- Jan 30, 2018
- 233 (0.09/day)
System Name | Dreamstation2 |
Processor | Ryzen 7 3700X |
Motherboard | MSI X470 Gaming Plus |
Cooling | Hyper 212 Black Edition |
Memory | Kingston HyperX 32GB DDR4 3200 CL16 |
Video Card(s) | Aorus 2080 Ti Turbo (sounds like a vaccum cleaner at full load) |
Storage | 2 x 1TB M.2 NVME + 1TB 2.5" SSD |
Display(s) | Samsung Odyssey G7 32" 4k |
Case | NZXT H500i |
Audio Device(s) | Asus Xonar U3 / Audio-Technica ATH-M50x / Edifier R1855DB |
Power Supply | Corsair TX650M |
Mouse | Corsair Scimitar Pro RGB |
Keyboard | Cooler Master Masterkeys Lite L |
My Ryzen PC is annoying me since I bought it last summer. Yes, the performance is great, everything is faster and smoother BUT ... as much as I edit fan profile curves, add more and bigger case fans, the stock CPU cooler makes too much noise even at idle with CPU load below 0.5%. My old Intel rig was so silent (in idle) I could hear the GPU water pump noise (and it's quite silent). Idle temp on the Ryzen CPU was touching 55-57ºC in the first months. Later AMD released the new AGESA and idle temps fell a bit, to 48-53ºC (my old i5-4690K is happily idling at 28ºC, in the same room).
So I did a google search about undervolting and found this article
https://www.gamersnexus.net/guides/3494-amd-ryzen-3000-undervolting-offset-override
Following the advice from it, instead of hard undervolting I configured the offset instead, putting -0.05V offset applied to CPU Vid.
I didn't try benchmarking but the PC is just as smooth and fast as before, but now my Ryzen is at 40-48ºC with a browser with 5 tabs open and CPU load of 2%.
Maybe if I finally replace the stock cooler with something better, results will be even more satisfying, but I think that better cooler would make bigger difference at high loads, not at idle. Also the current Coronavirus situation raised the prices of everything and stocks are almost non-existent so new cooler is out of the question for the foreseeable future.
Now my question is: Is this a placebo effect, am I deluding myself, or is such gain possible with such a small offset in VID?
