Water Chiller - that's her modified for Subzero ;-)
470 (0.15/day)
Scotland
EDIT: 22/01/2017
Frost ;-)
ORIGINAL MESSAGE: 12/01/2017
Quite pleased with myself tonight, lol.
err... Google...... :respect:
Never broke anything; and it's working perfectly (so far lol -- I hope the wire I used, was thick enough) :slap:
It might just be me, my excitement; but I am actually sure, it is cooling more powerfully too. (Usually by now, with GPU & CPU fully loaded + overclocked, falling water temp would have slowed) :wtf:
Thermostat set to 32c -- but Chiller still running at temp of 25c (for demonstration) :)
After my insulation order arrives, (and I've set it all up) I'll update this video showing sub-zero temps,
Front cover off
front panel & thermometer disconnected
First Attempt (brown wire)
What a donut; I never cut wire long enough:banghead:
That's more like it :) (outside left, to outside right, blue wire) this bypasses thermostat; chiller now runs as soon as power is switched on; regardless of water temperature
to regain Temperature Control & still have sub-zero
and/or
Run off external temp controller
-If I wanted; I could wire a Ranco Temperature Controller up to a Surge Protector/Extension.
-Plug the Water Chiller in to the Surge Protector/Extension.
-The Ranco Temperature Controller applies power to the SP/Extension socket when the temperature reaches what you set it to.
-You can learn how to wire a Surge Protector/Extension to a Ranco Temperature Controller at you-tube :)
So far:
1) Pick a subzero compatible coolant
(complete, 2 picked out; 1 for backup) :toast:
2) Modify Chiller electrics for subzero (complete):toast:
3) Insulation (never done this before -- research starts now) any advice?
~My Dream Machine~
cdawall
where the hell are my stars
27,683 (4.10/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
Fix the tubing so it isn't uselessly long in the case and run the same style insulation you have in the cooler on the tubing. The board is a bit more work.
470 (0.15/day)
Scotland
Thanks,.. this is.. I suppose.. maybe going to be the scariest part of all :)
especially where the GPU is concerned :) (insulation)
10,895 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6400 1:1 CL30-36-36-76 FCLK 2200
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
These are great... benchies and temps!
Would it help the chiller if you ran the triple rad prior to it hitting? or would that just create additional condensation?
Toothless
Tech, Games, and TPU!
9,689 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Way too much tubing. More tubing seems like it would have more area for heat to get back in before it hits the chip.
2,012 (0.35/day)
Heart of Eutopia!
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling old socket775 cooler
Memory 32 Viper
Storage raptors+ssd
Display(s) acer 120hz
Case open bench
Audio Device(s) onb
Mouse mx 518
Keyboard roccat arvo
i really dont want to spoil your enthusiasm.
just my opinion
i think you should have let the chiller be chiller and get a single stage for benching thats the only way for really going below 0° except ln² or dry ice
but i see you like pushing your hardware.
470 (0.15/day)
Scotland
Radiator isn't connected. Just left it in the top of the case.. its not affecting anything. Almost forgot it was there. The fans are still left spinning at their lowest setting to help create good airflow (they're on exhaust) and the front is on intake. Not that any of this will matter much during a subzero run...
Evening,
Last step on my little mission, is figuring out the insulation requirements for condensation.
After a bit of research, I placed orders tonight for all this:
  • Duct Tape - self explanatory (this is also waterproof) £4
Total = £40 (after delivery costs about £55 due to all from different suppliers)
Can anyone think of anything I've missed?
Nick Peyton
DOM
7,628 (1.12/day)
TX, USA
Processor Intel i7 4770K
Motherboard Asrock
Cooling Water
Memory Team Xtreem LV 16GB (2x8GB)
Video Card(s) EK Full WB HD7970
Display(s) CROSSOVER 27Q LED-P 27"
Case Danger Den Torture Rack
Power Supply CORSAIR Professional Series Gold AX1200
Software W 10 Pro
Art eraser you said you have some is it the gray one?
You can knead it and it should get softer or also stretch it out or folded over and over just to make it softer to work with
470 (0.15/day)
Scotland
I was scared to bump this.
Thank you, for following this up, after the other thread was closed.:)
I've found this on Ebay:
"Kneaded putty rubber which can be moulded and shaped by hand. Ideal for picking out highlights and erasing pencil, chalk or charcoal.
