- Jun 19, 2008
- 394 (0.07/day)
- Chiefs Kingdom
System Name | Never Had a Name |
Processor | i7-8700K |
Motherboard | ASUS ROG Maximus XI Hero Z390 |
Cooling | Corsair H110i Pro |
Memory | EVGA SuperSC 16GB 2 x 8GB DDR4-3000 PC4-24000 |
Video Card(s) | GIGABYTE RTX 2080 Ti WindForce OC - GV-N208TWF3OC-11GC (140 power target fw: 90.02.0B.40.6B) |
Storage | Samsung 960 EVO 500GB MLC V-NAND PCIe Gen 3 x4 NVMe M.2 2280 |
Display(s) | Asus PG278QR 27" / Asus MG248Q 24" |
Case | Cooler Master HAF 922 |
Power Supply | EVGA SuperNOVA 1000P2 |
Mouse | Corsiar M65 Pro |
Keyboard | Corsair K95 |
Software | Windows 10 64bit |
Benchmark Scores | http://www.speedtest.net/result/6097610737.png |
Ok, in 2018 I built my PC with a de-lidded 8700k and 2080ti custom loop with the following items:
I am now looking to update my components, I have a Lian Li PC-O11 Dynamic Tempered Glass ATX Mid-Tower.
Leaning toward an AMD 9800x3d combo from MC, eventually updating to a RTX 4080 or 5080 possibly.
A couple things I want to change:
CPU 9800x3d (Gaming, Productivity, Video editing)
Motherboard MSI X670E MAG Tomahawk WiFi AM5
Graphics Card RTX 4080 Super or likely RTX 5080
RAM G.Skill Flare X5 Series 32GB DDR5 5200 Kit
SSD's/HDD's M.2 960 EVO and 980 EVO, adding another M.2 at some point.
Case Lian Li PC-O11 Dynamic Tempered Glass ATX Mid-Tower.
PSU EVGA Super Nova 1000p2
Monitor 27" ASUS 1440p 265hz, 2x 24" ASUS extras.
Operating System Win11
Peripherals old stuff
Cooling custom loop twin 360mm rads
- Watercool WCP D5-VARIO 12V Pump with a 200mm reservoir.
- Bitspower G1/4" Matte black fittings.
- Bitspower None Chamfer PETG 16mm OD Rigid Tubing
- 2x XSPC TX360 Ultrathin Radiators (top case and front back behind res).
- Move from rigid to flex for serviceability ease.
- Does anyone know if the existing Bitspower G1/4" fitting will work with flexible tube or do I need barbed fittings?
- My pump and reservoir will need relocated to fit a RTX 4080 or 5080 as there is not enough room as currently mounted.
- Pretty sure I will need to ditch this current reservoir setup due to space.
- Do I really need a reservoir? Easier to fill a loop with one I imagine.
- Looking for suggestions on the pump/res replacement.
- Not planning to water block whatever GPU I end up with, I realize the 9800x3d doesn't really need 2x 360mm rads but I have them so might as well use them.
