Warzone low FPS with low CPU/GPU usage
K00KSS
2 (0.00/day)
Hello! I have a problem with the warzone, namely, regardless of the selected graphics settings or the lowest or maximum, the game displays the same number of frames and the CPU and GPU consumption is constant. I throw 2 screens, one of which is at the maximum details and the other at the lowest . I have the newest drivers.
My hardware is a Lenovo Legion Y540-15IRH with an I5 9300HF, RTX 2060 and 32GB Ram, 512 SSD with Win 10
I’d be monitoring your CPU and GPU temps first to rule out any throttling. It’s a demanding game for desktop PCs as well.
After 2 hours of playing, the temperatures on the CPU and GPU do not exceed 70 degrees
Seems fine, just know lots of people have issues with game performance no matter the hardware. There is no specific solution you haven’t tried. I own it but have only played I enough to test for another user with the same GPU to prove his experience was normal. I’m sure there are dozens of tweaks to be found on the web and maybe find something useful.
I know this post is 2 weeks old now but did you happen to find a solution? I am having the exact same problem with my 2080S except my usage and FPS are much lower. At 2k or 720p it still stays the exact same.
Try doing a clean install of older drivers. The newer drivers have not been good to me either.
From your screenshots looks like the graphics card isn't at its fullest.
Check the config file under My documents-cod mw,edit in notepad and set renderworkercount to 4,where 4 is the number of physical cores your cpu has.
Warzone engine is very bad optimized but benefits from high core count and high ram.
A friend of mine plays on notebook with avg 90+fps,same specs but 6core cpu and 16gb of ram(i7-9750h)
The game is very cpu intensive, but yeah check the config file for renderworkercount should be 4
