no0oo00o0o0o
- Nov 27, 2022
- 2 (0.00/day)
This is the model I'd like to turn down the fan speed of whenever it's idle, currently it only goes down to 35%. Someone on reddit said that the most important things to keep consistent when flashing across models are the power connectors and display ports - it has no power connector:
www.techpowerup.com
MSI states that the only MSI cards which support this fan feature (branded as "Zero Frozr") are their GAMING and ARMOR series. The display ports of this GAMING model (which supports zero fan speed), are identical, but it has a 6-pin power connector. How safe would it be to flash this VBIOS?
Alternatively, Zotac calls this feature "Freeze", but I also haven't found any Zotac models which both support this, and have no power connectors.
If anyone could recommend another VBIOS model, or something else I could do to override the minimum fan speed, that would be awesome. Maybe even some piece of hardware which controls the fan separately, or replacing the fans with ones that are controllable? These threads [1] [2] mention "low-noise adapter" cables, which seem relevant. My motherboard is a B350 Tomahawk.
Thanks
![www.techpowerup.com](https://www.techpowerup.com/gpu-specs/images/b/4261-front.small.jpg)
MSI GTX 1050 Ti AERO ITX OC Specs
NVIDIA GP107, 1455 MHz, 768 Cores, 48 TMUs, 32 ROPs, 4096 MB GDDR5, 1752 MHz, 128 bit
Thanks
