Used RX 580 no signal after bios flash
azsampako
3 (0.08/day)
So I bought a used miner rx 580. It’s a XFX XXX 580 4gb. The card has a bios switch with 2 positions - left and right. The right one didn’t give a video signal at all, so I used the left one. With it the display constantly flickered and games couldn’t run. Furmark worked fine(the version of the benchmark that doesn’t use vram) and the card got a good score. It also green screened a bit. So all this, in my mind, points to the vram being faulty. I cleaned and repasted it and I underclocked the vram severely and viola it(kind of) helped. It stopped the flickering. I tried running a couple of games and only one of them ran - AC Unity, it ran fine. So at this point I contacted the guy and told him the card was faulty. He agreed to replace it with another one from his rig but advised me to flash the bios to check if that’s the problem.
I downloaded the only bios in techpowerup for a xfx 580 4gb. It seemed all was ok until after the restart the gpu didn’t give any signal. And I flashed the left bios, the one that at least worked.
I don’t have an igpu but a friend does and I might try re-flashing the card on his pc. But my question is - is it worth it? Was I correct in my original assumption that the vram was bad? Should I just request a new card?
P.S: I used the 3.31 version of atiflash; The guy I bought it from also told me that this faulty behaviour of the card is to be expected if Im using it with his bios; I flashed the bios while using the rx 580, as my 5700x doesn’t have integrated graphics.
1,891 (1.44/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
Hello there. As an ex miner, the card had at least one BIOS modded. In your case i suspect that both BIOS-es were modded.
For now, we need some pictures:
- GPU-z main screen
- GPU-z > advanced tab and from drop down menu you will choose advanced timings
- labels from the card
- open the card and make a picture from GPU die and memory chips. Use macro and a good light source
azsampako
3 (0.08/day)
- GPU-z main screen
Hi, I took the card out of my pc and Im going to my friend’s place today to try flashing it in his pc. So until then I can’t post pictures of gpuz screenshots or the vram modules. But here is a photo of the label, if that’s informative in some way.
1,814 (0.30/day)
System Name Ryzen5900X
Processor AMD Ryzen 5900X
Motherboard Gigabyte B550 AORUS PRO AC
Cooling NZXT Kraken X62
Memory 4x G.Skill F4-3600C17D-8GTZ
Video Card(s) AMD Radeon RX 6800XT Midnight Black
We need more information. Please remove cooler and make picture of the memory.
After you found out which memory is on the pcb, you can try to flash one of these below. Please use AMDVBLFASH 2.93 for flashing.
Elpida EDW4032BABG änd Hynix H5GC4H24AJR memory support:
Samsung K4G41325FE and Hynix H5GQ4H24AJR memory support:
42,145 (6.63/day)
Please do what @VuurVOS asked, he knows what he is doing, same with @Imperator and myself
azsampako
3 (0.08/day)
Okay so the problem resolved itself somehow. After the bios flash the card didn't output a signal on my pc. When I plugged it into my friend's pc, to whom the card was a gift for anyways, it just worked. The correct bios is the elpida one. And I already flashed that exact one. For some reason it didn't work on my pc.
1,891 (1.44/day)
Romania
Hello.
So in the end you have a fully functional card?
That is great.
Enjoy it!
