Uninstalling Elder Scrolls Online - The Bethesda Way
23,173 (6.10/day)
Up for a laugh?
Had enough of the infinite hassle with their broken launcher and updaters? Yep - been an issue since closed beta, and still not fixed :) You have to workaround even for getting a simple game update.
So, then you're fed up with the mess called ESO:
This is what you find after using the uninstall application Zenimax provides
125137
And its not like the app likes to save a small selection for whenever you'd reinstall, either;
125138
What, you think we're done? Note the scroll bar.
125139
Leave it to Bethesda to grab an off the shelf uninstall wizard and screw it up!
Note; this game was NOT made by the same team(s) as Fallout 76. Its a real culture thing with this company. I bet when you apply for a job they will ask you to create a small product with a minimum of five bugs, or you can turn around and go home :D
64K
6,773 (1.70/day)
Processor i7 7700k
Motherboard MSI Z270 SLI Plus
Cooling CM Hyper 212 EVO
Keyboard Logitech G105
Seems like most games leave behind some stuff after uninstalling. That's pretty silly though. When I uninstall a game I go back and check if there's still a folder left behind and I delete that. It's an old habit that goes back to when hard drive space was a concern.
87 (0.04/day)
System Name Shiny Beast 2.0
Processor AMD Ryzen 9 5950x
Cooling Corsair H150i Elite Capillex
Memory 32GB G.Skill Trident Z RGB 3600Mhz CL17
Video Card(s) Asus Strix RTX 3090 OC
Storage Samsung 980 Pro 1TB, Samsung 970 Evo 1TB, Samsung 860 Evo 1TB, Crucial MX500 2TB, WD Black 2TB
Display(s) Asus PG35VQ 3440x1440 200Hz GSync
Case Corsair 500D SE RGB
Audio Device(s) Logitech Z906
Power Supply Corsair HX1000 Platinum
Mouse SteelSeries Rival 600
Keyboard Logitech K750
It feels like they search for employees the exact opposite to every other company. You manage f-up something as simple as an uninstaller? Good you are hired! Your application works 100% as intended? Sorry, no job for you today. Jeez:roll:
339 (0.14/day)
Well, see, you should not delete it anyway... :D
Thats a bit harsh but feels truth.
64K
6,773 (1.70/day)
Processor i7 7700k
At least he can get to the folders to delete them. I bought 2 games from the MS Store. Gears of War Ultimate and Gears of War iV and MS installed them in a folder that I can't access and I am administrator on my rig. I followed the prompts to gain access to see what was installed and it didn't work. The folder is 250 GB in size. Those 2 games can't take up that much room. I suspect MS loaded some stuff in that folder besides those games and I can't even open the folder to view what they put there. They can't be uninstalled with the regular uninstaller either. They don't even show up on the list. They didn't even put icons on my desktop to launch the game either. What a mess the MS store is.
rtwjunkie
PC Gaming Enthusiast
14,025 (2.32/day)
Louisiana
Processor Core i9-9900k
This I had heard about most of the MS Store games, which is why I haven't bought any. I recently reinstalled Gears of War (yeah, the original one- from physical media) on my W8.1 rig. I may go and get my fix again next week.
Edit: @64K have you looked here, under user on C drive? LOCALAPPDATA%\VirtualStore
64K
6,773 (1.70/day)
Processor i7 7700k
194 (0.07/day)
I'm just curious, how many gigs of game data total left behind? Seems like a lot. Also what percentage of the original game folder size?
Same! Might be habit, paranoia, OCD - you name it, but I do that, too.
... bought 2 games from the MS Store ... MS installed them in a folder that I can't access and I am administrator on my rig ... The folder is 250 GB in size ... They can't be uninstalled with the regular uninstaller either. They don't even show up on the list. They didn't even put icons on my desktop to launch the game either.
Ho-lee monsterflipping schnitzels, my good fellow! I literally can't even...
584 (0.26/day)
... back to when hard drive space was a concern.
It is still a concern today, because it's SSD space, not hard drive space.
And SSD's, while much cheaper than before, ar still quite a lot smaller than HDD's.
Most laptops with SSD, even new ones sold today, come with 120-128 GB SSD, only the high-end ones have 250GB or higher.
If a game leaves 5 GB of junk behind (or more), that IS a problem when your drive is so small !
23,173 (6.10/day)
Wow that is next level shit. And ppl complain about EGS hahaha...
As for the size/remainder of files; the uninstaller only deleted the updater itself, it misses the rest as a result of Zenimax's sloppy file updater that fails for most people at some point; the 'workaround' is launching the game through the game exe and not the launcher. (Again, typical Bethesda: it wont work? Just dont use it!) Subsequent updates you get by, wait for it: reinstalling the launcher from scratch so it starts with a refreshed MANIFEST file...
So after one update of the game files, nothing matches up anymore and the uninstaller leaves the entire TES Online data folder intact.
64K
6,773 (1.70/day)
Processor i7 7700k
True, my laptop has a 250 GB SSD. I mostly play older games on it. My main rig has a 250 GB SSD and a 4 TB HDD just for games so I have plenty of space left on that. I think on my next build I will splurge on a 4 TB SSD.
