Upgrade my Laptop's processor
jackhicks121
1 (0.01/day)
HI Everyone
I am using a Lenovo Laptop with AMD processor. I am planning to replace it with intel processor. I have a few questions
Is it possilble to Upgrade from AMD CPU to Intel CPU
Or I will have to change the motherboard in order to use it.
Please also tell me if (https://serverorbit.com/cpus-and-processors/core-i7/) processor is compatible with my system or suggest me any other processor that will work well with my system.
Thanks in advance.
18,585 (2.71/day)
System Name AlderLake
You need to buy a new laptop if you want to switch to intel.
Also these days most laptops got the CPU's soldered to the mainboard, so you just can't simply upgrade.
GL.
7,453 (1.47/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
It is a bot? Ain't it?
18,585 (2.71/day)
7,453 (1.47/day)
Rīga, Latvia
Software FEDORA 41
That part with the link wasn't yet included when I replied.
I sometimes have a feeling when we are actually dealing with some trained troll AI in certain situations, especially when in specific fanboy rampages occur, that sometimes defeat reason and logic. Maybe I am exaggerating.
18,585 (2.71/day)
I'm done here.
2,835 (2.12/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
Reminds me of the 6700 VRAM mlcc troll
1,298 (2.11/day)
System Name KLM
Motherboard B-650E-E Strix
Video Card(s) 4070-ti PNY
Storage 512+512+1+2+2+2+2+6+500+256+4+4+4
Case 4000D Airflow
Power Supply Shift 1000
Mouse 502 Hero
Keyboard K68
Software EMDB
Benchmark Scores 0>1000
Skynet
Frick
Fishfaced Nincompoop
19,293 (2.84/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
7,453 (1.47/day)
Rīga, Latvia
Software FEDORA 41
Not necessarily, such questions have come up before.
Yeah... with AI that's the makes it even more severe, ain't it?
1,298 (2.11/day)
System Name KLM
Case 4000D Airflow
Mouse 502 Hero
Keyboard K68
Software EMDB
If OP answers humanly later, so we'll know
41,483 (6.58/day)
HI Everyone
Thanks in advance.
dimtel and AMD are not interchangeable, most mobiles use a bga chip and not a lga/pga zif so you'd need a hot air station to desolder the chip and use the highest chip the board and cooling system supports. To me just get a new mobile.
7,217 (1.03/day)
Processor AMD Ryzen 7 7700 Raphael \ i5-1135G7 Tiger Lake-U
Motherboard ASRock B650M PG Riptide Bios v. 2.02 AMD AGESA 1.1.0.0 \ Lenowo BDPLANAR Bios 1.68
Video Card(s) Asus GeForce RTX™ 4070 Dual OC GPU: 2325-2355 MEM: 1462| Intel® Iris® Xe Graphics
Display(s) LG UltraGear 27GP850-B 1440p@165Hz | LG 48CX OLED 4K HDR | Innolux 14" 1080p
Software Win11 Pro 23H2 UK | Win11 LTSC UK / Arch (Fan)
The closes anyone with a Lenovo might get is the with T490 if I remember correct you can install upto a T14 G3 motherboard into this chassis because the motherboards have the same layout or go Framework they do the same pcb layout so you keep your chassis and just buy another pcb,
I believe the last models from Lenovo that was "cpu" upgradeable was the T440p with Intel LGA but they sadly ain't worth it today slimmer and faster models are out.
944 (0.55/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Altec Lansing
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
You can't replace Intel with AMD or vice versa. But you can replace same brand of CPUs if you have a bga rework station.(If the socket type is the same)
Nowadays almost all mobile PCs have their CPU soldered to mobo
Generally server type sockets are different than the ordinary processors.
