reduced my temps in my SFF build. :)
