Using Arctic Silver 5 on a gpu
naseltzer
72 (0.01/day)
Hey, could you guys offer any advice on applying AS5 to a 7800gt? I used it when applying my zalman 700alcu? It will sometimes burst to like 55 idle or higher at 100% fanspeed. If I slow down the fan even half way, it overheats. All kinds of stability problems. Also other problems. I'm wondering if I put it on wrong. I never used the card without the zalman, so I can't be sure that the card wasn't defective before.
N
overcast
733 (0.10/day)
Processor AMD Opteron 165 @ 2.7ghz Stock Voltage
Motherboard ASUS A8N-SLI Premium
Cooling Stock Opteron
Memory OCZ PC4000 EB Platinum 2GB
Video Card(s) ATI X1900XTX
Storage 2 x Western Digital 74gb Raptors
Display(s) NEC 990B 19"
Case Antec P150
Power Supply Seasonic S12-500
Software XP 32bit
So you are RMA'ing it because you screwed up and put to much paste on. Thereby cutting Neweggs profits , that will be reflected on the rest of us, because you want to exploit the process.
naseltzer
72 (0.01/day)
Yeah, you made a good point. I sounded like a jerk there. Though I was speaking a bit tongue-in-cheek. I don't actually think I scewed it up, though I can't actually be sure because I never ran it before installing the zalman. And I mean honestly, its not like their that hard to install. And I wasn't really all that descriptive of the problem. I should have also mentioned that sometimes the temps are fine (like 40), but will then shoot up to 55 for no apparent reason.
So, maybe it was screwed up before, maybe it wasn't. But that's why I buy at newegg, even if I could get it somewhere else for a little less. Security. Yes, its possible that I'm the one that screwed up and newegg has to eat it, but I also buy EVERYTHING from newegg. That's why they made it part of their business plan to give the customer the benefit of the doubt--they get loyal customers who will shop with them for years and recommend them to all of their friends.
Though I do see your point. It would be shameful for someone to regularly abuse their willingness to give RMAs.
spectre440
937 (0.13/day)
Israel
Processor Athlon 64 x2 4000+ (65nm Brisbane)
Motherboard Abit AN-M2 (AM2) nForce 630a
Cooling Stock everything (for the time being), 2x120mm fans (intake & exhaust)
Memory 2GB (2x1024) OCZ Platinum PC2-6400 (4-4-4-15, 2T)
Video Card(s) PowerColor ATI HD 2600XT 256mb GDDR4 PCI-e
Storage Hitachi Deskstar 160GB SATA 3.0G/s, External USB2.0 WD 160GB
Display(s) LG 17' LCD (L1753TR)
Case HEC-Compucase 6A, black & grey
Audio Device(s) On-Board 7.1 (realtek)
Power Supply Spire Zeno 650W
Software WinXP Pro SP2 (32-bit, for the time being)
wazzledoozle
5,358 (0.71/day)
Seattle
Processor X2 3800+ @ 2.3 GHz
Motherboard DFI Lanparty SLI-DR
Cooling Zalman CNPS 9500 LED
Memory 2x1 Gb OCZ Plat. @ 3-3-2-8-1t 460 MHz
Video Card(s) HIS IceQ 4670 512Mb
Storage 640Gb & 160Gb western digital sata drives
Display(s) Hanns G 19" widescreen LCD w/ DVI 5ms
Case Thermaltake Soprano
Audio Device(s) Audigy 2 softmod@Audigy 4, Logitech X-530 5:1
Power Supply Coolermaster eXtreme Power Plus 500w
Software XP Pro
55 load is actually good. 6/7 series cards are around 70 celsius load usually. The card was probably damaged from the start.
But next time use this stuff. Its non conductive and non capacitive, so its safe if you accidentally get some on the circuits. Its supposed to cool a little better too.
1,540 (0.22/day)
Athens - Hellas
Processor C2D E7600
Motherboard GA EG41M ES2L
Memory 2GB ADATA 800MHZ
Video Card(s) ASUS HD4350
Storage OCZ VERTEX TURBO 32GB + 2 MORE..
Display(s) SM226BW
Audio Device(s) 7.1 HD / X-540
Software 7X86 ULT
i agree with wazzledoozle.use ceramique next time.
and dont worry about RMA.thats the reason it exists...
2,481 (0.35/day)
Hey naseltzer,
I have my 7800GT at stock speeds with the stock cooler. At idle it stays around 37C and during load it is around 55C-60C (I have a PCI fan right below it). It could prob. be lower, but my wire management sucks and I am too lazy to open her up right now.
3,654 (0.50/day)
Little Rock Arkansas, United States
Yeah. I use the ciramique. It works pretty well. Combined with my NV silencer my 6800 GS only gets to 48~C load, and over clocked to 509MHz core and 611/1222MHz memory.
1,540 (0.22/day)
Athens - Hellas
Processor C2D E7600
Display(s) SM226BW
Software 7X86 ULT
it depends on which cpu.you wont have any problem using AS on an Intel cpu because it is "protected " by the heatspeader.but on an AMD cpu and on many gpus you must be extra carefull with all the circuits around.if AS touches them bye bye.
thats the reason of using ceramique in these cases.its non conductive and non capacitive so its safer if accidentally you do sth. wrong.
spectre440
937 (0.13/day)
Israel
any amd cpu newer than a socket-A athlon XP has almost the exact same heatspreader over its top as the intel cpu's.
1,540 (0.22/day)
Athens - Hellas
Processor C2D E7600
Display(s) SM226BW
Software 7X86 ULT
just giving a general example there..
1,540 (0.22/day)
Athens - Hellas
Processor C2D E7600
Display(s) SM226BW
Software 7X86 ULT
here is G70.no heatspreader.
if AS touches a circuit around the core..zzzzzzzzz
