V/F points shows constant values
2 (0.67/day)
System Name Katana gf76
Processor i7 11800h
Video Card(s) 3050ti
my curve is a constant line, how to fix
unclewebb
8,042 (1.33/day)
What CPU model do you have? It is possible that the V/F stuff only works on fully unlocked K and HX series CPUs. It may not work on 10th or 11th Gen partially unlocked CPUs like you probably have.
Try checking the Use Core V/F Offsets box and then press the Apply button. Do any of the values change?
2 (0.67/day)
Processor i7 11800h
11800h. the offset values on the fivr table change when i apply an offset, but it then changes back to the adaptative values.