2,141 (0.52/day)
Serbia
Processor Ryzen 5600
Motherboard X570 I Aorus Pro
Cooling Deepcool AG400
Display(s) 24G2U
Case NR200P
Power Supply Ion SFX 650
Mouse G703 (TTC Gold 60M)
Software W10
Leave it to Bethesda to make something laugh worthy
rtwjunkie
14,025 (2.32/day)
Louisiana
This is why other than OS drives which get the SSD treatment, I still use large capacity HDD. I prefer to download my games and be done with it, not uninstall a game and install a new one each time I go to a new game. Plus I have a habit of going back to old games for a taste occasionally.
Until SSD’s can give me the full install of all my games like HDD do at as reasonable cost, then I will not fully swap over.
1,277 (0.29/day)
Motherboard MXI APEX
Storage 660P 1TB, 860 QVO 2TB
Case Open Benchtable V2
Audio Device(s) SB X-Fi
Power Supply MSI A1000G
Mouse G502
Keyboard G815
Software Gentoo/Windows 10
They are just anticipating your relapse -- these are dealers, they know what they're doing.
878 (0.31/day)
Home
System Name Blackbox
Processor AMD Ryzen 7 3700X
Motherboard Asus TUF B550-Plus WiFi
Cooling Scythe Fuma 2
Memory 2x8GB DDR4 G.Skill FlareX 3200Mhz CL16
Video Card(s) MSI RTX 3060 Ti Gaming Z
Storage Kingston KC3000 1TB + WD SN550 1TB + Samsung 860 QVO 1TB
Display(s) LG 27GP850-B
Case Lian Li O11 Air Mini
Audio Device(s) Logitech Z200
Mouse Logitech G305
Keyboard MasterKeys Pro S White (MX Brown)
Benchmark Scores It plays games.
Yikes. Guess we know what the interns work on at Bethesda. :laugh:
Also, I'm now very curious to know where Horizon 4 is installed. MS Store is so bare you can't even pick where you install stuff, and that 80GB install was a hard pill to swallow for my small 250GB boot SSD.
64K
6,773 (1.70/day)
Processor i7 7700k
I was able to install to my HDD. When it prompts to install on the C: drive just change it to the letter of your other drive.
Deleted member 24505
Look for something called take ownership. I have it on my PC and you can take ownership of any file or folder, edit/access it and revert it back.
64K
6,773 (1.70/day)
Processor i7 7700k
Thanks. I will check into that too.
878 (0.31/day)
Home
Mouse Logitech G305
I don't remember any prompts during the install.. I think I just bought it and it started downloading right away. But I may have missed it in my excitement. I've read there's a move button in the Apps and Features that works for some store apps, but I haven't looked at it yet.
23,173 (6.10/day)
You say that but Im confident I wont relapse back into this one! It has its fun moments but looking back its a pretty horrible game. Tis a shame I needed a few hundred hours to figure that out :)
I know you are probably still ignoring me, but thanks for this one!
471 (0.14/day)
System Name Specs Last Update: 8/April/2024
Processor Intel Core i5 9400f 2.9GHz/4.0 Turbo (NoOC)
Motherboard Gigabyte Z370M D3H rev. 1.0
Cooling be quite! Dark Rock Slim 180W TDP (The Silent Wings 3 120mm Fan)
Memory Corsair Red Line 8x2 16GB 3000MHz (NoOC) DDR4-3000 15-17-17-35 (CMK16GX4M2B3000C15R) V1.35 ver 4.24
Video Card(s) NVIDIA GeForce MSI 980 Ti Golden Edition (NoOC)| Spare: GTX 650 Ti 1 GB
Storage Samsung 870 EVO 4 TB | Samsung 860 EVO 1 TB | Cold Backup: WDC Black 930 GiB WD1003FZEX
Display(s) Asus VG248QZ 1920x1080 144hz 24" (Current: 60hz)
Case Corsair Air 540
Power Supply Corsair 850W RMi
Mouse Logitech M187 wireless (First day of use 30-9-2021)
Keyboard Logitech K270 wireless
Software Windows 10 21H2 LTSC 2021 / Linux: Candidates: Bazzite - Linux MX - Tuxedo - Kubuntu
Ownership Build 120 from http://www.rizonesoft.com, but the site is moving the servers and you have to wait for 7 days.
However, you can download the exact thing from here https://www.softpedia.com/get/System/OS-Enhancements/Rizone-Take-Ownership-Shell-Extension.shtml (Same version)
EDIT:
There is also this, specific for Windows 10
How to Add Take Ownership to Context Menu in Windows 10
878 (0.31/day)
Home
Mouse Logitech G305
There's also the takeown command but it doesn't have "undo" afaik. Had to use it a couple times on naughty files.
7,099 (1.01/day)
USA
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
Nuke the entire directory from orbit, it's the only way to be sure.
silentbogo
5,612 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 64GB DDR4-3600(4x16)
Storage ADATA Legend 2TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Probably the same crap that makes B. Launcher forget the game location. I think it's the worst launcher to ever exist (including small short-lived random shit from early 2000s).
I've been bashing Bethsoft for 2 years on their forums, even offered my humble services to re-write the launcher - almost got banned on community portal ))) I guess they are happy with the way things are now.
With Bethesda you never know. Sometimes nuking is the surest way to crash the server :nutkick:
64K
6,773 (1.70/day)
Processor i7 7700k
Hah. I remember that when Fallout 76 launched people were setting off nukes in the game which would cause the server to crash. What an embarrassing mess of a game that was. Hopefully Bethesda will go back to making single player games now. They will still need the modding community to fix them though.
