VRR Flicker when using Frame Generation
407 (0.53/day)
I recently changed my monitor and GPU. I've got an OLED Aorus FO32U2 240Hz and 5080. I know that OLED monitors in general are prone to VRR flicker with rapid changes in framerate or if there are frametime spikes but in my case problem happens only when using DLSS frame gen. I turned on monitor OSD to see the refresh rate and if I have frame gen enabled in games (tested CP2077, Alan Wake 2, Avowed) the refresh rate is erratic. At one moment it stays the same as my FPS only to jump +30hz or +40, 50 etc causing flicker. If I turn it off it stays synced with my framerate.
I tried to turn off vsync in driver settings, changed it to Fast but that didn't help. Anybody noticed the same on their side? I wonder if that is just the issue with 50 series or in general it happens. I will probably raise a ticket with Nvidia but since my monitor doesn't have official gsync certification I think they are just going to say that this is what's causing this. I mean it could be but then why it only happens with frame gen?
