What I mean is that I don't want to use it as crossfire. The second x1950 secondary edition is not important either. I just need a driver that will work with the mv2200 and 4800 series and I can use the 4800 series alone.
HD 4800
HD 4800 secondary.
but Fire MV 2200 has to work. I think 2200 series can use max catalyst 10.2. is that right
The version of the catalyst here is 6.4 and although it seems to be installed with HD 4800, it is not working right now. It wants me to update. When I install the latest version, it is not compatible with MV2200. I am looking for a version that will work with both and I want to install the 4800 series as primary and secondary.
If I am understanding correctly, you had 2x ATI X1950 and one of them broke? That generation of card required the dongle that connects the two cards together. Something like this.
With the 4850, ATI went to the Crossfire bridge. Something like this.
You cannot crossfire these cards together. It is not going to work.
What can you suggest me to use instead of x1950 crossfire. It will have crossfire feature but it will also work with MV2200. Here comes the problem.
The program does not work without mv2200.
