Hello everyone
I just build a new PC but I have a problem with the NvME so I can't get over it
The PC is MB ASUS proart Z690
I9 12900K
64 Mb RAM DDR5 5600 kingston
graphics card 1660Ti
1 NVME 2 TB samsung 980 Pro with OS WIN10
1 NVME 2 TB samsung 980 Pro with some dat
1 NVME 2 TB samsung 980 Pro with no data on it just formatted 500MB
The problem is that I have these disappointing performances from NVME, all three are more or less on these values (even the empty one just formatted)
Tests performed with crystal disk 7
CrystalDiskMark 7.0.0 x64 (C) 2007-2019 hiyohiyo
Crystal Dew World: https://crystalmark.info/
* MB / s = 1,000,000 bytes / s [SATA / 600 = 600,000,000 bytes / s]
* KB = 1000 bytes, KiB = 1024 bytes
[Read]
Sequential 1MiB (Q = 8, T = 1): 6793.875 MB / s [6479.1 IOPS] <1208.98 us>
Sequential 1MiB (Q= 1, T= 1): 2964.959 MB/s [ 2827.6 IOPS] < 345.60 us>
Random 4KiB (Q= 32, T=16): 75.915 MB/s [ 18533.9 IOPS] < 26273.34 us> <----------------- HERE THE PROBLEM
Random 4KiB (Q= 1, T= 1): 28.914 MB/s [ 7059.1 IOPS] < 133.97 us> <----------------- HERE THE PROBLEM
[Write]
Sequential 1MiB (Q= 8, T= 1): 4922.388 MB/s [ 4694.4 IOPS] < 1690.48 us>
Sequential 1MiB (Q= 1, T= 1): 3078.317 MB/s [ 2935.7 IOPS] < 332.76 us>
Random 4KiB (Q= 32, T=16): 56.373 MB/s [ 13762.9 IOPS] < 35562.51 us> <----------------- HERE THE PROBLEM
Random 4KiB (Q= 1, T= 1): 35.573 MB/s [ 8684.8 IOPS] < 107.19 us> <----------------- HERE THE PROBLEM
Profile: Default
Test: 1 GiB (x5) [Interval: 5 sec] <DefaultAffinity=DISABLED>
Date: 2022/09/09 13:50:31
OS: Windows 10 Enterprise [10.0 Build 19044] (x64)
as you can see the random write and read values are very different from those shown here while those sequentials are similar:
https://www.guru3d.com/articles-page...review,14.html
I presume given the date of the review the reposted values were taken from the same version of crystal disk, anyway I tried also with version 8.0 (current) and these values are the same
I tried to change brand by putting a NVME WD black 850 but the values are very similar, slightly lower.
NVMEs work via the microsoft driver
I tried to make them work with the Intel RST driver but the values get a little worse
I tried to unplug all the mechanical hard disks connected on the sata ports and also to disable them via BIOS but nothing changes.
I tried to run the crystal disk test in W10 safe mode to rule out interference from drivers or applications but nothing changes.
I tried to force the PCIe 4x mode from bios for the NVME slots (which otherwise by default are on auto) but nothing changes.
Using samsung magician i put all the nvme on high performance but nothing changes.
Magician also confirms low performance values.
Sequential read 1685 MB / s
Sequential write 1708 MB / s
random read 17,570 IOPS
random write 10,986 IOPS
Much lower than those reported as typical on the samsung website.
In particular, the random values are 1/10 of the expected.
Magician does not report errors with NVME drivers
The NVME firmware is updated to the latest release.
W10 is up to date.
I honestly don't know what ot check / do now.
I9 12900K
[Read]
[Write]
Profile: Default
W10 is up to date.
