Using Dual gigabit Ethernet ports?
4,909 (0.80/day)
Multidimensional
System Name Apple MacBook Air M2
Processor Apple M2 8 Core CPU
Motherboard Apple Motherboard
Cooling Laptop Passive Cooling
Memory 16GB LPDDR5 RAM
Video Card(s) Apple M2 8 Core GPU
Storage 256GB SSD
Display(s) 13.6-Inch Liquid Retina display 2560x1664
Case Apple Laptop
Audio Device(s) Generic Apple Audio
Power Supply Laptop Battery
Mouse Track Pad
Keyboard Laptop Keyboard
VR HMD ( ◔ ʖ̯ ◔ )
Software MacOS Sequoia
Benchmark Scores Don't do them anymore.
Hey guys, just wanted to ask a simple question. What can I use dual gigabit ethernet ports for and are there any benefits using it?:toast:
4,909 (0.80/day)
Multidimensional
Storage 256GB SSD
Case Apple Laptop
Mouse Track Pad
VR HMD ( ◔ ʖ̯ ◔ )
UUmmmm anyone home :D
5,461 (0.88/day)
Australia
Even i always wanted to know the answer to that question, because i haven't seen a use for them yet ether.
Someone would know, give it time.
Bo$$
Lab Extraordinaire
5,656 (0.98/day)
London, UK
System Name Desktop | Server
Processor Intel i7 2700k @ 4.6GHZ | AMD 5350 @ 2500MHZ
Motherboard Asus P7Z77-V Pro | Asus AM1I-A
Cooling Corsair H60v2 | Stock Air
Memory Crucial Ballistix 2x8GB CL8 1600MHZ | Corsair Vengence 2x4GB CL9 1600MHZ
Video Card(s) EVGA GTX 1060 6GB | PNY GTX 750Ti
Storage Samsung 840 EVO 250GB + 4TB WD Red | 2x Seagate Barracuda 2TB
Display(s) Samsung S27D390H + Asus VE276Q | Headless
Case Fractal Design R5 | CM Elite 110
Audio Device(s) Asus Xonar D1 w/Otone Stilo 5.1 and Creative Fatal1ty headset
Power Supply EVGA Supernova 850 G2| Corsair CX430M
Mouse Razer Imperator 2012
Keyboard Corsair K90
Software Windows 7 SP1 X64 | Ubuntu 16.04LTS
well im using one and it seems fine man, no need to waste your time and effort to get it working
443 (0.07/day)
BY-S36
System Name Bitch / Dogma
Processor 955 BE @ 3.8Gig / 9850 @stock
Video Card(s) 8800 GTX 512 / 4890
Storage 8 x Samsung F2 1.5TB, 8 x Seagate 500s
Display(s) Acer 24 / Dell 24
Case Lian li / Akasa
Software Win server 2008 / Win 7
There are a number of ways to use 2 Ethernet ports :
Two Network Connections (two subnets)
Will allow your PC to be connected to two networks at the same time.
Balance-rr (Round-Robin)
Transmit packets in sequential order from the first available slave through the last. This mode provides load balancing and fault tolerance.
Active Backup(Fail Over)
Only one slave in the bond is active. A different slave becomes active if, and only if, the active slave fails. The bond’s MAC address is externally visible on only one port (network adapter) to avoid confusing the switch. This mode provides fault tolerance.
Balance XOR
Transmit based on the selected transmit hash policy. The default policy is a simple [(source MAC address XOR’d with destination MAC address) modulo slave count]. Alternate transmit policies maybe selected via the xmit_hash_policy option. This mode provides load balancing and fault tolerance.
Broadcast
Transmits everything on all slave interfaces. This mode provides fault tolerance.
IEEE 802.3ad
Creates aggregation groups that share the same speed and duplex settings. Utilizes all slaves in the active aggregator according to the 802.3ad specification. This mode provides load balancing and fault tolerance but requires a switch that supports IEEE 802.3ad Dynamic Link Aggregation with correct LACP mode configured.
Balance-tlb (Adaptive Transmit Load Balancing)
Channel bonding that does not require any special switch support. The outgoing traffic is distributed according to the current load (computed relative to the speed) on each slave. Incoming traffic is received by the current slave. If the receiving slave fails, another slave takes over the MAC address of the failed receiving slave. This mode provides load balancing and fault tolerance.
Balance-alb (Adaptive Load Balancing)
Include balance-tlb plus receive load balancing (rlb) for IPV4 traffic, and does not require any special switch support. The receive load balancing is achieved by ARP negotiation. The receive load balancing is achieved by ARP Replies sent by the local system on their way out and overwrites the source hardware address with the unique hardware address of one of the slaves in the bond such that different peers use different hardware address for the server. This mode provides load balancing and fault tolerance.
4,909 (0.80/day)
Multidimensional
Storage 256GB SSD
Case Apple Laptop
Mouse Track Pad
VR HMD ( ◔ ʖ̯ ◔ )
Balance XOR
Broadcast
IEEE 802.3ad
Thanx for having the time to write that in depth description:toast::toast::toast::toast:
4,267 (0.67/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
Only 2? Weak! 4 is where it's at,
I even tried 6-way by adding the 2 on-board ports to the quad-port NIC team. But then I had a feeling that I never felt before... I said to myself, "this is too much". And I'm talking about my work network here.
At home not a lot of users would ever know the difference. I have a switch that supports up to two teams, so it's there for the boxes that will support it (I would not go out of my way and buy a NIC). Had a couple old Xeon servers with two ports apiece, but I don't run them any more.
hat
Enthusiast
21,750 (3.26/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
The only benefit I can think of is if you constantly transfer a shitton of stuff over your network, but for that to work, the computer you're transfering from has to be running at 2Gb too.
4,909 (0.80/day)
Multidimensional
Storage 256GB SSD
Case Apple Laptop
Mouse Track Pad
VR HMD ( ◔ ʖ̯ ◔ )
thanx for the help guys:toast:
28,883 (4.59/day)
Miami, Florida
Motherboard ASUS ROG Crosshair X670E Hero
Cooling ARCTIC Liquid Freezer III 360 A-RGB // X12 Phanteks D30-120 D-RGB Fans
Memory G.SKILL Trident Z5 Neo RGB Series (AMD Expo) DDR5 RAM 32GB (2x16GB) 6000MT/s CL30
Video Card(s) ZOTAC Gaming GeForce RTX 4090 AMP Extreme AIRO
Storage Samsung Pro 980 2TB NVMe (OS and Games) // WD Black 10TB HDD (Storage)
Display(s) SAMSUNG 34-Inch Ultrawide 75Hz (Desk Games) // SAMSUNG 49-Inch Ultrawide 144Hz (Sim Racing Rig)
Case Phanteks NV7
Power Supply Seasonic Vertex GX-1200, 1200W 80+ Gold, ATX 3.0
So not to create a new thread i'll sorta hi jack this one. There is no advantage in using both ports just for your regular PC use right, like it won't give you better bandwidth or anything like that? Heard this the other day and i'm not really into networking so it kinda made me wonder.
Mussels
Freshwater Moderator
58,412 (7.85/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Unless you have a managed switch (read: expensive) then you get NO benefits, other than should one cable fail, you have a backup connection.
when transferring files through windows, it doesnt split the load between network adaptors - it all goes over the one adaptor (the primary one, whichever that is) - even with two PC's set up and teamed, you only get 1Gb of transfer... cause the OS insnt designed to handle it.
28,883 (4.59/day)
Miami, Florida
Case Phanteks NV7
Thank you kind sir :D for clearing that up
