VESA Releases DisplayPort 2.1 Specification
18,120 (2.45/day)
The Video Electronics Standards Association (VESA) announced today that it has released DisplayPort 2.1, the latest version of the DisplayPort specification, which is backward compatible with and supersedes the previous version of DisplayPort (DisplayPort 2.0). VESA has been working closely with member companies to ensure that products supporting DisplayPort 2.0 would actually meet the newer, more demanding DisplayPort 2.1 spec. Due to this effort, all previously certified DisplayPort 2.0 products including UHBR (Ultra-high Bit Rate) capable products - whether GPUs, docking station chips, monitor scalar chips, PHY repeater chips such as re-timers, or DP40/DP80 cables (including both passive and active, and using full-size DisplayPort, Mini DisplayPort or USB Type-C connectors) - have already been certified to the stricter DisplayPort 2.1 spec.
Achieving a robust, end-to-end user visual experience remains the utmost priority for VESA's DisplayPort specification, whether across a native DisplayPort cable, via DisplayPort Alt Mode (DisplayPort over the USB Type-C connector), or tunneled through the USB4 link. As such, DisplayPort 2.1 has tightened its alignment with the USB Type-C specification as well as the USB4 PHY specification to facilitate a common PHY servicing both DisplayPort and USB4. In addition, DisplayPort 2.1 has added a new DisplayPort bandwidth management feature to enable DisplayPort tunneling to coexist with other I/O data traffic more efficiently over the USB4 link. This increased efficiency is on top of mandated support for VESA's visually lossless Display Stream Compression (DSC) codec and VESA's Panel Replay capability. DSC bitstream support can reduce DisplayPort transport bandwidth in excess of 67 percent without visual artifacts, while VESA's Panel Replay capability can reduce DisplayPort tunneling packet transport bandwidth in excess of 99 percent when Panel Replay operation is taking place.
"Achieving greater alignment between DisplayPort and USB on a common PHY has been a particularly important effort within VESA given the significant overlap in use case models between the DisplayPort and USB4 ecosystems," stated Alan Kobayashi, VESA Board Chair and VESA DisplayPort Task Group Chair. "DisplayPort 2.1 brings DisplayPort into convergence with USB4 PHY specifications to ensure the highest video performance across a broad range of consumer products. Display transport through DisplayPort, with its higher bit rates and proven visual quality of DSC compression even for HDR content, offers ample bandwidth for the needs of virtually every practical application. Features such as driving multiple displays over a single cable, or enabling multiple functions on a single port like video, power and data transfer, no longer require any compromise in video format choice. The advanced capabilities of the DisplayPort video interface are enabled by the invaluable contributions by our more than 300 member companies from across the electronics ecosystem."
DisplayPort 2.1 has also updated the DisplayPort cable specification to provide greater robustness and enhancements to full-size and Mini DisplayPort cable configurations that enable improved connectivity and longer cable lengths (beyond two meters for DP40 cables and beyond one meter for DP80 cables) without diminishing UHBR performance. VESA certified DP40 cables support up to the UHBR10 link rate (10 Gbps), with four lanes, providing a maximum throughput of 40 Gbps, while VESA certified DP80 cables support up to the UHBR20 link rate (20 Gbps), with four lanes, providing a maximum throughput of 80 Gbps.
"For all of our standards including DisplayPort, VESA has invested significant resources in testing and auditing procedures, including interoperability testing of products incorporating VESA specifications. This is to ensure that products that are introduced to market that claim support of VESA's standards meet the high-quality benchmarks that we have established," stated James Choate, compliance program manager for VESA. "VESA continues to investigate and develop new procedures to improve our auditing process in order to ensure robust implementation of quality products supporting DisplayPort and other VESA specs in the market. Thanks to the contributions by test equipment vendors, VESA has a solid test infrastructure in place to support wider testing and deployment of DisplayPort 2.1 certified devices in the marketplace."
531 (0.37/day)
Germany
System Name Homebase
Processor Ryzen 5 5600
Cooling Scythe Mugen 5 RGB
Mouse Sharkoon Sharkforce Pro
Keyboard Fujitsu KB955
It must be really hard for such companies to create a proper chart with which cable and standard supports what metric......
