Hello folks! Im recently having some issues with minecraft.. So the problem is when i launch the game it immidietly starts to lag around 20-40fps.. People get like thousand frames with almost the same hardware yet i really dont know whats wrong with my PC. Allocating rams updating java, installing optifine/sodium and stuff didnt really change much. What do i do?
Specs:
XFX RX580 GTS XXX
Ryzen 5 3400g
Dual channel 16gb 3200mhz
B450m-a pro max 2
Yeah the cpu lacks a little but i think it really shouldnt be that bad.. CPU usage stays around %70 80s drops to 60 time to time wheras gpu stays around 300-500mhz at 32 chunks but the lag is just unbearable. (Im not suspecting of throttling either cpu temps peak around 70 degrees) Is this driver related??
Specs:
XFX RX580 GTS XXX
Ryzen 5 3400g
B450m-a pro max 2
