- Mar 10, 2010
- 11,878 (2.23/day)
- Manchester uk
System Name | RyzenGtEvo/ Asus strix scar II |
Processor | Amd R5 5900X/ Intel 8750H |
Motherboard | Crosshair hero8 impact/Asus |
Cooling | 360EK extreme rad+ 360$EK slim all push, cpu ek suprim Gpu full cover all EK |
Memory | Corsair Vengeance Rgb pro 3600cas14 16Gb in four sticks./16Gb/16GB |
Video Card(s) | Powercolour RX7900XT Reference/Rtx 2060 |
Storage | Silicon power 2TB nvme/8Tb external/1Tb samsung Evo nvme 2Tb sata ssd/1Tb nvme |
Display(s) | Samsung UAE28"850R 4k freesync.dell shiter |
Case | Lianli 011 dynamic/strix scar2 |
Audio Device(s) | Xfi creative 7.1 on board ,Yamaha dts av setup, corsair void pro headset |
Power Supply | corsair 1200Hxi/Asus stock |
Mouse | Roccat Kova/ Logitech G wireless |
Keyboard | Roccat Aimo 120 |
VR HMD | Oculus rift |
Software | Win 10 Pro |
Benchmark Scores | 8726 vega 3dmark timespy/ laptop Timespy 6506 |
So I think we need a club
Please post your cards version in this thread and i will add you to the club ,, It is not possible to discern Asic quality at the moment and ill update on this when it is.If possible we could do 3dmark default run comparisons too (default of any with a valid certificate ,though if its special case please include clocks and a gpuz cpuid page on your screanshot) , I might reasonably trace driver improvement through time ,, since i apparently spend as much time on 3dmark as any other game , ill try and get something on this together soon.
Validated timespy runs with a pic of gpuz and cpuid open as you would usually expect , ill post an example and format shortly.
I will do a spreadsheet of benchmark results when theres more then a few.
Stock bios download links and other's:
Founders edition https://www.techpowerup.com/vgabios/196039/amd-rxvegafe-16368-170616
Vega 64 Right side Tpu review sample https://www.techpowerup.com/vgabios/194442/amd-rxvega64-8176-170719-1
Vega 64 Left side Tpu review sample https://www.techpowerup.com/vgabios/194441/amd-rxvega64-8176-170719
Vega 64 LC version https://www.techpowerup.com/vgabios/195319/amd-rxvega64-8176-170811
other Vega 64 bios's https://www.techpowerup.com/vgabios...X+Vega+64&interface=&memType=&memSize=&since=
Vega 56 Left side Tpu review sample https://www.techpowerup.com/vgabios/194443/amd-rxvega56-8176-170730
Vega 56 Right side Tpu review sample https://www.techpowerup.com/vgabios/194444/amd-rxvega56-8176-170730-1
other Vega 56 bios's https://www.techpowerup.com/vgabios...X+Vega+56&interface=&memType=&memSize=&since=
link to AMD drivers
Win10 https://support.amd.com/en-us/download/desktop?os=Windows+10+-+64
Win7 https://support.amd.com/en-us/download/desktop?os=Windows+7+-+64
and Linux options https://support.amd.com/en-us/download/linux
Member's
@theoneandonlymrk powercolour ref vega 64+LC Timespy stck 5871(turbo)6412max*(oldFX8350) 8017 (GPU8323CPU6636) Ryzen 2600X Max Oc
@turbogear Saphire RX Vega 64
@springs113 saphire ref rx vega 64 and xfx ref vega 64
@acperience7 Saphire RX Vega 64
@londiste msi reference vega64
@fullinfusion MSI RX Vega 56
@kurosagi01 Sapphire RX Vega 64 8GB
@terroralpha Gigabyte Vega 64
@Eric3988 SAPPHIRE RX Vega 56 (64 BIOS Flash-mod)
@cdawall RX vega frontier edition
@Sasqui PowerColor Vega 64 3dmark Firestrike 16964 (21627gpu 14148Cpu 7317Comb)
@Fleb89 Vega 56 Asus strix vega 56
@blacktruckryder Powercolor Vega 64 Timespy 6943
@skeets sear Sapphire Nitro Vega 64 Timespy 9255
@Flyordie XFX Vega 64 +LC
@erek Engineering sample Vega 64
@INSTG8R Sapphire Nitro+ Vega 64 revision 2
@MarkJohnson Dell Vega 64
@Dinnercore MSI Vega 64
@Apocalypsee HIS Vega56
@F7GOS Asus Strix ROG Vega 64
@IvanP91v Asus Strix ROG Vega 64
@sepheronx Ref Saphire Vega 64
@GamerGuy Gigabyte RX VEGA 64 x2
@SpeedHunter Gigabyte RX VEGA 64 GAMING OC
@Hellfire Sapphire Vega64 Nitro+ x2 Crossfire Timespy 15254 (GPU15618CPU4610)
@Johan45 Asus Vega64 Strix Firestrike 21557(Gpu25551Physics28701Comb8469, Timespy 7999(Gpu15708Cpu13109)
@springs113 Sapphire and XfX reference model
@GoldenX Vega 11
Tuning corner
You will all likely have had a dabble at overclocking so this section is open to experimentation and ideas, and in construction.
So for gaming I found one tune setting does'nt fit all, in some games low voltages with high clocks can be unstable , crashing occasionally but never consistently.
so with the addition of the silicon lottery element its hard to suggest a definitive set of settings but I personally expect all cards to work reasonably with these.
Core p7 ,1550 p8 1600 @1.16V max / 950 memory @1V power limit @+35% Your Fan speed will require a tweak though mines water blocked so I have no clue what speed to set it at and it's personally optional.
these settings play any game well Afaik.
please let me know if you have better clock settings or issues with mine
I recommend using the chill option in wattman at all times , i've had no issues using it in games and it keeps temps and power use in check also use the frame limiter to stop the card doing insane fps values in some older game's since the heat and power use@180-30000 fps is'nt going to help the card last long and mine has crashed due to this occasionally
New OverdriveNtool beta thanks's @fullinfusion
AMD Mem Tweak Tool https://github.com/Eliovp/amdmemorytweak
thread for Amd Mem Tweak Tool https://www.techpowerup.com/forums/...-amd-radeon-memory-timings-on-the-fly.255830/
https://forums.guru3d.com/threads/overdriventool-tool-for-amd-gpus.416116/page-22#post-5619672
power play table mod guide video
please feel free to PM me with any suggestions you have for this club page.
link to AMD drivers
Member's
@GoldenX Vega 11
Tuning corner