Approximate eraser dimensions: 48mm x 37mm"
http://www.ebay.co.uk/itm/Koh-I-Noo...224323?hash=item360e2f71c3:g:mN4AAOSwB09YRvYS
Perfect, thank you. I've ordered 7.
On a similar note;
Dielectric Grease - anyone have an opinion on this? I've read conflicting information....
Is it easy to remove without corroding your equipment in the removal process?
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
It won't create condensation.
It would help to remove the radiator.
As you can see i kept the Radiator.
The reason i kept the Radiator.
Keeping the radiator it's something positive in winter months, i have a 280mm Rad inside the case with 2 fans attached to it, the water that flows into the radiator makes the Rad very cold + 2 fans pushing air inside the Machine through the Rad at 1200rpm helps to keep temps inside the Machine at least 1c less than the room's temperature.
Right now the room's temperature is 17c and inside the Machine is 16.1c
cdawall
27,683 (4.10/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
You lose efficiency from the chiller when you leave the radiator in the loop. If the goal is the best water temps it needs to go.
2,100 (0.48/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
On a similar note;
Only place I use dielectric grease is in the socket. Yes, you can clean it out without damage.
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
Give me a good reason.
If you're looking for -c maybe it could be but for what i need it i don't think so.
cdawall
27,683 (4.10/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
It's not a thought thing if you run chilled water through a radiator with higher temperature air pushed through it you literally heat the water.
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
cdawall
27,683 (4.10/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
How am i heating the water?
If the air temperature is above the water temperature then using the radiator will heat the water.
Something about physics.
470 (0.15/day)
Scotland
You're chiller will be working harder IF you're running the water temperature below your ambient.. If you're running it anywhere above ambient -- you're probably helping the Chiller... it all depends on ambient. I know you don't have a heater in your room :)
Its entirely up to you, though, how you want to run it.. it depends on what suits your needs the most :) The quick connect/disconnect was a very good idea.
Some people during gaming may have a water temp that will equalise at between 28-32c. If you only plan on running at 18c (for peace of mind that you're a still 5-10c cooler than an extra radiator could ever, have managed) then I don't see a problem with that :)
You probably paid the cost of 2 radiators for the "guaranteed" 18c(?) which you will always be able to match, regardless of day-to-day differences in ambient/weather. You'd never have this level of consistency simply buying more radiators.. but with the Chiller.. you do :)
So again it all depends what your goal is, if you're happy that's the main thing :)
You still, of course.. have the extra power to go even lower if you are feeling more adventurous one day... again.. if you'd just upgraded your radiators... you'd of had to roll your rig outside to get another 10c. So again, the Chiller still wins.. in my eyes :)
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
It depends how you set the loop, if i would have the Rad between Chiller and CPU i would agree with you but i have the loop set this way: Pump/reservoir ---->Rad---->Chiller---->CPU
the last component in the loop is the Rad because in that way the water that goes from the Rad to the Chiller before it goes to the CPU it has been already cooled.
2,100 (0.48/day)
Spencerport NY
System Name Master
Doesn't matter. The order affects nothing. Fact is, that rad pumping ambient air into your chilled loop is heating it up slightly, and giving you a very large condensation target.
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
There is no way that it will heat the water because the ambient air is cooler than the Chiller's water temp.
The water temp it is not running below ambient.
I know that very well:toast:
I will running it depending the Machine's needs, could be lower than 18c or maybe higher.
Ambient temperature
Water temperature
Temp inside Machine
2,100 (0.48/day)
Spencerport NY
System Name Master
In your case, I concede. Normal people's ambient is usually between 20-23c. I had no idea that you live in a morgue.
DOM
7,628 (1.12/day)
TX, USA
Motherboard Asrock
Cooling Water
Software W 10 Pro
Why is this even going on in the op thread?
And 4.5 oc with a chiller Knoxx?
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
In your case, I concede. Normal people's ambient is usually between 20-23c. I had no idea that you live in a chiller.
I don't use a Heater in the room where i have my Machines, that is why i have low ambient temps.
Maybe i am not normal,:rolleyes: i hate Heaters, it doesn't matter how cold it is i don't use the heater.
A big heater.
I just use it to decorate the room:roll:
4.6GHz
The CPU it is not mine, that's why i don't OC higher.
DOM
7,628 (1.12/day)
TX, USA
Motherboard Asrock
Cooling Water
Software W 10 Pro
What a waste I run 4.6 on air lol
