- Apr 29, 2006
- 5,105 (0.76/day)
- Sydney, Australia
System Name | UltraPC |
Processor | E8500 Core 2 Duo, 1333Mhz FSB, 3.16Ghz @ 4.5GHz (got into Windows @ 4.75GHz) |
Motherboard | ASUS P5Q-e |
Cooling | CPU Cooler - TT V14 Pro, 2x120mm CM Blue LED fans, 1x90mm CM Blue LED fan |
Memory | G.Skill Pi 4GB (2x2GB) Dual Channel DDR2 PC8000 (1000MHz), 5-5-5-15 |
Video Card(s) | Sapphire HD4850 512mb with ASUS EAH4850 BIOS |
Storage | 2x 500GB Seagate 7200.12 Raid 0 |
Display(s) | Acer AL1912, 19" LCD screen |
Case | Thermaltake Soprano Black ATX case |
Audio Device(s) | Onboard 7.1, Speakers - 5 + Sub + Monitor speakers |
Power Supply | Thermaltake 850W Toughpower Cable Management - Quad (2x18A and 2x30A) 12V rails |
Software | Win 7 Pro x64, MSN, CS:Source, etc etc |
Note: Please dont flame guys...just make suggestions.
These are the advantages and disadvantages i got with Vista from XP: (so far)
Advantages:
Really fast response time
Support for a lot of drivers automatically installed (LAN/Audio/Scanner/Printer)
Internet got faster (Ping on speedtest went from 18ms to 10ms)
Aero looks pretty cool (Not a stat, but my opinion)
Has its own security
Partitioning tool!!!
Sidebar has many features and clock is very handy
Windows Calender and Windows media center
Fast sleep and resume
Enhanced Video Quality
Live taskbar thumbnails
Parental controls
Encryption fearures
Flip and flip 3d window switching (I personally love this )
Games explorer
Windows search, Welcome center, Photo gallery, Sync center and Self-healing system
Disadvantages:
Not as many applications supported as XP, but generally ok (and will get better)
Cant use Visual Styles i.e. Msstyles
Neutral
The frequent popups asking you whether you should allow stuff or not. It isnt that annoying, and you can always disable it.
DirectX 10 (Neutral because it hasnt had any perf. increase yet)
Tested rigs:
1 - e6400, ASUS P5B deluxe, 2GB PC6400, X1950 PRO 512mb, 500GB HDD in RAID (full specs to left)
2 - (Laptop) PM 2Ghz, Dell 9300, 1.2GB PC4200, nVidia 6800 Go 256mb, 100GB HDD.
Problems
1 - Only problem is WMP not playing sound on more than two speakers, and that cant partiton more than 200 of the 500GB hard disk.
2 - Bluetooth driver has a bit of trouble (FIXED - Download latest driver from Dell site), and only can partition 45 of the 100GB hard drive.
Will test on:
1 - P4 2.6Ghz, Abit IS-50, 1GB PC3200, 9800 PRO 128mb/X800PRO to XT PE 256mb, 80GB IDE HDD.
Note - im using Vista Ultimate with all latest updates installed.
I, personally, HIGHLY recommend Vista. I have not had any major problems with it, and it has been fine so far.
Comment as much as you want, and let me add to my list
Now my first question - what security are you guys using?
Advantages:
Parental controls
Encryption fearures
Games explorer
Disadvantages:
Neutral
Tested rigs:
Problems
Will test on:
