- Feb 6, 2025
- 3 (3.00/day)
Processor | i5 14600k |
Motherboard | ASUS Prime Z790M-P |
Cooling | Peerless Assassin 120 SE |
Memory | 32 GB Kingston DDR 5600 |
Video Card(s) | RX 7800 XT OC 16GB |
Storage | Kingston SDD |
Power Supply | Be Quite 750W 80+ |
I have an issue for a newly build system (i5 14600k on a ASUS Prime Z790M-P)
When I do cpu benchmark w R23 the multiplier of the P-core drops.
If I keep it at standard 5300mhz it will drop to 5200mhz when the cores hit 100%
After the high load the cores will go up to 5300mhz during idle.
In single core test it remains 5300mhz
I have tried to increase the P-core multiplier to both x54 and x55 (sync all cores).
The same result. During idle CPU will run 5400mhz or 5500 mhz (in CPU-z). If run a R23 benchmark it will instantly drop to 5000mhz or 5100 mhz.
In Throttlstop I get constant red limit for Core: V MAX and RIng: EDP Other during the multi core benchmark test.
I have made an undervolt setup in the bios in order to reduce the temp of the CPU. Cores were up to 95c at full load.
After the BIOS undervolt changes max temp is below 70c.
I was getting Cinebench scores just below 22.000 before the undervolt settings. Now I am getting 24.000
The bios settings I have made are:
Furthermore I have maxed out my PL1, PL2 & IccMax.
Any advice on what I should do to fix the throttling?
- XMP I (for the RAM)
- Fixed core voltage to 1.20
- Disabled IA CEP
- Disabled SA CEP
