UNLEASHED VBIOS POWERCOLOR 5600 XT ANYONE HAVE THEM?
42,349 (6.65/day)
You mean the 1 that increases the ram clocks
https://www.reddit.com/r/Amd/comments/es9t8a
I believe it increased ram clock from 1500 MHz (12000/8) to 1750 MHz (14000/8) or to 2000 MHz (16000/8)
(12000 is 12GBps, 14000 is 14GBps, 16000 is 16GBps)
GDDR6 is octal pumped, GDDR5 was quad pumped
Ok the performance boost for the GDDR6 was to go from 1500 MHz (12GBps) to 1750 MHz (14GBps) the files are all here, both 1500 and 1750.
TUL/PowerColor/Dataland:
Verified
Unverified
Match your Device ID and Sub System ID up to the files from the bios on the card to the 1s you will download.
Can you upload here?
Thanks
Here are all the vendors
Verified
Unverified
42,349 (6.65/day)
303 (0.06/day)
Thank you, dear, @eidairaman1, I could not find the specific vbios but if you have any directives on the directive of lucifer here on this earth we both share, so I may be aware of his end time goal. Would you be willing to let me know good sir? -Chrisninski Of ~The Divinity Of The Supremacy Of The Light Command~
42,349 (6.65/day)
The unleashed bios are all in the links i provided, they only upped the ram speed from 1500 to 1750.
Chris get gpu-z screenshot please, then go to the advanced tab and get a screen shot in there and click everything by the word general and screenshot everything in there
@chris189 it's strange but it's like pulling teeth to see anything from you as you pop in then many months go by and you're gone again.