3,403 (0.60/day)
Czech republic
Processor Ryzen 5800X
Motherboard Asus TUF-Gaming B550-Plus
Cooling Noctua NH-U14S
Memory 32GB G.Skill Trident Z Neo F4-3600C16D-32GTZNC
Video Card(s) Sapphire AMD Radeon RX 7900 XTX Nitro+
Storage HP EX950 512GB + Samsung 970 PRO 1TB
Display(s) Cooler Master GP27Q
Case Fractal Design Define R6 Black
Power Supply Seasonic PRIME Ultra 650W Gold
Mouse Roccat Kone AIMO Remastered
But why does virtually everything still only support DP 1.4?
17,644 (4.67/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Display(s) 27" QD-OLED Glossy 240hz 1440p
Case NZXT H710 (Red/Black)
So Radeon rdna3 may support dp2.1 after all, now that the spec is official. Good to see innovation continuing. Looking forward to the next generation of USB and thunderbolt as well.
I doubt it, the cards are already in production (I'd bet money on it), you have to stockpile before you can sell. I expect late November we will have launch, November 3rd is reveal date.
3,965 (0.60/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
…….still waiting for gpus and monitors to get caught up………
Hey Swede, you didn’t update the wiki yet!!
445 (0.10/day)
Lithuania
If you read the changes for 2.1 they are for cables, not related to cards, DSC support becoming mandatory, which AMD probably supported already and adjustments for USB4. Pretty sure they have all that down, especially considering that AMD and VESA work pretty closely together.
1,081 (0.19/day)
Porto
Processor Ryzen 9 5900X
Motherboard Gigabyte X570 Aorus Pro
Cooling AiO 240mm
Memory 2x 32GB Kingston Fury Beast 3600MHz CL18
Video Card(s) Radeon RX 6900XT Reference (amd.com)
Storage O.S.: 256GB SATA | 2x 1TB SanDisk SSD SATA Data | Games: 1TB Samsung 970 Evo
Display(s) LG 34" UWQHD
Audio Device(s) X-Fi XtremeMusic + Gigaworks SB750 7.1 THX
Power Supply XFX 850W
Mouse Logitech G502 Wireless
VR HMD Lenovo Explorer
Software Windows 10 64bit
This coming out just 2 weeks before the launch of the RDNA3 series is a strong indicator that these are bringing the new spec.
I wonder if this means the top RDNA3 cards are coming with the USB-C connector, like AMD's original Radeon 6900XT.
It could mean full PSVR2 support for the new GPUs, and other future VR headsets that sport a single cable.
Of course, I'm assuming the new DP2.1-over-USBC spec doesn't retract from previous DP2-over-USBC one, which brought 5Gb/s USB 3.1 (more than enough for accelerometers and dual cameras) and up to 100W USB-PD.
ARF
4,670 (2.53/day)
Ex-usa | slava the trolls
DP 1.4 supports only 8K@30 at 8-bit, and 4K@97 at 10-bit.
Even DP 2.0 only supports 8K@74 at 10-bit.
UHBR20 must be upgraded to support 8K@240 at 12-bit. That requires a lot of bandwidth.
DisplayPort - Wikipedia
445 (0.10/day)
Lithuania
Do you really think Sony would give their VR headset PC support?
Also isn't wireless just the future for PC VR? With AV1 encoding/decoding capabilities that seems like the future to me.
18,120 (2.45/day)
ARF
4,670 (2.53/day)
Of course, someone who has all the technical data shall do it.
1,081 (0.19/day)
Porto
Cooling AiO 240mm
Considering they gave official PC support to DualSense and they're making a significant push on PC gaming, yes. Future Playstation VR games released on PC will support PSVR2.
PSVR2 is already a headset that works much closer to a cheaper PC headset anyways. It uses inside-out tracking and a regular USB-C connection (probably DP2.0 in alt-mode), unlike PSVR1 that needed a camera with a custom connector to track the controller + headset lights.
Coding + decoding induces latency and should make reprojection techniques harder to achieve.
