using 7-port HUB on workstation motherboard
179 (0.05/day)
Tangent Universe
Processor 2x Intel Xeon Processor E5-2670
Motherboard ASROCK SSI-EEB DUAL-SOCKET EP2C602-4L/D16
Cooling Corsair Hydro Series™ H105 240mm / Coolermaster Hyper Evo 212
Memory Samsung ECC 1333Mhz 64GB
Video Card(s) Gigabyte G1 Gaming GeForce GTX 980 4GB
Storage WD Black 1,5TB 7200rpm 64MB Cache 3.5" / Samsung Pro 850 256GB SSD
Display(s) Asus P298Q 29'' IPS
Case NZXT S340
Power Supply Corsair AX860 80 PLUS® Platinum Fully Modular
Mouse Razer Taipan Ambidextrous
Keyboard Cooler Master Quickfire XT MX Cherry BLUE
Software Win7 64bit / Razer Electra
hello and merry xmas!
i got this http://www.asrockrack.com/general/productdetail.asp?Model=EP2C602-4L/D16 motherboard and as you can see it lacks of usb ports badly. only 2 x 2.0 ports. its pretty much terrible as i use standart setup - mouse/piano and usb wifi. as i have other pc's this one is used just for casual working on 3d.
i was wondering am i good to go with this TP-LINK USB3.0 UH700 if i am only plug in this hub keyboard, mouse and some usb small flashes? should i be aware of some chokes and lags on mouse/keybaord when hub used on usb 2.0 port? or it will scale just about properly and it wont be any problem at all?
btw, i understand that it is 3.0 hub, which i am considering to plug into 2.0 motherboard.. future proof for the win and because i can... lol
i attached pic on setup i planning. what do you think? am i safe to go?
thank you guys, i am looking forward for some xmas answers!
Frick
Fishfaced Nincompoop
19,819 (2.86/day)
north
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
Some periphals don't like hubs, but most do. Powered hubs usually works better.
One option is a USB card. They don't cost much either.
179 (0.05/day)
Tangent Universe
Case NZXT S340
what do you mean by 'some dont like hubs'?
this hub is not a cheap one, it is powered hub, so i assume i am good to go?
i have already used usb 3.0 extension card on pcie. didnt cost more than 10euros, and died few weeks later. some extremely bugy drivers.
Frick
19,819 (2.86/day)
north
Some stuff just don't like hubs. I use a mixer a lot and that doesn't work with any hub I've tried. Some USB sticks don't like 'em either, and I've seen mice/keyboards that don't like 'em. You know, just random USB stuff. It's pretty rare though, so you are good to go. It's not like you've got a choice. But again, PCI USB controller cards are cheap.
179 (0.05/day)
Tangent Universe
Case NZXT S340
thank you mate, appreaciate your feedback.
more feedbacks are welcome!
4,267 (0.67/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
Unless you need 4 front ports, perhaps have one or both of the USB headers in the rear:
43,546 (6.77/day)
Id say either grab a powered hub or a pci/pcie bus card. Or use a port pigtail like above
silentbogo
5,616 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 64GB DDR4-3600(4x16)
Storage ADATA Legend 2TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Your motherboard has to initialize your hub before it does the devices, which are plugged into it.
This is why your keyboard/mouse or anyting plugged into that hub won't work until it boots into OS.
I had to work around this crap on my PS3 many years ago, when I wanted to run YellowDog linux.
Same problem usually follows PCI-e cards.
What you need to do, is utilize that pair of FP_USB connectors. Use the back ports for KB/Mouse, plug in your WiFi into extension bracket, like the one @Jizzler posted, and use one connector for 2x front panel USB 2.0 for your flash drives.
No need for expensive hubs, especially because you'll have no gain from 3.0 hub working on a single 2.0 host port...
There is a ton of chinese crap on the market, made with fake host controllers, or badly constructed.
Either buy from a trusted brand, or at least check which controller it uses, and how well is it made (preferrably in person, somewhere in the physical store).
For reference:
- Asmedia controllers are probably the fastest on the market, but they die like flies (especially on motherboards). BUT, this is probably your only option for 3.1 (unless I've missed some retail VIA products)
- Etrontech is unstable, has problems
- NEC is probably your best option (Renesas D720201 or something like that). Relatively slow, but good for most applications. Long-lasting.
