VGA and Boot LED after VGA-Bios Update - Black Screen, No BIOS, No Post
Solios
4 (0.01/day)
MB:
  • MSI Gaming Edge Wifi X570
GPUs:
  • MSI GeForce RTX™ 3060 Ti GAMING Z TRIO 8G LHR
  • GTX 1650 Super
  • GTX 770
So i came across this article (https://www.nvidia.com/en-us/geforce/news/geforce-rtx-30-series-resizable-bar-support/) to enable ReBar
and i went ahead and got the MSI Dragon Center to initiate the VGA BIOS Update. It did its thing and restarted the PC automatically - after that i only got a black screen. No Bios or anything. Just nothing.
I checked on my MB and the Boot and VGA LEDs were red - well something went obviously wrong.
I reseted the BIOS via the Jumper and the Battery, didn't help. Tried with different GPUs, different PCIe slots (they GPUs work on a different System) same error - still both LEDs red. Every fan and every RGB works tho.
All options i found online didnt seem to help me - since most of them require that you can get into the BIOS with a different GPU or something similar - which isnt a option for me, since i just get a black screen regardless of what i do.
Now my question did this update really kill my Motherboard? Or is there anything else i can do?
413 (0.85/day)
Detroit, Michigan
System Name Desktop/HTPC
Motherboard Gigabyte X570 I Aorus Pro WiFi ITX
Cooling ID Cooling DashFlow 240mm AIO
Memory 64GB (2x32) G.Skill Trident Z RGB DDR4-3600 CL18
Video Card(s) Sapphire Pulse Radeon RX 7900 XTX 24GB
Storage 4TB WD SN850X NVMe, 2TB WD SN850X NVMe
Display(s) LG OLED65B9PUA 65" 4K OLED TV
Case Lian Li x Dan A4-H20
Audio Device(s) USB to MiniDSP DDRC24 DAC, RCA to SUMO Andromeda amp, wired to Wharfedale SP88 speakers
Power Supply Silverstone SX1000R SFX-L Platinum ATX 3.0
Mouse Corsair M65 RGB Elite
Keyboard Corsair K65 RGB Mini
VR HMD Oculus Rift / PSVR / PSVR2 / Lenovo Explorer
Find a USB flash drive, format it FAT32. An old small drive is fine - formatting will delete anything on it, so make sure to back it up first if needed.
Download the latest BIOS for your board from here:
Unzip the BIOS, rename it to MSI.ROM - if you can't see file extensions just change it to MSI or enable showing file extensions.
Do what it says above.
Hopefully that will unbrick it.
I strongly recommend never flashing a BIOS from Windows - the chances of something going wrong are much higher than from a command line or within the BIOS itself.
Solios
4 (0.01/day)
Thanks - i will try this. Usually i never flash BIOS from Windows. I simply followed the article from NVIDIA and the MSI Dragon Center cos i never did a VBIOS Update before. I know there are risks and i had to reset my BIOS already once after i OCed my RAM, but i never imagined doing the VBIOS Update via the Dragon Center would brick my whole system to the point even resetting the BIOS doesnt fix it.
413 (0.85/day)
Detroit, Michigan
Just to be clear - you updated the VBIOS, not the motherboard BIOS? And you've tried with another graphics card and are still getting no output?
Solios
4 (0.01/day)
Yes - i updated the VBIOS via the Dragon Center - not the mb BIOS. Other GPUs dont work either - same error. They do however work in a different system.
413 (0.85/day)
Detroit, Michigan
Still try what I suggested above, but that's just bizarre...
Solios
4 (0.01/day)
You are a life saver.
I had try 3 different USBs until it worked, but it went through at last.
I am still confused how this killed my BIOS completly - but at this point am just glad that it works again.
Thanks again!
413 (0.85/day)
Detroit, Michigan
Thanks again!
Label that USB and keep it in a drawer or something where you can find it in case this ever happens again!
