Unverified BIOS for Gainward RTX 2080
1,487 (0.31/day)
Anchorage Alaska
System Name Matter's / Helios 300 Predator
Processor Ryzen 7 2700 / i7 7700HQ
Motherboard B450 Tomahawk / Acer Helios 300 Predator
Cooling Arctic Freezer eSports Duo
Memory Patriot Viper ddr4 32gb / 32gb gskill ddr4
Video Card(s) MSI RTX 2080 Super Ventus OC / GTX 1060 6gb
Storage Patriot Viper nvme M2, crucial MX300 275gb, Samsung 860 qvo 1tb
Display(s) Acer 24" 1080p / 15.6 1080p HD
Case Antec 300 / Acer Helios 300 Predator
Audio Device(s) On Board - Steel Series Arctis Pro Wireless Cans
Power Supply Antec 850watt high current pro
Mouse Steel series Rival 600
Keyboard Corsair K70 / Acer Helios 300 Predator
Software Win 10 Pro / Win 10 Home
W1zzard
Administrator
28,014 (3.71/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Different subsystem ID, don't think NVFlash will accept that BIOS for your card.
Why do you want to flash in the first place?
Spacekiller
7 (0.00/day)
I'm hitting the power limit pretty often, its already at max for this card (112%) and I'm about to watercool the whole PC.
My only bottleneck for my GPU would be the power limit.
Edit: It won't be a problem if its not working, I'm just curious if its possible to increase the power limit with this BIOS
43,118 (6.73/day)
Get a gpu-z screenshot and an exact model number from your card.
What are your system specs
I was sent over from the LTT-Forums to ask, if someone can verify and ensure me, that this BIOS,
will work on my Gainward RTX 2080 (Triple Fan).
"Then go to techpowerup forums to verify the bios to your card.
You want eidairaman1 to have a look for you." - ShrimpBrime
Thanks for your help.
Spacekiller
7 (0.00/day)
Excuse me, but what do you mean by model number. The product number is NE62080020P2-180X
And this is screenshot from Nvidia Controlpanel
Edit:
My specs are :
CPU: Ryzen 7 2700X
GPU: Gainward RTX 2080
MB: ASUS X470 F-Gaming
PSU: BeQuiet Pure Power 11 600 Watt
43,118 (6.73/day)
Take a picture of the white stickers on the back of the card
43,118 (6.73/day)
43,118 (6.73/day)
The bios in your original post should work
Use this tool
If you want to go crazy try this one too, water cool otherwise fans may rev
Spacekiller
7 (0.00/day)
Thank you very much I will try it with the 280W BIOS.
Nice to have such a great Community. xD
43,118 (6.73/day)
Spacekiller
7 (0.00/day)
YES, IT WORKED.
The differences I noticed are:
Lower RPM Fans (but 33% minimum speed instead of 30%)
A bit higher coil whine
And 130% power limit instead of 112% (YESSS)
I'm so hyped to watercool this.
Thank you very much.
Deleted member 185158
Right on.
Thank you Mr. The Airman (exiled) once again for helping me help another request. You're the best. :D