I do agree that the future of VR is wireless, but IMO it's probably coming in the form of 60GHz 802.11ay / WiGig 2 with 44 to 176Gbit/s with line-of-sight. That way there's no need to compress the signal.
OTOH, that also means we'll get new concerns with battery life and battery weight (ergonomy, confort, etc.). And for seated VR - which is what most people will use for anyways - a single cable isn't that much of a problem.
1,260 (0.99/day)
New GPUs should have at least one USB-C connector supporting full 80 Gbps speed.
There will be one HDMI 2.1 FRL at 48 Gbps, hoperfully, as 6000 GPUs gave us slightly trimmed HDMI 2.1 FRL at 40 Gbps.
I guess two other ports will be native DP at 40 Gbps.
But would not be surprised to see two USB-C ports, one HDMI FRL and one traditional DP. AIBs can adjust ports differently.
3,127 (2.34/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
But would not be surprised to see two USB-C ports, one HDMi and one traditional. AIBs can adjust ports differently.
Without compatible display devices those USB-C connectors on the GPUs will go for naught. And when I say display devices, I mean more than just traditional PC monitors. This also includes television sets.
Look at the VirtualLink port. The technology was never deployed by VR HMD manufacturers and the port disappeared after a single appearance on Turing generation cards.
1,280 (0.27/day)
South-Africa
Processor AMD Ryzen 9 5900X
Cooling Noctua NH-D15 G2
Video Card(s) ASUS GTX 1650 TUF
Storage SAMSUNG 990 PRO 2TB
Display(s) Dell S3220DGF
Case Corsair iCUE 4000X
Please don't go too fast, Nvidia has to catch with 2.0 first
Yeah, imagine the irony; nVidia pushes the first GPU that can do high 4k FPS gaming and then they limit it with a shitty DP 1.4 connector.
Ah, nVidia, you are the worst, you are true villains, posing as a legitimate company. It's almost like you are purposefully trying to see how you can screw your end-users with as little as possible in features for as much $ as possible.
3,502 (1.11/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
Valve is porting HL:A over to the PSVR2 so you never know. Valve in general has been helping companies advance VR. They gave HP their speaker and headstrap design for the G2 and the original Vive was made in conjunction with Valve.
Ultimately Sony would only be hurting themselves by not having PC support for the PSVR2. They'd be leaving a large portion of the market to their competitor Meta. In addition, people having a PSVR in hand would encourage sales of VR games exclusive to playstation. Even if they use it for PCVR, it's entirely possible they might just buy a playstation as well.
1,260 (0.99/day)
Without compatible display devices those USB-C connectors on the GPUs will go for naught. And when I say display devices, I mean more than just traditional PC monitors. This also includes television sets. Look at the VirtualLink port. The technology was never deployed by VR HMD manufacturers and the port disappeared after a single appearance on Turing generation cards.
There will be plenty of adapters for those who need an additional specific port and AIB models will be diverse in port offer. It should not be an issue at all.
My monitor from 2018 has USB-C Thunderbolt port, native DP and HDMI. Increasing number of monitors will have one or two.
Essentially, most GPUs and monitors will have native DP, HDMI and USB-C, so you can connect whatever you please.
18,120 (2.45/day)
My monitor can do 4K 160 Hz over USB-C. I've tested it using the VirtualLink port on my RTX 2080.
6,422 (1.55/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
shhhhh, pleeze don't tell them, lest they come up with yet ANUTHA scheme to justify milking us out of even moar $$ than they already are :(
3,127 (2.34/day)
I never said the technology couldn’t work. However for widespread adoption there needs to be strong support from the display industry in a timely manner.
Maybe that’s why NVIDIA stuck with DisplayPort 1.4 with the 40 Series generation.
Ultimately these standards need to be adopted by display manufacturers first. People hold onto their displays longer than their discrete graphics cards.
It’s not like everyone who buys a new graphics card will buy a new display at the same time.
wolf
Better Than Native
8,477 (1.30/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte B650I AX
Cooling Scythe Fuma 2
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
Are there even display's out with 2.0 let alone 2.1? I know the support needs to come sometime, but I am seeing a storm in a teacup here.
But hey, we all seem to enjoy a little bit of outrage right.
