USB Stick problem. (No access)
10 (0.00/day)
System Name My Pc
Processor Amd Fx 3850 (4.0 Ghz)
Motherboard ASRock 990 Fx Extreme 3
Cooling quiet! Shadow Rock 2 Tower
Memory 16 GB TeamGroup Xtreem
Video Card(s) Geforce Gtx 980 (Reference)
Storage Western Digital WD20EARS Caviar Green 2TB
Case Nanoxia Deep Silence 2 gedämmt mit Sichtfenster Midi Tower ohne Netzteil schwarz Nanoxia Deep Silenc
Power Supply 630 Watt be quiet! Pure Power L8 CM Modular 80+ Bronze 630 Watt be quiet! Pure Power L8 CM
Mouse Speedlink Kudor RS
Keyboard Some Acer Office thing
Software Win 7
Hello
I have a little problem with my USB-Stickt and I think I need some help with it, because I can't fix it on my own...
I bought an "Intenso Ultra Line USB 3.0 USB-Stick" with 128 Gb.
My problem is that it is not showing up under "Computer" when i stick it inside the USB port.
I am out of ideas what the problem could be, i tested several USB ports (2.0 and 3.0) and i cant give the drive a letter like "C: or X:". But it shows somehow up. (Drivers are up to date)
I would really appreciate it if you could help me somehow!
Kursah
Super Moderator
14,730 (2.21/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
Possibly a corrupt partition table, delete both partitions, recreate them in Computer Management's Disk Utility (your top screenshot), format for exFAT or NTFS, give the volume a name and you should be good to go.
10 (0.00/day)
System Name My Pc
Software Win 7
Thank you VERY much ^^ it worked!
748 (0.18/day)
Oceania
A new drive shouldn't have any partitions. A partiton means it's been formatted.
Op did you buy the drive new or 2nd hand?
Kursah
Super Moderator
14,730 (2.21/day)
Missoula, MT, USA
Actually quite contrary to that, I've seen many USB HDD's and flash drives come pre-formatted and partitioned with software, including but not limited to backup, encryption, antivirus/malware, etc.
In fact, I don't recall a time when I bought a USB drive that didn't already have a partition and was pre-formatted aside from internal drives. I deal with a lot of them as I'm sure you do, but maybe up here in my market things are different.
:toast:
748 (0.18/day)
Oceania
:toast:
Yep, so I know that's an exagggeration. Sure it's possible.....but not every drive like you mean, def not the norm...
How many drives have you got that came prepartioned with Antivirus installed out of the box... a couple?
Eg......they're uninitialized unless stated on package. If I unexpectedly found 2 partitions on my new drive I'd be returning it.
PS, come to think of it multiple partitions aren't allowed on removable drives.
Prob what the op's problem was
Kursah
Super Moderator
14,730 (2.21/day)
Missoula, MT, USA
:rolleyes:
Anyways, without derailing the thread, I stand by my comments before. We can agree to disagree, I don't care to argue what I see daily. Feel free to start a new topic or start a PM. :toast:
@ OP, I'm glad your issues are resolved! That Computer Management MMC is very useful for a variety of tasks from disk management to user account and group management. Good stuff to learn and know. :)
748 (0.18/day)
Oceania
That's fine, but so just so you know, Windows only mounts the first partition on removable USB. For multi partition the vendor has to set the drive as fixed, otherwise u need a 3rd party tool......
Tbh I never even heard of Intenso...prob a Sandisk rebrand or someting...
