VBIOS RX570/470 for MINGZHOU RX 580 8GB
43,069 (6.72/day)
Hello, I need VBIOS of RX570 or 470 to Mingzhou RX 580 8GB for I use Hackintosh. I already tryed a couple of, but without sucess. I didn't find compatible one. Somebody know what will workt fine with this GPU?
The original VBIOS is this: https://www.techpowerup.com/vgabios/249580/249580
Thanks
Get a gpu-z screenshot first, then go to advanced tab and select memory timings, get a screenshot there.
Get pics of white stickers on the back of the card
If the card can't display a picture on monitor in windows you will need to take heatsink off and get a pic of a ram chip.
samuel.rg
2 (0.00/day)
Here is the screenshots. The card have backplate, the stickers don't are visible (if have).
43,069 (6.72/day)
There is no bios that will work for you for your particular card to make it work for apple, if you want a card to work in apple buy a apple card.
Your bios must contain 1002 6FDF 1002 0B31 with 8GB of Elpida BABG ram.
